Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Phil Schuman on August 22, 2006, 4:20 pm
Please log in for more thread options Some VoIP vendors indicate they have not seen any probs over their network, while some integrators have said flat out it doesn't work reliably... SO - what's been your experience with normal FAX machines that work fine on a POTS/PSTN network... plugging them into an analog port on a VoIP gateway, and used across the VoIP LAN / WAN configuration ? here - http://www.soft-switch.org/foip.html this is better - http://www.cantata.com/applications/fax/faxoverip/index.cfm tnx for the feedback | |||||||||||||
Posted by James on August 23, 2006, 4:26 am
Please log in for more thread options 90 site Satellite WAN (580 ms RTT) for over 3 years - they work perfectly. The Softswitch article is complete garbage - the guy who wrote that is clueless. Cisco Routers support T.38 and their own proprietary Fax protocol. Both work with no problems. You can run 8k G.729 and run fax over it using the command "fax rate voice" on your dial-peers. Cisco command reference:- If you require fast fax transmission then with a well deisgned dial plan, you can create sperate dial-peers for Fax calls using a 64k codec and have your voice calls use an 8k Codec. Check out the Cisco fax troubleshooting guide for more information on Cisco's Fax over VoIP implementation:- http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/prod_troubleshooting_guide_chapter09186a0080558500.html James Phil Schuman wrote: > Ok... just discovered the 2-sided discussion on Fax over IP.
> Some VoIP vendors indicate they have not seen any probs over their > network, > while some integrators have said flat out it doesn't work reliably... > > SO - what's been your experience with normal FAX machines > that work fine on a POTS/PSTN network... > plugging them into an analog port on a VoIP gateway, > and used across the VoIP LAN / WAN configuration ? > here - > http://www.soft-switch.org/foip.html > this is better - > http://www.cantata.com/applications/fax/faxoverip/index.cfm > > tnx for the feedback | |||||||||||||
| Similar Threads | Posted |
| Voip Updated Howto,Voip ATT Home (October Update) | October 29, 2006, 9:00 am |
| Voip Updated Howto,Voip AT Home | June 28, 2006, 9:02 pm |
| VOIP | June 21, 2006, 2:18 pm |
| Allow VOIP through PIX 501 | July 10, 2006, 3:54 am |
| FAX + VoIP - T.30 / T.38 | August 22, 2006, 4:20 pm |
| VoIP over VPN | August 28, 2006, 4:16 am |
| Voip and QoS | August 28, 2007, 4:54 am |
| VOIP and QOS | October 1, 2007, 2:31 pm |
| voip over adsl? | August 27, 2005, 2:09 am |
| QoS for SAN and VoIP traffic | November 24, 2005, 1:24 am |
| VoIP (SIP) though an Soho91 | October 18, 2005, 4:39 pm |
| Help with VOIP on Cisco 831 | November 14, 2005, 10:44 am |
| voip issue | March 1, 2006, 12:38 am |
| Setting up QOS on 831 for VoIP | April 9, 2006, 12:00 am |
| VOIP delay | April 27, 2006, 3:40 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
For >example, if the voice codec is G.711, fax transmission may occur up to
14,400 bps >because 14,400 bps is less than the 64-k voice rate. If the voice
codec is G.729 (8k), >the fax transmission speed will be 7200 bps.
