Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Ned on May 3, 2007, 4:06 am
fine. I have added a Netgear smartswitch GS748T. I have created the VLANS on the Netgear switch; now I want to set up a trunk (DOT1Q) between the switches. I have the Cisco trunk set up, but I never did a Netgear trunk and am confused by the Web interface for trunking; firstly, should the ports in each VLAN be tagged or untagged. Secondly when setting up a trunk the netgear config screen has an "ID" column and "port numbers" - do I select and ID for each VLAN and tick the port that are in that VLAN? Is there a command line interface for the netgear or does it have to be accessed through the browser? TIA, Ned | |||||||||||||
Posted by Brian V on May 3, 2007, 6:57 am
Please log in for more thread options The "Trunk" in Netgear speak is not "Trunk" in Cisco speak. In Cisco "Trunk" is an interface that carries multiple vlans. In Netgear it is the binding of ports to create a larger pipe, which in Cisco we call a port channel. Under the port configuration area on the Netgear there should be a way to check off which VLAN's belong to a port. Once you check off multiple VLAN's it automagically creates the "Trunk". | |||||||||||||
Posted by Doug McIntyre on May 3, 2007, 2:24 pm
Please log in for more thread options >I have a Cisco 3750 with layer 3 switching for the VLANs working
>fine. >I have added a Netgear smartswitch GS748T. I have created the VLANS >on >the Netgear switch; now I want to set up a trunk (DOT1Q) between the >switches. I have the Cisco trunk set up, but I never did a Netgear >trunk and am confused by the Web interface for trunking; firstly, >should the ports in each VLAN be tagged or untagged. Secondly when >setting up a trunk the netgear config screen has an "ID" column and >"port numbers" - do I select and ID for each VLAN and tick the port >that are in that VLAN? Yep, the HP method of doing things. :) Amazing how much of their technology leaks out to other vendors. You want to tag each of your VLANs on the port that is your "trunk" port upstream to your 3750. It'll start doing what you want then. >Is there a command line interface for the netgear or does it have to
>be accessed through the browser? There is a CLI from what I remember, but the web interface is easier to use. | |||||||||||||
Cisco & Netgear switch trunking
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> fine.
> on
> TIA, Ned
