Cisco Systems IP, Ethernet, ATM and DHCP
Subject Author Date
IP, Ethernet, ATM and DHCP Lars L. Christensen 10-11-05
Posted by Lars L. Christensen on October 11, 2005, 10:28 am
Hi there
I've got a setup where my core network is based on ATM and some of my
distribution network is based on Ethernet. The setup is shown below:
- means ethernet
= means ATM
dhcp -- router == ATM -- ethernet
ATM -- ethernet
My setup requires a common VLAN id on the whole (ethernet) network.
In order to connect the two ethernet segments and the router (which works
as the default gateway for all users connected to the ethernet segments),
all PVCs and ethernet subinterfaces are bridged together using the bridge
command.
Equipment is:
router: 7204vxr
ATM: Catalyst 8510 MSR with ARM and FastEthernet ports.
ethernet: Catalyst 2950 EMI switches.
dhcp: ISC DHCPd
The problem is when I run DHCP on the network, it seems like I'm unable
to obtain IP addresses from a central DHCP server.
In order to find out, whats going on, I've started sniffing on the
network with a analyzer (ethereal) and it looks like not all requests
enters the DHCP server and not all DHCPoffers are returned to the client.
How do I create a bridged network, that works as expected?
Hope someone has a good answer.
Cheers, Lars Christensen
Similar ThreadsPosted
IP, Ethernet, ATM and DHCP October 11, 2005, 10:28 am
1 Ethernet port and 2 DHCP ranges March 9, 2006, 5:25 pm
router dhcp, two ethernet and firewall January 11, 2008, 10:56 pm
Simple Ethernet to Ethernet setup (cisco 1605R) But I can't get it to work. July 7, 2005, 12:59 pm
Use router ethernet interface as a layer 2 ethernet port November 24, 2006, 7:53 pm
Ethernet and non Ethernet Leads April 1, 2007, 1:49 am
Ethernet and non Ethernet leads April 1, 2007, 1:49 am
how to add a second ethernet interface August 20, 2005, 9:04 pm
unnumbered for ethernet? August 29, 2005, 11:04 pm
Power over Ethernet February 13, 2006, 5:00 pm
2620XM - Ethernet WIC ? February 20, 2006, 5:50 am
Powerline ethernet February 20, 2006, 2:31 pm
POS to ethernet converters? March 9, 2006, 2:34 am
bridge: ethernet over FR March 15, 2006, 12:35 pm
poewr over ethernet June 15, 2006, 6:06 am
