Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Cisco563 on December 10, 2006, 12:05 pm
completed I reload the switch, when the switch is coming up I get a message that "Loading "c3500XL-c3h2s-mz.120-5.WC2.bin"...c3500XL-c3h2s-mz.120-5.WC2.bin: permission denied Error loading "c3500XL-c3h2s-mz.120-5.WC2.bin" Interrupt within 5 seconds to abort boot process. Boot process failed... " Why can I boot from the image? Thank You | ||||||||||||||||
Posted by Make on December 10, 2006, 2:01 pm
Please log in for more thread options http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080094955.shtml If you receive the error loading flash message, this indicates that there is a problem loading the current image in Flash. The image may be corrupt, an incorrect image, or the image in Flash may be missing. If the system is unable to load a software image in Flash, the system loads the boot helper and brings up a switch: prompt. Otherwise it is in a continuous boot cycle. If the switch is stuck in a continuous boot cycle, use this procedure to bring up a switch: prompt: | ||||||||||||||||
Posted by Cisco563 on December 10, 2006, 9:41 pm
Please log in for more thread options I followed what both section said to do. The only way that I am able to
boot the image is if I boot it manually by using the command "boot flash:c3500xl-c3h2s-mz.120-5.WC11.bin". However, after I reload the switch I have the same problem. What else can I do? Thank You Make wrote: >
> If you receive the error loading flash message, this indicates that there is > a problem loading the current image in Flash. The image may be corrupt, an > incorrect image, or the image in Flash may be missing. If the system is > unable to load a software image in Flash, the system loads the boot helper > and brings up a switch: prompt. Otherwise it is in a continuous boot cycle. > If the switch is stuck in a continuous boot cycle, use this procedure to > bring up a switch: prompt: > > >I just did an IOS upgrade on a 3500 switch. After the uploading
> > completed I reload the switch, when the switch is coming up I get a > > message that "Loading > > "c3500XL-c3h2s-mz.120-5.WC2.bin"...c3500XL-c3h2s-mz.120-5.WC2.bin: > > permission denied | ||||||||||||||||
Posted by Make on December 11, 2006, 12:28 am
Please log in for more thread options So you have wrong boot string? Boot manually and conf t:
boot system flash:c3500xl-c3h2s-mz.120-5.WC11.bin (or something like that) exit write reload >I followed what both section said to do. The only way that I am able to
> boot the image is if I boot it manually by using the command > "boot flash:c3500xl-c3h2s-mz.120-5.WC11.bin". However, after I reload > the switch I have the same problem. What else can I do? | ||||||||||||||||
Posted by Doug McIntyre on December 11, 2006, 9:39 am
Please log in for more thread options >I followed what both section said to do. The only way that I am able to
>boot the image is if I boot it manually by using the command >"boot flash:c3500xl-c3h2s-mz.120-5.WC11.bin". However, after I reload >the switch I have the same problem. What else can I do? I've seen this a couple times. Try resetting your boot strings in both the IOS boot configuration, as well as in the bootstrap monitor once it bombs out. Make sure your config register is correct. Its a strange error indeed. >Make wrote:
>> If you receive the error loading flash message, this indicates that there is >> a problem loading the current image in Flash. The image may be corrupt, an >> incorrect image, or the image in Flash may be missing. If the system is >> unable to load a software image in Flash, the system loads the boot helper >> and brings up a switch: prompt. Otherwise it is in a continuous boot cycle. >> If the switch is stuck in a continuous boot cycle, use this procedure to >> bring up a switch: prompt: >> >> >I just did an IOS upgrade on a 3500 switch. After the uploading
>> > completed I reload the switch, when the switch is coming up I get a >> > message that "Loading >> > "c3500XL-c3h2s-mz.120-5.WC2.bin"...c3500XL-c3h2s-mz.120-5.WC2.bin: >> > permission denied | ||||||||||||||||
| Similar Threads | Posted |
| 3500 XL switch | October 11, 2006, 10:45 pm |
| IOS 3500 switch | December 10, 2006, 12:05 pm |
| enable Span on Cisco Switch 3500 | October 16, 2006, 8:39 am |
| My Cisco Catalyst 3500 XL Switch is Dead ?!! | September 5, 2007, 2:45 pm |
| Traffic Shaping & Qos on 3500/3700 Switch tough one | August 18, 2006, 10:44 am |
| 2900 XL-EN vs 3500 XL-EN | June 13, 2007, 3:31 pm |
| SNMPv3 with Catalyst 3500 XL | August 30, 2005, 12:31 pm |
| 802.1q debugging on Catalyst 3500. | August 2, 2006, 9:04 am |
| 3500-XL Requirements for PVLAN | October 4, 2006, 4:48 am |
| Re: cisco 3500 series XL | April 12, 2007, 6:31 am |
| Runts between Catalyst 2950 and 3500? | August 31, 2005, 1:18 pm |
| Remove ALL configuration from a Catalyst 3500? | October 7, 2005, 7:06 am |
| port fast ? cisco 3500 xl | October 14, 2005, 8:16 am |
| Catalyst 3500 switching method | July 5, 2005, 11:56 am |
| enable 3500 snmp agent | March 20, 2009, 8:04 pm |
IOS 3500 switch
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> permission denied
