Cisco Systems Connecting a Linksys port to a Cisco 2611
Subject Author Date
Connecting a Linksys port to a Cisco 2611 jwkrych 05-27-08
Posted by jwkrych on May 27, 2008, 11:11 am
Hi all!
Thanks again for the help regarding my earlier post on a booting loop.
I have a question. My home lab is nearly complete and I want to connect
it to the Internet. I understand how to set my router port to receive
and IP via the DHCP statements, connecting a cable modem to a router,
but I'd like to grab one free port off of the Linksys so the rest of the
home LAN will not be affected by this. Can I connect one port of the
Linksys to my 2611, the Internet Router for my home lab? It's
essentially a switch-to-a-router connection.
Regards,
James
Posted by Trendkill on May 27, 2008, 1:00 pm
> Hi all!
> Regards,
> James
It should be no different. The linksys connects to the cable modem on
the external side and gives an internal IP to the router, unless of
course you have multiple public IPs and then you will need a basic
switch to split off the public IPs. Your only challenge will be
telneting/sshing to the router from the internet when it is no longer
addressed publicly. You can use either port forwarding, or use remote
desktop/VNC to a PC on the LAN who can then telnet/ssh to the router
to get into your lab. Hope this makes sense.
Posted by jwkrych on May 27, 2008, 3:07 pm
Trendkill wrote:
>> Hi all!
>> Regards,
>> James
Yes it does.
From what I have gathered here, it would look like the 2611 will get an
IP from the Linksys and I'll use that on my home lab for Internet
access-probably for the Win2003 server and the Linux box. I'll use
NAT/PAT to allow this.
Stay tuned...
James
Similar ThreadsPosted
Connecting a Linksys port to a Cisco 2611 May 27, 2008, 11:11 am
Internet to a 2611 through a Linksys WRT54G September 14, 2006, 6:55 pm
Connecting to a Cisco router's Console port via Zterm - Issues August 1, 2007, 1:21 am
Connecting to a Cisco router's Console port via Zterm - Issues August 1, 2007, 1:36 am
HELP WITH CISCO 2611 ARP December 20, 2006, 6:43 pm
Cisco 2611 NAT Configuration April 11, 2007, 4:03 pm
Cisco 2611, NAT, and Default Routes June 18, 2007, 11:00 pm
cisco 2611-dc power cable June 16, 2008, 11:29 am
Cisco 2611 router interface issues February 8, 2008, 5:42 pm
Cisco 2611 with Road Runner Business Class July 19, 2006, 5:23 pm
Replacement components on a Cisco 2611 mainboard (router go boom) June 16, 2006, 8:52 am
after rommon 1>conf reg 0x24(mistype) and reset ,i can't boot my cisco 2611 January 24, 2006, 9:23 pm
Linksys GIG v's Cisco Gig October 14, 2006, 2:01 pm
telnet through Linksys to Cisco April 11, 2006, 4:56 pm
cisco 7960 POE on linksys SRW 244 P August 2, 2006, 9:30 am
