Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Morph on July 24, 2008, 12:58 pm
Please log in for more thread options yesterday. It is an appliance based on a hardened Windows Server 2003 with no access to the windows part. After I started the appliance it would boot and on the attached monitor I see the windows message "At least one service or driver failed during system startup..." The device was acting funny so today I did a recovery procedure, that is I reinstalled the appliance with the DVD from cisco. Even with a fresh new installation when the device boots I see on the screen the same message "At least one service or driver failed during system startup...". Since there is no access to the windows OS I can't see what exactly is the problem. Now the appliance seems to be working fine but i'm not sure why the error message appears. Does anyone have an idea regarding this issue? -- -Was he talking about what I think he was talking about? -If you mean time-traveling bunnies, then yes. | |||||||||||||
Posted by Thrill5 on July 24, 2008, 9:50 pm
Please log in for more thread options Open a TAC case, they will be able to access the OS and determine if there is a problem. | |||||||||||||
Posted by fugettaboutit on July 25, 2008, 7:27 am
Please log in for more thread options I believe this is a bug and is listed on CCO. I have an ACS Solutions
Engine as well, and I see the same warning. Seems like I had also discussed this with TAC on an unrelated call and they indicated it wasn't a problem. Thrill5 wrote: >> I installed a new Cisco Secure Access Control Server Solution Engine
>> yesterday. It is an appliance based on a hardened Windows Server 2003 >> with no access to the windows part. >> >> After I started the appliance it would boot and on the attached monitor >> I see the windows message "At least one service or driver failed during >> system startup..." The device was acting funny so today I did a recovery >> procedure, that is I reinstalled the appliance with the DVD from cisco. >> Even with a fresh new installation when the device boots I see on the >> screen the same message "At least one service or driver failed during >> system startup...". Since there is no access to the windows OS I can't >> see what exactly is the problem. >> >> Now the appliance seems to be working fine but i'm not sure why the >> error message appears. >> >> Does anyone have an idea regarding this issue? >> >> -- >> -Was he talking about what I think he was talking about? >> -If you mean time-traveling bunnies, then yes. >
> Open a TAC case, they will be able to access the OS and determine if there > is a problem. > > | |||||||||||||
Posted by Morph on July 28, 2008, 6:03 am
| > yesterday. It is an appliance based on a hardened Windows Server 2003 | > with no access to the windows part. | > | > After I started the appliance it would boot and on the attached monitor | > I see the windows message "At least one service or driver failed during | > system startup..." The device was acting funny so today I did a recovery | > procedure, that is I reinstalled the appliance with the DVD from cisco. | > Even with a fresh new installation when the device boots I see on the | > screen the same message "At least one service or driver failed during | > system startup...". Since there is no access to the windows OS I can't | > see what exactly is the problem. | > | > Now the appliance seems to be working fine but i'm not sure why the | > error message appears. | > | > Does anyone have an idea regarding this issue? | > | > -- | > -Was he talking about what I think he was talking about? | > -If you mean time-traveling bunnies, then yes. | Open a TAC case, they will be able to access the OS and determine if there | is a problem. I opened a TAC case and they (as fugettaboutit sugested) said that I can ignore the error message and that it doesn't affect the ACS. Thanks both of you for your time! -- -Was he talking about what I think he was talking about? -If you mean time-traveling bunnies,then yes. | |||||||||||||
Cisco Secure ACS Solution Engine - Some windows services not started
Yahoo!
Windows Live
del.icio.us
digg
Netscape
