Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Max on May 6, 2008, 2:54 pm
Please log in for more thread options I have a problem concerning 'IP CLASSLESS' on cisco routers I have quite a lot of vpn tunnels with IP CLASSLESS enabled on the router and some that it is not enabled. i have noticed that there are some application that i'm using that are not working fine when it's not enabled. i've tried to enable it on those routers but it doesn't seem to change anything. i typed 'IP CLASSLESS' and when i look in the running config it's nowhere for example: cisco 871w with IOS Version 12.4 = no IP CLASSLESS = not working ( but i don't seem to be able to enable it) cisco 851 with IOS Version 12.3 = IP CLASSLESS enabled = works fine any explanation? | ||||||||||||||||||||||||||||||||||
Posted by News Reader on May 6, 2008, 7:28 pm
Please log in for more thread options There are numerous commands that do not show up in the configuration file when set to their default state. Furthermore, the default may change from one IOS release to another, as well as whether they show up when configured to their default state. The behavior of "Default Routing" is very much dependent on the setting of "IP Classless", and is likely the functional issue you have observed. Best Regards, News Reader | ||||||||||||||||||||||||||||||||||
Posted by Paul Matthews on May 7, 2008, 3:40 am
>nowhere On by default.To prove it, try "no ip classless" and watch that appear. -- Paul Matthews CCIE #4063 Please post questions to the NG, NOT by e-mail. | ||||||||||||||||||||||||||||||||||
Posted by Merv on May 7, 2008, 4:46 am
AFAIK these commands are a special case of what is displayed by show running-config; typically default commands are not displayed. Both of the commands "ip classless" and "no ip classless" will show up in output of sh running-config. At least this is the behavior with IOS 12.3 | ||||||||||||||||||||||||||||||||||
Posted by Merv on May 7, 2008, 8:04 am
Please post output of show version from the 871W | ||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| IP CLASSLESS not working | May 6, 2008, 2:54 pm |
| ip classless and auto-summary | August 4, 2006, 12:23 pm |
| Question about Redistributing Between Classful and Classless Protocols | June 28, 2005, 8:51 am |
| Call transfer full consult is not working properly, blind transfer is working instead | October 8, 2008, 8:04 pm |
| sh cdp n not working | September 1, 2005, 9:31 am |
| VPN working | October 7, 2005, 4:17 am |
| PBR not working | March 9, 2006, 3:02 pm |
| NAT/PAT not working in PIX 515 | April 27, 2006, 10:45 pm |
| QoS not working | February 26, 2007, 12:43 pm |
| PAT not working :-( | March 8, 2007, 3:38 pm |
| NTP not working? | April 4, 2007, 5:10 pm |
| PAT not working | April 9, 2007, 4:16 am |
| Help, FTP thru ASA not working | July 4, 2007, 6:04 pm |
| Cisco SDM is not working | July 11, 2005, 8:07 am |
| SSH stops working | July 17, 2005, 10:14 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> anything.
> nowhere
> for example:
> any explanation?
