Cisco Systems Difference between PIX and ASA
Subject Author Date
Difference between PIX and ASA Christoph Hanle 05-29-06
Posted by Christoph Hanle on May 29, 2006, 5:07 am
can someone explain me the differnces between a PIX and an ASA, especial
a PIX 515E/R and an ASA 5510 plus.
I understand, that the ASA has the full functionality of a PIX plus
SSL-Gateway and the option of installing SSMs.
I have the problem to combine and expand our PIX based network with a
watchguard and soho-router based network. In the first step i will
replace the 2port Watchguard on the other mainoffice with a PIX or ASA
with minimal 3 NICs to implement among other things a DMZ, site-to-site
VPN and the possibility for the use of the Cisco VPN-Client.
If I understand the description of the ASA, I can solve it with the ASA
in the same way as with a PIX and the implementation and funktion of the
PIX OS 7.1x should be the same on both machines for this need. Is this
correct, or can i run into trouble ?
If i see the pricedifference between a PIX and an ASA, i would prefer an
ASA ( i have a not verified offer where the ASA5510 plus is cheaper than
a PIX 515E/R, and on the ASA i have 5 ports)
hope someone can give me more information
bye
Christoph
Posted by www.BradReese.Com on June 1, 2006, 1:49 pm
Hi Christoph,
The Cisco Pix is considered old technology, and though it has not been
end-of-life'd, it is not actively being pushed as their recommended
solution.
This is because today organizations are faced by what are called
blended threats that can only be addressed with multi-functional type
technology provided by the ASA series solution.
You will also find that a PIX cost MORE than the better ASA technology
solution - this is an incentive to move toward ASA.
The user can enable or disable what technology they do not want to use
- though they should use them all.
Andrew R. Reese, Security Expert
http://www.bradreese.com/andrew-r-reese.htm
Hope this helps.
Sincerely,
Brad Reese
BradReese.Com - Cisco Network Engineer Directory
http://www.bradreese.com/network-engineer-directory.htm
1293 Hendersonville Road, Suite 17
Asheville, North Carolina USA 28803
USA & Canada: 877-549-2680
International: 828-277-7272
Fax: 775-254-3558
AIM: R2MGrant
Website: http://www.bradreese.com/contact-us.htm
Similar ThreadsPosted
No difference between ....T and .....T3? February 22, 2006, 10:33 am
Difference between PIX and ASA May 29, 2006, 5:07 am
Difference in setting up ATM 0 or ATM 0.1 February 8, 2005, 8:32 pm
Difference between PIX 501 and 800 series July 9, 2005, 7:26 pm
Difference between SDM and SDM Express July 18, 2007, 9:07 am
Difference between WICs and VWICs July 6, 2006, 3:51 pm
Difference between 4500 and 4900. August 21, 2006, 1:08 pm
routed port and SVI difference March 30, 2007, 4:51 am
Difference - SUP2 vs. SUP32 April 20, 2007, 1:54 am
difference between 3750 and 3750E July 11, 2007, 1:24 pm
ASA IOS versions? Difference in Trains? August 7, 2007, 1:25 pm
What is the difference between these two Cisco WAN Cards October 31, 2007, 11:33 pm
What is the difference between a T1and an ISDN PRI May 8, 2008, 9:45 pm
Difference between 4.1.7 and 4.7.2 - Cisco VPN 3005 April 15, 2009, 11:34 pm
Difference Between Collision and Broadcast Domain. September 21, 2005, 12:52 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
