Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Lovejoy on May 1, 2007, 1:12 pm
Please log in for more thread options etherchannel using the gbics on the supervisors. The uplink is currently 100 Mb, and I want to upgrade it to a gig. I need to disable the etherchannel so I can use the gbic as a gig uplink to the network. Here is a snippet of the config : Sw1 - #frame distribution method set port channel all distribution mac both ! #port channel set port channel 1/1-2 183 ! #module 1 : 2-port 1000BaseX Supervisor set port trap 1/1-2 enable set spantree portfast 1/1-2 disable set spantree guard none 1/1-2 set port channel 1/1-2 mode desirable silent sw2 - #frame distribution method set port channel all distribution mac both ! #port channel set port channel 1/1-2 125 ! #module 1 : 2-port 1000BaseX Supervisor set port trap 1/1-2 enable set spantree portfast 1/1-2 disable set spantree guard none 1/1-2 set port channel 1/1-2 mode desirable silent Is it as simple as : set port channel all mode off set port trap 1/1-2 disable set port channel 1/1-2 mode off ... on both to disable? And then just configure a normal link between the sups? TIA Lovejoy -- =========================================================== This space for lease.... | |||||||||||||||||||
Posted by Trendkill on May 1, 2007, 1:14 pm
Please log in for more thread options set port channel <mod/ports> disable
Posted by Trendkill on May 1, 2007, 1:16 pm
Please log in for more thread options >
> > > > I inherited 2 4006's running CaOS, that are linked together via an
> > etherchannel using the gbics on the supervisors. The uplink is > > currently 100 Mb, and I want to upgrade it to a gig. I need to disable > > the etherchannel so I can use the gbic as a gig uplink to the network. > > Here is a snippet of the config : >
> > Sw1 -
> > set port channel all distribution mac both > > ! > > #port channel > > set port channel 1/1-2 183 > > ! > > #module 1 : 2-port 1000BaseX Supervisor > > set port trap 1/1-2 enable > > set spantree portfast 1/1-2 disable > > set spantree guard none 1/1-2 > > set port channel 1/1-2 mode desirable silent >
> > sw2 -
> > set port channel all distribution mac both > > ! > > #port channel > > set port channel 1/1-2 125 > > ! > > #module 1 : 2-port 1000BaseX Supervisor > > set port trap 1/1-2 enable > > set spantree portfast 1/1-2 disable > > set spantree guard none 1/1-2 > > set port channel 1/1-2 mode desirable silent >
> > set port trap 1/1-2 disable > > set port channel 1/1-2 mode off >
> > the sups? >
> > TIA
> > Lovejoy >
> > =========================================================== > > This space for lease.... >
> set port channel <mod/ports> disable I stand corrected, yes, mode off will do. You don't want to do all unless you have no other channels configured. Provided the trunks or connections are the same already, you don't need to configure a normal link, it should just go back to standalone intra-connections. | |||||||||||||||||||
Posted by Lovejoy on May 1, 2007, 1:35 pm
> > > etherchannel using the gbics on the supervisors. The uplink is > > > currently 100 Mb, and I want to upgrade it to a gig. I need to disable > > > the etherchannel so I can use the gbic as a gig uplink to the network. > > > Here is a snippet of the config : > >
> > > Sw1 -
> > > set port channel all distribution mac both > > > ! > > > #port channel > > > set port channel 1/1-2 183 > > > ! > > > #module 1 : 2-port 1000BaseX Supervisor > > > set port trap 1/1-2 enable > > > set spantree portfast 1/1-2 disable > > > set spantree guard none 1/1-2 > > > set port channel 1/1-2 mode desirable silent > >
> > > sw2 -
> > > set port channel all distribution mac both > > > ! > > > #port channel > > > set port channel 1/1-2 125 > > > ! > > > #module 1 : 2-port 1000BaseX Supervisor > > > set port trap 1/1-2 enable > > > set spantree portfast 1/1-2 disable > > > set spantree guard none 1/1-2 > > > set port channel 1/1-2 mode desirable silent > >
> > > set port trap 1/1-2 disable > > > set port channel 1/1-2 mode off > >
> > > the sups? > >
> > > TIA
> > > Lovejoy > >
> > > =========================================================== > > > This space for lease.... > >
> > set port channel <mod/ports> disable >
> I stand corrected, yes, mode off will do. You don't want to do all > unless you have no other channels configured. Provided the trunks or > connections are the same already, you don't need to configure a normal > link, it should just go back to standalone intra-connections. Thanks. Lovejoy >
| Similar Threads | Posted |
| Disabling an Etherchannel | May 1, 2007, 1:12 pm |
| Disabling CSA | March 8, 2006, 6:43 am |
| Disabling mls | July 3, 2008, 4:12 pm |
| disabling modem on 836? | July 8, 2005, 1:19 am |
| Disabling Telnet | February 28, 2008, 2:28 pm |
| Disabling CiscoWorks Syslog | November 20, 2006, 3:46 am |
| Disabling IPX on Cisco 2600 Router | February 9, 2007, 2:04 pm |
| Enabling/disabling port Catalyst 4006. | July 6, 2006, 4:38 am |
| Etherchannel vs. STP - what do you think? | September 18, 2005, 1:40 pm |
| EtherChannel | March 29, 2006, 12:18 am |
| L2 vs L3 Etherchannel? | April 13, 2006, 10:44 pm |
| Configuring Etherchannel | October 18, 2005, 12:55 pm |
| EtherChannel and Sun/Solaris | December 14, 2005, 9:52 pm |
| Etherchannel problem | April 27, 2006, 1:56 pm |
| etherchannel problem | July 26, 2006, 9:38 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Sw1 -
> #port channel
> sw2 -
> #port channel
> the sups?
> TIA
> Lovejoy
