Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Bjarke Andersen on November 20, 2006, 3:46 am
Please log in for more thread options (LMS2.5)? Disable the service through Windows services or can it be disabled in the CiscoWorks configuration? -- Bjarke Andersen Wanna reply by email? Remove the spammer in address | |||||||||||||||||||
Posted by Martin Bilgrav on November 20, 2006, 4:28 pm
Please log in for more thread options Hi I think disable in Service Manager is the way, but if I recall correct, the syslog service are used internally by CW aswell. I wouldnt recommend disable syslog service - Why do you wanna do that ? HTH Martin | |||||||||||||||||||
Posted by Bjarke Andersen on November 20, 2006, 4:41 pm
> correct, the syslog service are used internally by CW aswell. > I wouldnt recommend disable syslog service - Why do you wanna do that > ? We wanna run third-party syslog service off the same machine. -- Bjarke Andersen Wanna reply by email? Remove the spammer in address | |||||||||||||||||||
| Similar Threads | Posted |
| Disabling CiscoWorks Syslog | November 20, 2006, 3:46 am |
| Syslog and CiscoWorks | December 26, 2006, 1:46 am |
| Ciscoworks syslog real-time viewer | November 22, 2006, 1:55 am |
| Disabling CSA | March 8, 2006, 6:43 am |
| Disabling mls | July 3, 2008, 4:12 pm |
| disabling modem on 836? | July 8, 2005, 1:19 am |
| Disabling an Etherchannel | May 1, 2007, 1:12 pm |
| Disabling Telnet | February 28, 2008, 2:28 pm |
| Disabling IPX on Cisco 2600 Router | February 9, 2007, 2:04 pm |
| Enabling/disabling port Catalyst 4006. | July 6, 2006, 4:38 am |
| Ciscoworks LMS 2.5 | December 1, 2005, 9:02 am |
| CiscoWorks 2000 | February 13, 2005, 9:19 pm |
| CiscoWorks and CiscoSecure ACS | January 24, 2006, 2:33 am |
| whatsupgold and ciscoworks is it possible on same pc?? | January 25, 2006, 5:48 am |
| Ciscoworks problem | January 27, 2006, 12:04 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
