Cisco Systems Dedicated Point to Point T1 Connection via 2620 Routers
Subject Author Date
Dedicated Point to Point T1 Connection via 2620 Routers bavien 09-09-08
Posted by on September 9, 2008, 5:15 pm
I am trying to connect two remote sites using dedicated point to point
T1. The router at each site is Cisco 2620.
Currently, there is only one WIC card in each of the 2620 router. My
question is about the network subnet between the two routers.
Do I have to use some public subnet that my ISP will provide me or can
I just use any private subnet (taken into account that this private
subnet will be different from the subnets use for the remote LANs)?
Do I need specific settings from my ISP?
Anybody has a sample config for this setup?
For future expansion, if we need to up the bandwidth from a T1 to 2
Bonded T1, is this something that can be done easily router-
configuration wise? (with additional WIC in each of the 2620 router).
Thanks.
BV
Posted by Hansang Bae on September 9, 2008, 8:35 pm
> Thanks.
> BV
Can you be more specific? Do you have this setup?
ISP ---RTR1 -----new T1 --- RTR2
or
ISP1 ---RTR1 -----new T1 --- RTR2 ---ISP1
or
ISP ---RTR1 -----new T1 --- RTR2 ---ISP2
hsb
"Somehow I imagined this experience would be more rewarding" Calvin
Due to the volume of email that I receive, I may not be able to
reply to emails sent to my account. Please post a followup instead.
Posted by on September 9, 2008, 10:27 pm
> > Thanks.
> > BV
> Can you be more specific? =A0Do you have this setup?
> ISP ---RTR1 -----new T1 =A0--- RTR2
> or
> ISP1 ---RTR1 -----new T1 =A0--- RTR2 ---ISP1
> or
> ISP ---RTR1 -----new T1 =A0--- RTR2 ---ISP2
> hsb
Hansang,
A T1 line from the same ISP is brought into the demarc at each site so
I guess it would the second scenario you described...
ISP1---RT1---new T1--- RT2 --- ISP1
Hope this clear up my question...
BV
Posted by Hansang Bae on September 9, 2008, 11:09 pm
In that case, you don't need routable IP's on the transit (new) T1
connection. The religious debate about whether this is a good idea or
not is proably a moot point in this day and age.
Just make sure you account for the routing to and from RT1 subnets and
RT2 subnets. You can run an IGP (RIP2 for example) or you can use
static routes.
Assuming you're getting a default route from your ISP, make sure you
redistribute that into your IGP. This way, you get a redundant route
out if the right side link to ISP1 goes down. RT2 folks will know to
follow the default out via ISP1/RT1 path.
hsb
Posted by on September 9, 2008, 11:50 pm
> connection. =A0The religious debate about whether this is a good idea or
> RT2 subnets. =A0You can run an IGP (RIP2 for example) or you can use
> static routes.
> redistribute that into your IGP. =A0This way, you get a redundant route
> out if the right side link to ISP1 goes down. =A0RT2 folks will know to
> hsb
Hansang,
I am not sure if this will change the equation, but there is an
existing T1 at site2 to provide Internet access for LAN users at
site2. The idea is to connect the network between the two sites using
this new T1 (dedicated site to site connection) and also have the LAN
users behind router1 use the same existing T1 at site2 to get outside/
Internet access.
Thanks.
BV
Similar ThreadsPosted
Dedicated Point to Point T1 Connection via 2620 Routers September 9, 2008, 5:15 pm
IP Route Tables - Point to Point Connection - Only Routing 1 way December 3, 2007, 4:34 am
Point to Point T1 with Cisco 1841 Routers April 10, 2007, 1:51 pm
Scenario 5: IS-IS routing on Frame Relay Multi-point and Point-to-Point June 8, 2006, 5:11 am
E1 Controller Point to POint connection November 24, 2005, 4:50 pm
Point to Point T1 connection problem September 25, 2008, 6:42 am
Point to Point Connection Issues October 15, 2008, 8:00 am
using L2 connection as Point-To-Point July 13, 2007, 4:07 pm
Scenario 6: Multi Area EIGRP routing on Multipoint and Point-to-Point Frame Relay. June 11, 2006, 1:26 am
Point to Point Clear Channel DS3 - Clock Source Question July 19, 2006, 4:39 pm
Point-to-point T1 with 2620XM and crossover cable April 25, 2006, 4:59 pm
Re: Cisco 1300 series wireless access point/bridge Vs Linksys WAP54GPE Access Point Anyone know the basic pros & cons? November 28, 2007, 6:29 pm
Re: Cisco 1300 series wireless access point/bridge Vs Linksys WAP54GPE Access Point Anyone know the basic pros & cons? November 30, 2007, 4:03 pm
Re: Cisco 1300 series wireless access point/bridge Vs Linksys WAP54GPE Access Point Anyone know the basic pros & cons? December 2, 2007, 5:38 am
Point to Point connections over Ethernet October 13, 2006, 3:35 pm
