Cisco Systems Cisco + Ericsson Mini-Link 34 Mbps
Subject Author Date
Cisco + Ericsson Mini-Link 34 Mbps Enrico 12-02-08
Posted by Enrico on December 2, 2008, 5:13 am
Hello,
I'm dealing with a problem on a 34 Mbps RF link.
| cisco 2821 ipbase 124-5a.bin | -- coax cable ------------ | Ericsson
Mini-Link | --- RF
Router interface is NM-1T3/E3 subrate.
At the time x the router detects interface up/down while the RF link is
healthy.
.Feb 15 01:32:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0,
changed state to down.
Feb 15 01:32:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0,
changed state to up
.Feb 15 01:32:55: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0,
.Feb 15 01:33:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0,
changed state to up
At the time x+y the IP connectivity goes down, with the RF healthy.
To regain the IP connectivity we must disconnect and reconnect the coax
cable between the Cisco and the Mini-Link!
It can work some days, some weeks or some months ant then the problem
re-happen.
We've already wrote to cisco and Ericsson: no problem detected.
Any idea?
Thanks
Enrico
Posted by Jesper Skriver on December 2, 2008, 7:37 am
On Tue, 02 Dec 2008 10:13:56 GMT, Enrico wrote:
> Hello,
> Mini-Link | --- RF
> healthy.
> changed state to up
> changed state to up
> re-happen.
> Any idea?
Clocking ? who is providing clocking on this link ?
Jesper Skriver, CCIE #5456
Posted by bod43 on December 2, 2008, 7:45 am
> Hello,
> =A0 I'm dealing with a problem on a 34 Mbps RF link.
> Mini-Link | --- RF
> healthy.
> .Feb 15 01:32:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1=
/0,
> Feb 15 01:32:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/=
0,
> changed state to up
> .Feb 15 01:32:55: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1=
/0,
> .Feb 15 01:33:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1=
/0,
> changed state to up
> re-happen.
> Any idea?
Line protocol down is due to the loss of keepalive packets
on the cisco. On serial ports a keepalive is send periodically
(10 seconds? - I forget). Then the far end (the other router
I would imagine and not the Ericsson but I am not sure)
sends the keepalive back.
http://www.cisco.com/en/US/docs/ios/12_3/debug/command/reference/dbg_s1g.ht=
ml#wp1050649
describes the keepalive process and "debug serial int"
As long as you dont have a large number of interfaces on the router
you could leave this running long term I would think without affecting
router performance.
you need to arrange to log the debug messages of course.
To troubleshoot first look at the error counters on the interfaces
sh int
at *both* ends
Also determine if there are other problems with the link.
I would leave a long term ping running on the link to see how it is
actually performing.
pingplotter is VERY good. Use full length packets at 1 per second.
Also try a full load test with iperf or netperf or ttcp or otherwise.
How are you doing the clocking? Each serial link needs
**exactly** one clock source. Either the ericsson or the Cisco
must generate a clock? I do not know if the erricson link simulates
a serial link end to end or if it is effectively a bridge that
terminates
each serial link on it. Understanding this is critical to correct
clocking
configuration.
On a telco provided serial link it is normal for the telco to provide
the clock.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a008=
00a758d.shtml
Troubleshooting Serial Line Problems
Please post
sh int from both ends and the configuration of the
serial interfaces.
Report on results of long term ping
The Ericsson must have interface stats as well. Find those too.
It may be possible to recover without disconnecting
with reset int serial x/x/x
or with
conf t
int se x/x/x
shut
no shut
end
the latter being "stronger" medicine.
Posted by Enrico on December 2, 2008, 10:51 am
Thank you for your post:
Sorry, I've omitted the other portion of the network
|Cisco 2821|-- |Mini Link|---------- RF --------- |Mini Link|--| Juniper
M320|
Clocking is provided by the M320 Juniper; the Mini-Link is passive for the
clock.
Cisco Interface:
interface Serial1/0
description LINK 34 Mb
mtu 1500
ip address X.X.160.202 255.255.255.252
no ip route-cache cef
no ip route-cache
no ip mroute-cache
load-interval 30
dsu bandwidth 34010
dsu mode 1
Juniper Interface:
show configuration interfaces e3-2/1/0
description "* 34Mbps * ;
clocking internal;
encapsulation cisco-hdlc;
e3-options {
compatibility-mode kentrox;
unit 0 {
family inet {
address X.X.160.201/30;
Thanks
Enrico
> Hello,
> Mini-Link | --- RF
> healthy.
> Serial1/0,
> Serial1/0,
> changed state to up
> Serial1/0,
> Serial1/0,
> changed state to up
> re-happen.
> Any idea?
http://www.cisco.com/en/US/docs/ios/12_3/debug/command/reference/dbg_s1g.html#wp1050649
router performance.
sh int
at *both* ends
terminates
clocking
configuration.
the clock.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a758d.shtml
Please post
serial interfaces.
or with
conf t
int se x/x/x
shut
no shut
end
Posted by Thrill5 on December 2, 2008, 11:36 pm
Why is route caching disabled? Without it, you will never even come close
to utilizing a 34Mbps circuit and there are only very specific circumstances
where this should be disabled (like doing per-packet load-balancing, but you
still run into performance issues)
Anyway, the circuit is not your problem because line protocol is going down
not the circuit. If you do a show interface on the serial and it will show
up/down. This means the circuit is up, but no line protocol. I would
suspect that the problem could be the Juniper side. Next time this happens,
try doing a shut/no shut on the Juniper side to see if this jump starts the
interface to up. You could also try changing the encapsulation to PPP
instead of using HDLC.
> M320|
> clock.
> Cisco Interface:
> interface Serial1/0
> mtu 1500
> no ip route-cache
> no ip mroute-cache
> load-interval 30
> dsu bandwidth 34010
> dsu mode 1
> Juniper Interface:
> clocking internal;
> e3-options {
> unit 0 {
> family inet {
> Thanks
> Enrico
>> Hello,
>> Mini-Link | --- RF
>> healthy.
>> Serial1/0,
>> Serial1/0,
>> changed state to up
>> Serial1/0,
>> Serial1/0,
>> changed state to up
>> re-happen.
>> Any idea?
> router performance.
> sh int
> at *both* ends
> terminates
> clocking
> configuration.
> the clock.
> Please post
> serial interfaces.
> or with
> conf t
> int se x/x/x
> shut
> no shut
> end
Similar ThreadsPosted
Cisco + Ericsson Mini-Link 34 Mbps December 2, 2008, 5:13 am
Configuring two T1 lines in cisco 2600 (Total 4 Mbps) from two diffferent providers November 5, 2005, 3:20 am
www.yescell.com sell refurbish Sony Ericsson cellphone and parts January 9, 2009, 3:09 am
policer 1 mbps = 1,000,000 bps, 1,024,000 bps or 1,048,576 bps? January 2, 2007, 11:36 am
Business VoIP Solutions Using Cisco Gateways, Cisco Call Agent, And Cisco IP Phones October 2, 2007, 8:02 pm
Discussion about segregating bandwidth with Cisco 7513, Cisco 3750 and Cisco 3640 June 17, 2006, 8:34 am
good cisco and juniper IPS site for intrusion prevention and cisco switch info January 5, 2007, 4:59 pm
Re: Q: Cisco AP 1131 -- "Unsupported device type" error in Cisco Network Assistant November 27, 2007, 1:19 pm
Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable August 15, 2008, 6:40 am
Re: Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable August 15, 2008, 7:32 am
Cisco 2970 strange traffic problem - stumped cisco support February 10, 2005, 12:19 pm
Cisco Custom Historical Report for Cisco Customer Response Applications January 17, 2006, 12:34 pm
SNMP OIDs required for Cisco 1200 and Cisco 1100 series APs November 7, 2006, 9:44 am
Cisco owned (linksys wet11b) is cisco failing to see market demands? March 10, 2005, 5:02 pm
Respected Cisco trainer Wendell Odom blogging for Network World's Cisco Subnet September 10, 2007, 5:47 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
