Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Daniel-G on May 10, 2008, 7:07 pm
Please log in for more thread options I need some hint I have 2 C26xx running IOS 12.1 with several interfaces which I want to setup in a failover configuration with HSRP The idea is to switch to the backup router if any of the interfaces goes down On main router : interface f0/0 ip address 10.0.0.2 255.255.255.0 standby 1 ip 10.0.0.1 standby 1 preempt standby track f0/1 interface f0/1 ip address 172.16.0.2 255.255.255.0 standby 2 ip 172.16.0.1 standby 2 preempt standby track f0/0 I need some hints because I can't model the configurations Thanks in advance | |||||||||||||
Posted by Trendkill on May 11, 2008, 7:40 am
Please log in for more thread options I would also recommend setting a priority on both sides, either to ensure your traffic is being equally shared between core routers, or B because you want one link preferred downstream (presuming all paths are equal). Higher priority wins in this case, opposite of say spantree priorities on vlans. | |||||||||||||
Posted by Merv on May 11, 2008, 9:04 am
Please log in for more thread options > On May 10, 7:07 pm, Daniel-G <free-news_no-replyATcasylde.fr> wrote:
> > > > > Hello,
> > I need some hint > > I have 2 C26xx running IOS 12.1 with several interfaces which I want to > > setup in a failover configuration with HSRP >
> > down and do you want to stay on the backup router and move back manually ??? ponder what happens for example if you have a flapping Fast Ethernet interface on the main router | |||||||||||||
Posted by Daniel-G on May 11, 2008, 11:14 am
>> >> >> >>> Hello,
>>> I need some hint >>> I have 2 C26xx running IOS 12.1 with several interfaces which I want to >>> setup in a failover configuration with HSRP >>> The idea is to switch to the backup router if any of the interfaces goes >>> down >
Actually that's an excellent hint. I didn't think of it.
> > and do you want to stay on the backup router and move back > manually ??? > > ponder what happens for example if you have a flapping Fast Ethernet > interface on the main router > I have no idea on how to make it. Maybe removing the preempt command on the emain router would be enough but, then I have to be careful when starting the routers. Or maybe I can set the preempt command, just when I want to revert back to the main router. | |||||||||||||
Posted by Merv on May 11, 2008, 12:05 pm
Please log in for more thread options On May 11, 11:14 am, Daniel-G <free-news_no-replyATcasylde.fr> wrote:
> Merv a =E9crit : > > >> On May 10, 7:07 pm, Daniel-G <free-news_no-replyATcasylde.fr> wrote:
> >>> Hello,
o
> >>> I need some hint > >>> I have 2 C26xx running IOS 12.1 with several interfaces which I want t= > >>> setup in a failover configuration with HSRP
es
> >>> The idea is to switch to the backup router if any of the interfaces go= > >>> down
> > manually ??? >
> Actually that's an excellent hint. I didn't think of it. > I have no idea on how to make it. > Maybe removing the preempt command on the emain router would be enough > but, then I have to be careful when starting the routers. > Or maybe I can set the preempt command, just when I want to revert back > to the main router. Usually the HSRP tracking feature is used to track the state of WAN interfaces. Is this how you were intending to use it or are you trying to track LAN interfaces. If the later I would discourage you from doing so as you will unnecessarily complicate your operating environment. Perhaps you can share a little more info about both router , i.e the WAN side of things to assist folks in responding to your query. | |||||||||||||
HSRP monitor several interfaces switching to standby on failure of any active interface
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Hello,
> I need some hint
> down
> On main router :
> interface f0/0
> standby 1 preempt
> standby track f0/1
> interface f0/1
> standby 2 preempt
> standby track f0/0
> Thanks in advance
