Cisco Systems GRE Tunnel - one way ?
Subject Author Date
GRE Tunnel - one way ? kartik 09-30-05
Posted by kartik on September 30, 2005, 6:39 am
Hello all,
Does GRE work on unidirectional links ?
I need to configure a GRE tunnel over a one-way link .. from Router A
to Router B. (There is no return path from router B to Router A). If I
configure a GRE tunnel the regular way will it work ?
Thanks,
-kartik
Posted by Walter Roberson on September 30, 2005, 10:55 am
:Does GRE work on unidirectional links ?
:I need to configure a GRE tunnel over a one-way link .. from Router A
:to Router B. (There is no return path from router B to Router A). If I
:configure a GRE tunnel the regular way will it work ?
Perhaps you could leave off the 'tunnel source' on router B,
or perhaps you could use a "source" which was the NULL interface,
or a loopback interface that nothing was going into.
When you say there is no return path, do you mean that no packets
at all can get back, or do you mean that no *data* is intended to
flow? Looking briefly through the documentation, it looks to me
that a simple GRE tunnel without keepalives might work without
any back-packets at all. I suspect that if you introduced
encryption onto the tunnel that the encryption might perhaps need
communications back, but that's something that would need to be checked.
"It is important to remember that when it comes to law, computers
never make copies, only human beings make copies. Computers are given
commands, not permission. Only people can be given permission."
-- Brad Templeton
Posted by kartik on September 30, 2005, 12:09 pm
Thank you for your response. I think I am very close ... but ...
I tried but without a "tunnel source" the tunnel interface on Router B
does not come up. Here is a snippet of my configuration on Routers A
and B ..
I can tell from the Router A serial interface stats connected to the
one-way link that my multicast packets are getting tunnelled and are
going through to the one way link....
Router B is receiving it on its serial link but the packets as
evidenced by the serial interface statistics. However it never get
de-capsulated and forwarded on the LAN of ROuter B.
ROUTER A
interface Tunnel0
ip unnumbered FastEthernet0/0.1
ip pim dense-mode
ip igmp join-group 239.232.1.20
tunnel source FastEthernet0/0.1
tunnel destination 192.168.10.15
interface FastEthernet0/0.1
description Vlan1 Video and Data
encapsulation dot1Q 1 native
ip address 10.7.10.1 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim dense-mode
interface Serial1/0
description One Way Out ONLY Link
bandwidth 384
ip address 1.1.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route 192.168.10.15 255.255.255.255 Serial1/0
ROUTER B
interface Loopback0
ip address 6.6.6.6 255.255.255.0
ip pim dense-mode
interface Tunnel0
no ip address
ip pim dense-mode
tunnel destination 6.6.6.6
description $ETH-LAN$
ip address 192.168.10.15 255.255.255.0
ip pim dense-mode
ip mroute 0.0.0.0 0.0.0.0 Tunnel0
Thank you
-Kartik
Posted by Walter Roberson on September 30, 2005, 2:05 pm
:I tried but without a "tunnel source" the tunnel interface on Router B
:does not come up. Here is a snippet of my configuration on Routers A
:and B ..
I have done little GRE myself, so I'm probably off-base, but...
:ROUTER A
Leave as is. The tunnel traffic exits the router via a serial interface.
:ROUTER B
>interface Loopback0
> ip pim dense-mode
Hmmmm... not sure that's right.
>interface Tunnel0
> no ip address
> ip pim dense-mode
It seems to me that the tunnel destination might need to be
the 10.7.10.1 of Router A's FE interface, which you are borrowing
for the tunnel via the "ip unnumbered" statement. If the tunnel
destination does not match the other sender, then the router isn't
going to know -which- GRE tunnel it is dealing with (since there
might be several.)
> ip pim dense-mode
You don't have a Serial interface shown to receive the data.
If you don't want any packets going back, you shouldn't be routing
them to the Tunnel0.
To prevent traffic from going back along the tunnel, put in an
access list and apply it "out" Tunnel0 on Router B.
These .signatures are sold by volume, and not by weight.
Posted by kartik on October 1, 2005, 5:58 am
Thank you ! I have this working now.
You are right, the
1. tunnel destination interface on router B needs to match the Tunnel
Source interface on Router A.
2. The tunnel source interface on router A needs to match the tunnel
destination interface on Router B
Since i do not have a return path from Router B to Router A I tricked
router B by configuring a loopback interface with the same IP address
as the tunnel A source interface. Then I configured tunnel source and
tunnel destination IPs as per the rules above.
Thank you very much for you help.
-Kartik
Similar ThreadsPosted
GRE Tunnel up/up Cannot ping tunnel interface March 6, 2006, 3:55 pm
VPN tunnel July 25, 2005, 8:10 pm
GRE Tunnel - one way ? September 30, 2005, 6:39 am
Best MTU value for our VPN tunnel October 11, 2005, 10:39 pm
NAT-T + VPN Tunnel November 6, 2005, 4:06 am
515 & 501 VPN Tunnel Help April 4, 2006, 12:47 pm
GRE Tunnel November 21, 2005, 8:38 pm
PLEASE HELP - GRE tunnel September 5, 2006, 7:43 pm
NAT w Tunnel January 25, 2007, 9:06 am
GRE tunnel and NAT May 20, 2008, 10:52 pm
syslog through tunnel February 11, 2005, 9:55 am
Help With 1710 to Pix 501 VPN Tunnel July 24, 2005, 8:51 pm
tunnel interface ip September 14, 2005, 1:37 pm
PIX 7.0.4 tunnel all traffic. November 3, 2005, 12:27 pm
routing vpn tunnel December 22, 2005, 10:53 am
