Cisco Systems Cisco WLAN Controller project
Subject Author Date
Cisco WLAN Controller project Emlynfluff 05-16-08
Posted by Emlynfluff on May 16, 2008, 7:14 am
Hello,
I've been asked to look at a WLAN Controller project. Initially, this
will be for our internal use, then eventually offering some sort of
multi-tenancy share for our customers.
Anyone have any experience in the latter?
I guess we'd need a WCS, in order to give customers access to see
their own devices/reports etc. If that's possible.
Thanks, Stuart.
Posted by Uli Link on May 16, 2008, 7:36 am
Emlynfluff schrieb:
> Hello,
If you have to authenticate WLAN users for multiple customers, check the
restrictions for the originating interface for RADIUS requests. Each
RADIUS server must be reachable from the IP addresses of the
controller's management interface, which must also be reachable by every
connected LWAP. So if your customers want their own RADIUS servers used
for their own SSID/VLAN those management networks must be
interconnected, which is usually NOT the desired topology.
You can set the RADIUS server per VLAN/SSID but you cannot set the
RADIUS authenticator source interface per SSID/VLAN.
No problem if all WLAN's use a common RADIUS.
Uli
Similar ThreadsPosted
Cisco WLAN Controller project May 16, 2008, 7:14 am
WLAN controller? March 19, 2007, 9:53 am
project to configure Cisco Catalyst 6509 April 23, 2006, 11:50 pm
Looking for Cisco (freelance) engineers for project work August 10, 2006, 4:01 pm
Enable guests on Cisco WLAN March 22, 2007, 7:44 am
Cisco 877 as a simple WLAN Client? November 4, 2007, 1:12 pm
Bridging Ethernet and WLAN with a Cisco 877W October 29, 2006, 4:05 pm
Cisco 350 Wlan card - dead following firmware upgrade - suggestions? February 1, 2006, 7:03 am
Cisco WLAN 4402 Access points hang or reboot September 20, 2006, 9:33 am
Cisco Wireless Lan Controller Auditing March 12, 2008, 6:06 pm
Cisco Catalyst 3750G Wireless Lan Controller May 1, 2007, 2:54 pm
looking for a valuable project in VOIP / IMS August 2, 2006, 3:36 am
Layer 2 Filtering Project...... September 15, 2006, 5:11 am
Re: Large VLAN Project - Advise March 21, 2007, 7:34 am
WLAN Planning January 19, 2007, 2:02 pm
