Cisco Systems Cisco VPN Client v 4.6 and Cisco Aironet Wireless Adapter
Subject Author Date
Cisco VPN Client v 4.6 and Cisco Aironet Wireless Adapter cdonyi 02-09-05
Posted by cdonyi on February 9, 2005, 1:43 am
I am using a custom combination bundled install of the Cisco VPN Client
v4.6 and Cisco Aironet Wireless adapter. If an ethernet LAN pcmcia
card is installed in the laptop PCMCIA slot during the install, the
wireless card install waits until a card is inserted before proceeding
(as expected). In general if the vpn client install completes before
the Aironet wireless install trying a subsequent vpn connection over
wireless fails. However, If the vpn client is installed AFTER the
wireless LAN adapter, everything seems to work just fine (vpn over
wireless). I want to ensure the VPN client will always work regardless
of when the wireless adapter software is installed. Anybody with any
ideas to this behaviour? I notice during failure of vpn over wireless,
the log file complains about a problem starting the firewall.
Disabling the firewall did not alter this behaviour.
-Donald
Posted by Martin Bilgrav on February 9, 2005, 1:17 pm
> Hi,
Hiya
Are you installing/inserting other NIC while installing software ?
I would not reccommend doing so.
> the
The Wireless software should install first and then the VPN.
As both make dramastic changes to the IP stack.
A reboot is also required before everything works.
> -Donald
HTH
Martin Bilgrav
Similar ThreadsPosted
Cisco VPN Client v 4.6 and Cisco Aironet Wireless Adapter February 9, 2005, 1:43 am
Driver for Cisco Aironet 350 Wireless adapter. February 2, 2006, 1:22 pm
Re: Linksys wireless-G notebook adapter pings Cisco web each second March 23, 2008, 11:17 pm
Re: Linksys wireless-G notebook adapter pings Cisco each second March 24, 2008, 1:57 am
Cisco Aironet 1490 wireless bridge and lightning November 4, 2005, 10:55 am
Cisco VPN Client - wireless AP - Cisco 3000 concentrator January 25, 2006, 2:49 pm
Cisco Wireless - Client hidden from each other possible ? July 13, 2006, 10:19 am
Cisco 877W as Wireless client July 1, 2007, 12:49 pm
VPN Client is not working. Strange VPN Adapter behavior. January 2, 2008, 10:21 am
Recommend USB to Serial Adapter for Cisco Products November 8, 2005, 1:01 am
Some wireless clients cannot detect my unbroadcast Aironet AP July 3, 2008, 11:21 pm
Wireless clients can't get DHCP address from router behind Aironet 1100 January 20, 2007, 2:10 pm
wireless client cannot communicate each other? November 3, 2005, 11:02 pm
VPN client and wireless can't coexist May 26, 2006, 10:12 pm
Re: vpn client with wireless card doesn't work August 12, 2005, 5:26 pm
