Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on April 23, 2008, 12:14 pm
Please log in for more thread options that I was having problems with was balancing the traffic across two T1s attached to two Cisco 3845s. We have HSRP for redundancy, but on a suggestion from this group, I am pursuing configuring GLBP instead of HSRP. However, now, I am wondering if I should setup GLBP on both sides of the routers, i.e. both into the MPLS cloud to which all branches are attached and into the LAN. Below are the two setups that I am considering (best viewed in fixed-width font). I am using EIGRP for routing traffic across the MPLS cloud. My question is this, how will EIGRP broadcast the route back to these two routers to our branch offices? If I setup GLBP on both sides of the two routers, will I be balancing traffic more efficiently than EIGRP can do on the MPLS links? Thanks. ||==========||----------HOSTRTR01-----\ <branches>-|| MPLS || GLBP-------LAN
||==========||----------HOSTRTR02-----/
||==========|| /-----HOSTRTR01-----\ <branches>-|| MPLS ||-GLBP GLBP-------LAN
||==========|| \-----HOSTRTR02-----/
Posted by Russianj on April 29, 2008, 6:20 pm
Please log in for more thread options would be most appreciative. Thanks. On Apr 23, 11:14 am, russi...@gmail.com wrote: > I posted a couple of weeks ago about EIGRP over MPLS. The scenario
> that I was having problems with was balancing the traffic across two > T1s attached to two Cisco 3845s. We have HSRP for redundancy, but on a > suggestion from this group, I am pursuing configuringGLBPinstead of > HSRP. However, now, I am wondering if I should setupGLBPon both > sides of the routers, i.e. both into the MPLS cloud to which all > branches are attached and into the LAN. Below are the two setups that > I am considering (best viewed in fixed-width font). I am using EIGRP > for routing traffic across the MPLS cloud. My question is this, how > will EIGRP broadcast the route back to these two routers to our branch > offices? If I setupGLBPon both sides of the two routers, will I be > balancing traffic more efficiently than EIGRP can do on the MPLS > links? Thanks. > > ||==========||----------HOSTRTR01-----\ > <branches>-|| MPLS || GLBP-------LAN > ||==========||----------HOSTRTR02-----/ > > ||==========|| /-----HOSTRTR01-----\ > <branches>-|| MPLS ||-GLBP GLBP-------LAN > ||==========|| \-----HOSTRTR02-----/ | ||||||||||||||||
| Similar Threads | Posted |
| GLBP EIGRP Scenario | April 23, 2008, 12:14 pm |
| Scenario 6: Multi Area EIGRP routing on Multipoint and Point-to-Point Frame Relay. | June 11, 2006, 1:26 am |
| glbp and ip nat | October 19, 2006, 7:37 am |
| HSRP and GLBP | February 9, 2006, 2:56 am |
| GLBP for our WAN HA solution | August 14, 2007, 5:50 am |
| GLBP traffic filtering | May 18, 2006, 5:10 pm |
| OSPF with HSRP or GLBP | June 7, 2007, 4:10 am |
| How is "pri" calculated automatically by GLBP ? | July 1, 2008, 1:23 am |
| HSRP Scenario | July 19, 2005, 6:32 am |
| PIX 6.2 failover scenario | December 13, 2006, 3:59 pm |
| config scenario for VLANs | June 21, 2005, 4:32 pm |
| Multicast in hsrp scenario | March 28, 2007, 2:24 pm |
| spanning-tree gateway load balancing (STP & GLBP) | March 12, 2007, 9:46 pm |
| Quick scenario on PIX (initiatior, responder only) | February 6, 2006, 10:55 am |
| Scenario 4: Multi Areas OSPF | May 29, 2006, 9:20 am |
GLBP EIGRP Scenario
Yahoo!
Windows Live
del.icio.us
digg
Netscape
