Cisco Systems How to detect interface?
Subject Author Date
How to detect interface? Kesy 02-27-08
Posted by Kesy on February 27, 2008, 9:21 am
How to detect (via snmp - the best way) interfaces (on cisco catalyst
switch) connected PC with enabled WakeOnLan?
PC is turned off, interface is up due WakeOnLan on PC.
Kesy,
Posted by Walter Roberson on February 27, 2008, 10:33 am
That's quite difficult to do. Without actually waking up the PC
you have a quite hard time distinguishing the WakeOnLan case from the
case of a machine that is not presently active on the network
and which is refusing to talk to you.
Posted by Trendkill on February 27, 2008, 10:45 am
I agree, considering to the switch it is just a mac, you would need
some kind of wakeonlan discovery tool, as a switch or router would
most likely have no idea the services that are available on a NIC
connected to a port, other than mac/IP depending on its status.
Similar ThreadsPosted
How to detect interface? February 27, 2008, 9:21 am
How to detect availability July 5, 2005, 1:11 pm
Detect Incorrect Checksum July 27, 2006, 12:17 pm
Prevent\Detect Dual Homing August 21, 2006, 3:28 am
Reset VOIP Call (no media detect) October 18, 2005, 10:03 pm
Using snmp traps to detect broadcast storms March 20, 2008, 12:00 pm
Some wireless clients cannot detect my unbroadcast Aironet AP July 3, 2008, 11:21 pm
How to convert a fast ethernet interface in a Cisco Router to behave like a serial interface March 18, 2006, 8:48 am
need to lookup master interface that inherit IP address to unnumbered interface via SNMP October 30, 2007, 8:30 am
Will replacing Interface card / NM also copy interface configuration? October 23, 2006, 11:29 am
Inside interface VPN to outside interface. loop-back? August 26, 2007, 12:39 am
ASA management interface as fover interface? June 4, 2007, 4:05 pm
PIX 506E Routing from Inside Interface network To outside interface network August 4, 2005, 3:48 pm
Setting up a router with 29 Global IPs, BUT can't ping router internal interface from server or server interface from router December 11, 2005, 10:37 am
PIX outside interface July 19, 2005, 11:03 am
