Cisco Systems IOS SLB on what hardware?
Subject Author Date
IOS SLB on what hardware? <tva 09-19-05
Posted by on September 19, 2005, 6:02 pm
I've been trying to gather information on which hardware the Cisco IOS SLB
(Server Load Balancing) software will run. The Cisco website suggests that
the Cat6k and higher is supported, but those are really expensive platforms.
I'm looking to run IOS SLB (or equivalent) on the smallest switch platform
capable of reasonanle capacity. Basically load-balancing proxy servers that
use TCP (http) and UDP protocols.
Can one run IOS SLB (or a smaller variant) on, say, a 2950 series switch?
Regards,
-Tiaan.
Posted by Falk Stern on September 20, 2005, 3:31 am
> Hi,
As far as the Cisco Website goes, it is only supported on 7200 Routers
or Catalyst 6500 Switches (or 7600 Routers, which have the same hardware)
(according to
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/
121t/121t5/iosslb5t.htm#1015343 )
SLB would have to run on a router, Cat6k support it, because of the
MSFC, which _is_ a router.
No. You will need a router for this. Another "cheap" possibility would
be a Linux Server with ipvs installled
(http://www.linuxvirtualserver.org/)
Have a nice day,
Falk
Posted by on September 20, 2005, 6:03 am
switch?
Aha... so I can run IOS SLB on a 2600-series router with two ethernet
interfaces? (See, I used to use Alteons for this functionality, hence the
reason I was looking at switches).
*nod* I've looked at this as a possible solution, but IOS SLB has some very
specific functionality on the UDP side that we need.
Regards,
-Tiaan.
Posted by Per Heldal on September 20, 2005, 3:54 am
On Tue, 20 Sep 2005 00:02:15 +0200, tva wrote:
> Hi,
> Regards,
> -Tiaan.
SLB, regardless of vendor, is a feature that require routing-
capabilities. Although devices may be optimised for a certain function it
is a general rule that a box with a certain feature need to implement some
form of all functions below this feature in the protocol stack. Thus, you
won't find ethernet switches (L2) that implement SLB-features (L4+) unless
they also support basic path-selection and packet-forwarding (L3)
functions. Cisco's Cat6k does support SLB though its MSFC which is a
router, in fact the same route-processor you'll find in some of their
72xx/75xx/76xx boxes.
//Per
Similar ThreadsPosted
IOS SLB on what hardware? September 19, 2005, 6:02 pm
Please Recommend Hardware February 9, 2005, 4:54 am
871 and AES hardware encryption. July 25, 2005, 1:22 pm
Hardware Recommendations December 12, 2005, 6:01 pm
How to tell 3845 hardware rev? January 23, 2006, 10:09 am
HARDWARE cef or SOFTWARE cef ? March 22, 2006, 9:56 am
hardware to run a 64k dso - wic-1dsu-t1?? April 18, 2006, 11:15 am
PIX Hardware problems August 23, 2006, 5:27 pm
Hardware Monitoring December 4, 2006, 4:21 pm
Dual WAN Hardware March 29, 2007, 5:02 pm
PIX Hardware and fans May 9, 2009, 3:25 am
Recommended Hardware for eBGP November 2, 2005, 12:58 pm
IOS for wide array of hardware May 15, 2006, 1:57 pm
Client Hardware address July 5, 2006, 7:29 am
Hardware config question December 21, 2006, 6:05 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
