Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Fred Atkinson on November 17, 2005, 1:24 pm
Please log in for more thread options Update: 90 seconds Invalid: 3 x update Hold-down: 3 x update plus ten seconds Flush timer: 7 x update Question: If the update timer is changed by the administrator, do the values of the other timers change according to these rules (3 x new update value) or do they stay the same (3 x default update value)? Fred | |||||||||||||
Posted by Merv on November 17, 2005, 3:47 pm
Please log in for more thread options command within the IGRP routing process: router igrp 1 timers basic update invalid holddown flush [sleeptime] exit Cisco recommends preserving the ratios between the default values should new values for the timers be configured, but I do not believe it calculates these automatically (i.e if you change one, then change all) | |||||||||||||
| Similar Threads | Posted |
| IGRP Default Times Question | November 17, 2005, 1:24 pm |
| IGRP to a Pix 506 | May 14, 2007, 11:02 am |
| Default Route Question | September 4, 2007, 3:32 pm |
| A question about default vlan | July 2, 2008, 7:43 pm |
| IGRP Routing Tables | May 2, 2006, 12:59 am |
| Migrating from IGRP to EIGRP | May 5, 2006, 1:49 am |
| VPN Client times out in 3 minutes | July 25, 2005, 10:10 am |
| increasing ping times | December 10, 2005, 9:38 pm |
| Multilink PPP vs ping times. | March 27, 2007, 1:24 am |
| ASA 5510 restarts itself several times a day | August 18, 2008, 10:01 am |
| pb with load balancing using igrp variance | October 14, 2005, 2:57 am |
| IGRP EIGRP multicast addresses | November 30, 2005, 10:01 pm |
| Propagating 0.0.0.0 routes from EIGRP into IGRP | April 27, 2006, 2:13 pm |
| Sending the same Trap Multiple Times | October 1, 2005, 7:29 am |
| Ping response times - same after upgrade of bandwidth | January 24, 2006, 2:38 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
