Cisco Systems Cisco Pix 501 and Linksys router
Subject Author Date
Cisco Pix 501 and Linksys router chappobluff 07-06-05
Posted by chappobluff on July 6, 2005, 4:34 pm
I have a Linksys router connected to a cable modem.
I just got a cisco pix 501 off of ebay and I want to put it behind the
Linksys router, then all systems behind the pix.
Can I configure int0 with a private address?
So if I give the internal network behind the PIX 192.168.3.1
then the outsidie int0 192.168.2.1
Then my linksys router 192.168.1.1
Then create a static route between the PIX and the Linksys.
Will this work. I was told that I could not configure the outside
interface with a private address.
Thanks
Posted by Martin Kayes on July 7, 2005, 11:06 am
Yes, you can put any address on the outside interface. I have a similar
setup working with several customers.
Regards,
Martin
> Thanks
Posted by Ronin on July 8, 2005, 6:05 am
I can confirm that this can be done as I am currently doing it myself
(however I am using a Draytek instead of a Linksys).
At present from the PIX I can ping outside to the Internet but PC's from
behind the PIX (although they have a correct configured IP address) can only
ping to the inside interface of the PIX but cannot go out!
I am wondering whether this is due to the fact that there is NAT happening
on the Draytek but not sure what else to do, if anyone can give any tips
that would be great!
J
> Regards,
> Martin
>> Thanks
Posted by Martin Kayes on July 13, 2005, 9:23 am
It depends how your NAT is setup. If the Draytek router is doing a 1:1 NAT
to the outside interface address of the PIX, then the PIX will need a global
nat setting up to translate the PC's to it's own outside interface address.
If the Draytek is doing a many:1 PAT translation and is using the PC's
subnet as the source then the PIX will need a nat 0 statement for the PC
subnet to be allowed to reach the Draytek with their original IP's intact.
If that isn't too clear then could you confirm which types of NAT & relevant
addresses you are using.
Regards,
Martin
> only ping to the inside interface of the PIX but cannot go out!
> J
>> Regards,
>> Martin
>>> Thanks
Similar ThreadsPosted
Cisco Pix 501 and Linksys router July 6, 2005, 4:34 pm
VPN between Cisco 837 and Linksys wireless router. February 14, 2005, 4:58 pm
Linksys Router < -- > Cisco PIX 506e September 22, 2005, 9:02 am
Linksys router March 8, 2007, 3:54 pm
Linksys router as switch April 19, 2007, 9:20 am
Linksys router WAG54G and updates of antispyware November 17, 2005, 11:25 pm
Connect Catalyst 2924 to Linksys Router June 25, 2007, 6:16 am
Unable to Connect Multiple VPN Clients via Linksys Router October 20, 2006, 8:57 am
FS: Linksys RT31P2 VoIP PAP2+Router Combo$29.99USD/each (900 units available) June 2, 2007, 11:29 am
Linksys GIG v's Cisco Gig October 14, 2006, 2:01 pm
telnet through Linksys to Cisco April 11, 2006, 4:56 pm
cisco 7960 POE on linksys SRW 244 P August 2, 2006, 9:30 am
Linksys SFE2000P - not really a Cisco July 4, 2008, 5:44 pm
Cisco 837 IPSEC Linksys WAG54g July 11, 2005, 5:37 pm
Linksys BEFVP41 to Cisco Pix 506E July 21, 2005, 7:50 am
