Cisco Systems Detect Incorrect Checksum
Subject Author Date
Detect Incorrect Checksum Rahan 07-27-06
Posted by Rahan on July 27, 2006, 12:17 pm
Hi all,
I have some hosts (windows and Solaris) connected to Cisco Switch 2950.
When i capture traffic with sniffer, i can see a problem of incorrect
checksum in packet and i know why (i disabled offload in my network card and
all work fine).
But when i have checksum error, i don't see anything in the switche. (no
input, no output, no crc... no errors) !!!
How can i detecte checksum error whitout sniffing directly in the hosts ??
ThankYou very much
Best Regards
Rahan
Posted by Walter Roberson on July 27, 2006, 12:37 pm
>all work fine).
When you have checksums offloaded to your network card, then a
sniffer on the host sniffs the packets -before- they go to the network
card, and so sniffs the unadjusted checksums. The network card then
fixes the checksums and sends out the corrected packet.
I'm not sure from your posting whether you did not know that, or if
you have reason to believe there are checksum errors -after- the
NIC rewrites the checksum (e.g., somewhere in transit between the
NIC and the receiving end) ?
Posted by Rahan on July 27, 2006, 1:01 pm
and
> >all work fine).
Thank You for your answer.
if what you said is true, so, i will find all packets with checksum error !!
it's not in my case !
i have only some packets with checksum error, not all.
And when i disabled offloading in my NIC, i don't have checksum error.
And when i disabled offloading in my NIC, i don't have network problem
(disconnexion client, lost data... etc)
Best Regards
Rahan
Posted by Walter Roberson on July 27, 2006, 2:01 pm
When checksums are offloaded to the driver, then for any particular
protocol, the checksum field stored in the packet (the one that is
sniffed) will be either a constant or whatever trash happens to be
handy. Either way, by chance sometimes that is going to be the
correct checksum: in order for the value to *never* be right,
the drivers would have to calculate the checksum and then deliberately
put in something it knew to be wrong.
Another thing you might observe is that different protocols involve
different numbers of checksums. With checksum downloading turned on,
there may be a pattern of incorrect checksums -- e.g., it might happen
for all TCP packets but not for other packets.
It sounds like the easiest solution is to leave checksum downloading
disabled ;-)
If the NIC is not processing checksum regeneration properly, then
it could be having other difficulties that might lead to the
bad packets never leaving the NIC. You need try snooping the
data -after- it leaves the NIC, such as by using SPAN or RSPAN
to "mirror" the switchport data over to another port for analysis.
Similar ThreadsPosted
Detect Incorrect Checksum July 27, 2006, 12:17 pm
Cisco 877W shows incorrect DSL attenuation July 3, 2006, 7:26 pm
IOS checksum error... November 20, 2008, 9:32 am
Pix 515 checksum error after update October 13, 2005, 8:52 am
Ip Header Checksum Error April 19, 2006, 8:18 am
validate-checksum Command November 29, 2007, 9:02 am
How to detect availability July 5, 2005, 1:11 pm
How to detect interface? February 27, 2008, 9:21 am
Prevent\Detect Dual Homing August 21, 2006, 3:28 am
Reset VOIP Call (no media detect) October 18, 2005, 10:03 pm
Using snmp traps to detect broadcast storms March 20, 2008, 12:00 pm
Some wireless clients cannot detect my unbroadcast Aironet AP July 3, 2008, 11:21 pm
