Cisco Systems Does routers 1800 series (example 1827) enough for practicing CCIE
Subject Author Date
Does routers 1800 series (example 1827) enough for practicing CCIE cisco_crazy 07-01-09
Posted by cisco_crazy on July 1, 2009, 3:45 am
hi all,
i am wondering if i buy routers 1800 series would them support all i
need in routing for CCIE exam.
Thanx,,,,,,,,,,
Posted by flamer die.spam@hotmail.com on July 1, 2009, 11:19 pm
> hi all,
> Thanx,,,,,,,,,,
most labs are built with 2600's and 7200's.. so 1800 should cover you
pretty well. I would recommend getting the latest copy of a practise
exam and just see what they ask and see if it will support it all
before you go and spend $$$.
Flamer.
Posted by cisco_crazy on July 2, 2009, 8:35 am
On 2 =D9=8A=D9=88=D9=84=D9=8A=D9=88, 06:19, "flamer die.s...@hotmail.com"
> > hi all,
> > Thanx,,,,,,,,,,
> Flamer.
thanx,,,,,,,,,
Posted by Doug McIntyre on July 2, 2009, 4:36 pm
I think the 1800 is a good buy for that. Its modern, supports tons of
RAM and Flash for running the latest images, and supports a pretty
good set of cards (even some of the older ones that aren't supported).
It won't get you all the way for a CCIE VOICE, but by that time,
you'll probably be renting test rackspace for that since the gear is
pretty expensive to buy.
If you are doing CCIE R & S, you'll need at least 3-4 routers, but you
can use dynamips for the others. Having hands on experience with at
least one router is very good experience.
Similar ThreadsPosted
Does routers 1800 series (example 1827) enough for practicing CCIE July 1, 2009, 3:45 am
Limiting bandwidth per user on the 1800 Series October 3, 2007, 2:43 pm
CPU of new 800, 1800 & 2800 routers? January 6, 2006, 9:27 am
Interfaces on 1800 routers April 22, 2007, 6:19 am
Connect Windows XP VPN Client to Cisco 1800 series April 18, 2006, 2:47 pm
how to open a port on a Cisco 1800 series router February 19, 2008, 9:02 am
Monitoring network traffic on Cisco 1800 series November 18, 2008, 2:44 am
Using Cisco 1800 Series Integrated Modem for Dial-in Access March 17, 2008, 10:57 am
VPN Problems on Cisco 800 Series Routers June 5, 2006, 7:42 pm
Will this IOS work on all 25xx series routers? August 21, 2006, 11:42 am
Anyone clustering ASA5000-series boxes with 3000-series VPN concentrators October 27, 2006, 10:45 am
New CCIE Lab January 18, 2006, 2:31 pm
CCIE July 19, 2006, 8:54 am
CCIE July 18, 2007, 5:11 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
