Cisco Systems FIN Timeout
Subject Author Date
FIN Timeout kevin 08-26-05
Posted by on August 26, 2005, 1:18 pm
Hi
I have a problem with Cisco Firewall Pix 515E.
I setup a FTP service on DMZ zone on Windows 2003 Server.
Client can connect to the Ftp service from the Internet, but when he is
working on Passive mode client is being disconnected after about 1
minute of inactive.
On IIS inactive time is set to 3600 seconds and when I connect from
internal site everything is fine- so I think it's a firewall problem.
In firewall log I have this:
Built inbound TCP connection 915578 for outside:xx.xx.xx.xx/50601
(xx.xx.xx.xx/50601) to dmz:10.10.10.20/5512 (10.10.10.20/5512)
Teardown TCP connection 915578 for outside:xx.xx.xx.xx/50601 to
dmz:10.10.10.20/5512 duration 0:00:01 bytes 20867 TCP FINs
Teardown TCP connection 914797 for outside:xx.xx.xx.xx/50765 to
dmz:10.10.10.20/21 duration 0:37:20 bytes 686 FIN Timeout
Do I have something wrong with configuration.
Thank you for help
Kevin
Posted by Private on August 26, 2005, 6:43 pm
kevin@allgraniteandmarble.com wrote:
> Hi
> minute of inactive.
> Thank you for help
> Kevin
Can you mask your real IP addresses in the configuration and post it so
that we can look. The "Fin Timeout is a normal function if there is no
ACK received (FIN Timeout Force termination after 15 seconds await for
last ACK ). Are you using FTP fixup? and what version are you using.
Posted by on August 27, 2005, 4:22 am
That's my config:
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
hostname pixfirewall
domain-name test.local
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol tftp 69
names
access-list dmz-zone permit tcp any host 10.10.10.20 eq www
access-list dmz-zone permit tcp any host 10.10.10.20 eq ftp
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside 192.168.100.2 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
ip address dmz 10.10.10.10 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 192.168.100.11-192.168.100.50
global (outside) 1 192.168.100.10
global (dmz) 1 10.10.10.50
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (dmz,inside) tcp 10.10.10.20 www netmask 255.255.255.255 0 0
static (dmz,outside) 10.10.10.20 10.10.10.20 netmask 255.255.255.255 0
0
static (inside,outside) 192.168.1.100 192.168.1.100 netmask
255.255.255.255 0 0
access-group dmz-zone in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.100.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 1:00:00 rpc 0:10:00 h225
1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 1:00:00 absolute uauth 1:00:00 inactivity
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 60
ssh timeout 5
console timeout 0
terminal width 80
Ftp service is on standard port 21- active works fine but passive is
being disconnected after 1 minute. I setup passive ftp to work on ports
5500-5700.
Do I have to setup those ports in configuration?
Thank you
Posted by Private on August 27, 2005, 7:22 pm
> That's my config:
> PIX Version 6.3(3)
> names
> pager lines 24
> mtu outside 1500
> mtu inside 1500
> mtu dmz 1500
> pdm history enable
> arp timeout 14400
> 0
> 255.255.255.255 0 0
> 1:00:00
> floodguard enable
> telnet timeout 60
> ssh timeout 5
> console timeout 0
> terminal width 80
> 5500-5700.
> Thank you
I am thinking that the Fixup protocol for Ftp might be causing the
issue. If you can try to either disable the fixup for this or add the
ports to the fixup for FTP.
Similar ThreadsPosted
FIN Timeout August 26, 2005, 1:18 pm
VPN Timeout October 18, 2005, 1:57 pm
NAT timeout June 6, 2006, 3:01 pm
Cisco SDM timeout April 19, 2007, 2:09 pm
timeout xlate BCP August 30, 2007, 11:28 am
FWSM - SAP timeout ? April 7, 2008, 3:26 pm
tftp timeout June 5, 2009, 9:58 pm
exec-timeout on line November 29, 2005, 11:44 am
re:LOCK OBTAIN TIMEOUT January 14, 2006, 10:15 pm
question about timeout conn April 21, 2006, 11:50 am
question about timeout conn April 21, 2006, 11:55 am
Ike phase 1 rekey & timeout March 18, 2008, 2:51 pm
AS5800 and Idle-Timeout Issue December 1, 2005, 3:21 pm
120 sec. request timeout in acns 3.1 (proxy) November 3, 2006, 6:02 am
Dialer Idle Timeout Not Working June 16, 2007, 12:06 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
