Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by paul814@excite.com on April 19, 2008, 7:56 pm
Please log in for more thread options I had my vpn concentrator setup so someone accessing my network from the outside with a vpn client had to enter a group name and password and then would be prompted for a user name and password. I was then trying to get a LAN to LAN connection working and started playing with Base group settings. Now all that is needed is the group name and password, there is no more prompt for a username and password. Anyone know what this might be?....and how to fix it to ask for both again? | |||||||||||||
Posted by Darren on April 20, 2008, 11:00 am
Please log in for more thread options the global or user group that this user subscribes to. I think (from memory) you need to navigate to Configuration, User Management, Groups / Users. Somewhere around there you will see several Tabs, one of which will be the IPSEC properties. Scroll down until you see Authentication and make sure Xauth is checked. You need to ensure that the option selected is the one you use, for example, Internal if usernames and passwords are stored on the VPN Concentrator, or External if stored on another device. Then make sure you have your username and password defined for this user. If Local then I believe this is Configuration, User management, Users. HTH. Unfortunately I dont have a Concentrator to hand so can't 100% confirm the menu settings I'm afraid. Regards Darren | |||||||||||||
| Similar Threads | Posted |
| Concentrator 3000 question...client login. ??? | April 19, 2008, 7:56 pm |
| VPN 3000 Concentrator and Microsoft VPN Client | March 5, 2006, 4:30 am |
| Concentrator 3000 question ?? | April 15, 2008, 3:45 pm |
| Another question for Cisco VPN 3000 Concentrator | September 8, 2005, 9:28 pm |
| Cisco 3000 concentrator and PPTP question | February 15, 2006, 11:51 am |
| Cisco VPN Client - wireless AP - Cisco 3000 concentrator | January 25, 2006, 2:49 pm |
| Cisco 3000 login scripts? | June 9, 2006, 10:41 am |
| PIX 501 <-> Concentrator remote client question | April 20, 2006, 4:49 pm |
| help with concentrator 3000 | October 18, 2006, 10:18 am |
| Concentrator SSL VPN caching login page | October 24, 2006, 5:32 pm |
| Cisco IOS 12.4 =<> 3000 VPN concentrator? | August 3, 2005, 2:49 pm |
| Cisco Concentrator 3000 | August 14, 2005, 7:03 pm |
| Ports for a VPN 3000 Concentrator | September 8, 2005, 9:19 pm |
| Buy Cisco 3000 concentrator? | January 17, 2006, 1:41 pm |
| Cisco VPN 3000 concentrator | May 16, 2006, 10:00 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> again?
