Cisco Systems Difference between WICs and VWICs
Subject Author Date
Difference between WICs and VWICs ttripp@magnoliamanor.com 07-06-06
Posted by ttripp@magnoliamanor.com on July 6, 2006, 3:51 pm
Actually, I know what some of the differences are, but here's what I'd
really like to know: does running VoIP require using VWICs, or can you
use WICs? I'm talking about VoIP over T1s, and if routers equiped with
WICs can do LLQ and other kinds of QoS needed for voice traffic, or if
only VWICs have that capability. Thanks.
Posted by stephen on July 6, 2006, 5:20 pm
you only need a VWIC if you want TDM voice down the trunk, or some other
sort of channelised interface (we use E1 VWICs @ work for 2 Mbps lines with
1 64k channel reserved for status signalling).
The router queue management on the 38xx and down is done in software - it
doesnt need any specific hardware assistance from the interface, so AFAIK it
work with any of them.
WICs are generally the normal way to connect to subrate T1 / E1
connections - and there is nothing special about using all the possible
bandwidth on the circuit.
Regards
stephen_hope@xyzworld.com - replace xyz with ntl
Posted by ttripp@magnoliamanor.com on July 7, 2006, 9:56 am
That's what I was thinking, but wasn't entirely sure. Thanks for
clearing it up for me.
> Regards
Similar ThreadsPosted
Difference between WICs and VWICs July 6, 2006, 3:51 pm
E1 and BRI VWICs on same router?? December 9, 2005, 6:28 pm
Please help edumacate me on T1 WICs June 14, 2006, 9:56 am
2621 two wics adsl July 18, 2005, 11:19 am
No difference between ....T and .....T3? February 22, 2006, 10:33 am
Difference between PIX and ASA May 29, 2006, 5:07 am
Difference in setting up ATM 0 or ATM 0.1 February 8, 2005, 8:32 pm
Difference between PIX 501 and 800 series July 9, 2005, 7:26 pm
Difference between SDM and SDM Express July 18, 2007, 9:07 am
Difference between 4500 and 4900. August 21, 2006, 1:08 pm
routed port and SVI difference March 30, 2007, 4:51 am
Difference - SUP2 vs. SUP32 April 20, 2007, 1:54 am
difference between 3750 and 3750E July 11, 2007, 1:24 pm
ASA IOS versions? Difference in Trains? August 7, 2007, 1:25 pm
What is the difference between these two Cisco WAN Cards October 31, 2007, 11:33 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
