Cisco Systems Cisco 877W, fixed IP, ISP connection drops
Subject Author Date
Cisco 877W, fixed IP, ISP connection drops Ken 06-30-06
Posted by Ken on June 30, 2006, 2:37 am
Hi
I have purchased a brand new Cisco 877W. When using the ISP supplied
modem it works great with both my other routers DLink 524, Linksys
WRT54G (the modem is a Speedstream).
When using the Cisco router it stays online for approx. 4 hours
(sometimes less) and then it looses the connection to the ISP, I then
have to swap to one of the other routers (DLink 524, Linksys WRT54G)
for about 10-20 seconds and can then swap back to the Cisco.
(Explanation: When I say swap the routers that is not entirely correct.
What I do is this.
1. Take out the ADSL cable (going from the builtin Cisco modem -> line
splitter) from the line splitter.
2. Put in the ADSL cable (going from Speedstream modem (ISP supplied
modem) -> line splitter) into the line splitter.
3. Wait for the ADSL light to turn on (10-20 seconds) on the
Speedstream modem.
4. Take out the ADSL cable (going from Speedstream modem (ISP supplied
modem) -> line splitter) from the line splitter.
5. Put in the ADSL cable (going from the builtin Cisco modem -> line
Now the Cisco router will work again for a while most of the time just
around 4 hours (and 2 minutes) but somethimes less. The ISP have
checked their side and reports no error in the configuration, they even
swapped port on their side to no avail.
I have had CCNA professional assistance and still have no luck so far.
This really has me bewildered. The ISP TDC offers preconfigured Cisco
routers up to 677 to customers but I need the features of the 877W so I
had to purchase the router separately.
Remote access will be provided upon request.
Interesting parts of the log:
000280: Jun 29 11:36:53.423 PCTime: %LINK-3-UPDOWN: Interface ATM0,
changed state to down
000281: Jun 29 11:36:54.423 PCTime: %LINEPROTO-5-UPDOWN: Line protocol
on Interface ATM0, changed state to down
000282: Jun 29 11:38: 16.935 PCTime: %LINK-3-UPDOWN: Interface ATM0,
changed state to up
000283: Jun 29 11:38:17.935 PCTime: %LINEPROTO-5-UPDOWN: Line protocol
on Interface ATM0, changed state to up
the router is up for 1 hour and 3 minutes
TMData uptime is 1 hour, 3 minutes
System returned to ROM by reload
System restarted at 10:36:49 PCTime Thu Jun 29 2006
System image file is "flash:c870-advsecurityk9-mz.124-4.T1.bin"
Last reload reason: Reload Command
using debug command "debug atm ilmi atm 0" we captured the message:
006176: Jun 28 14:12:46.628 PCTime: ILMI: Encapsulation error on o/g
ILMI Pdu <ilmi_send_pkt> (ATM0)
006177: Jun 28 14:12:46.628 PCTime: ILMI: Unable to Send Pdu out
<ilmi_send_trap>
006178: Jun 28 14:12: 48.628 PCTime: ILMI(ATM0): Sending ilmiColdStart
trap
006179: Jun 28 14:12:48.628 PCTime: ILMI(ATM0): No ILMI VC found
after restart, this morning, 29 June, 10:36:49 the result frmo debug
was:
000360: Jun 29 11:48:41.087 PCTime: ILMI(ATM0): Sending ilmiColdStart
trap (ATM0)
000361: Jun 29 11:48:43.087 PCTime: ILMI(ATM0): Sending ilmiColdStart
trap (ATM0)
000362: Jun 29 11:48:45.087 PCTime: ILMI(ATM0): Sending ilmiColdStart
trap (ATM0)
000363: Jun 29 11:48:47.087 PCTime: ILMI(ATM0): Sending ilmiColdStart
trap (ATM0)
000364: Jun 29 11:48:49.087 PCTime: ILMI(ATM0): Sending ilmiColdStart
trap (ATM0)
000365: Jun 29 11:48:51.087 PCTime: ILMI(ATM0): Sending ilmiColdStart
trap (ATM0)
in about one hour from restart the connection went down again.
Country: Denmark
ISP: TDC
ADSL: 4096/768
Encapsulation: AAL5SNAP
(see details from running config)
ATM0 / ATM0.6 is the external interface
--- Running config - START
!This is the running config of the router: 50.10.10.1
!version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname TMData
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 $1$jl4C$7/wGQiLK5ttI1swqHcJWz/
no aaa new-model
resource policy
clock timezone PCTime 1
ip subnet-zero
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp pool sdm-pool1
import all
network 50.10.10.0 255.255.255.0
default-router 50.10.10.1
dns-server 193.162.153.164 194.239.134.83
ip inspect name DEFAULT100 appfw DEFAULT100
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip inspect name DEFAULT100 https
ip inspect name DEFAULT100 dns
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
ip tcp synwait-time 10
no ip bootp server
ip domain name tmdata.dk
ip name-server 193.162.153.164
ip name-server 194.239.134.83
ip ssh time-out 60
ip ssh authentication-retries 2
appfw policy-name DEFAULT100
application im msn
service default action allow
service text-chat action allow
server permit name messenger.hotmail.com
server permit name gateway.messenger.hotmail.com
server permit name webmessenger.msn.com
audit-trail off
application http
port-misuse im action reset alarm
transfer-encoding type compress action allow
transfer-encoding type identity action allow
transfer-encoding type chunked action allow
transfer-encoding type gzip action allow
transfer-encoding type deflate action allow
application im yahoo
server permit name scs.msg.yahoo.com
server permit name scsa.msg.yahoo.com
server permit name scsb.msg.yahoo.com
server permit name scsc.msg.yahoo.com
server permit name scsd.msg.yahoo.com
server permit name cs16.msg.dcn.yahoo.com
server permit name cs19.msg.dcn.yahoo.com
server permit name cs42.msg.dcn.yahoo.com
server permit name cs53.msg.dcn.yahoo.com
server permit name cs54.msg.dcn.yahoo.com
server permit name ads1.vip.scd.yahoo.com
server permit name radio1.launch.vip.dal.yahoo.com
server permit name in1.msg.vip.re2.yahoo.com
server permit name data1.my.vip.sc5.yahoo.com
server permit name address1.pim.vip.mud.yahoo.com
server permit name edit.messenger.yahoo.com
server permit name messenger.yahoo.com
server permit name http.pager.yahoo.com
server permit name privacy.yahoo.com
server permit name csa.yahoo.com
server permit name csb.yahoo.com
server permit name csc.yahoo.com
audit-trail off
crypto pki trustpoint TP-self-signed-1402440444
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1402440444
revocation-check none
rsakeypair TP-self-signed-1402440444
crypto pki certificate chain TP-self-signed-1402440444
certificate self-signed 01
30820248 308201B1 A0030201 02020101 300D0609 2A864886 F70D0101
04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D
43657274
69666963 6174652D 31343032 34343034 3434301E 170D3032 30333031
30303133
34365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504
03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31
34303234
34303434 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030
81890281
8100CC28 240D5B76 51F315C6 A315B0A8 5EDA747F C142157D 41E7CAC0
9EE8D130
7A346321 CEF4FF46 AB2A6FBA 24F22591 FA98844C C5FD5016 6B8E003A
41CBE254
B6CCEFEB D937C5A6 9C086DD4 1FA0737E E7D88E53 8195FF41 7332EF22
96D08B9D
35DE756E DBD0457E 11C5EA95 72263E3F 221F85E9 50678A99 457C093A
76833962
53D30203 010001A3 70306E30 0F060355 1D130101 FF040530 030101FF
301B0603
551D1104 14301282 10544D44 6174612E 746D6461 74612E64 6B301F06
03551D23
04183016 8014AC32 27D55EAB 6C208ED2 5B691330 7F7C47F5 6376301D
0603551D
0E041604 14AC3227 D55EAB6C 208ED25B 6913307F 7C47F563 76300D06
092A8648
86F70D01 01040500 03818100 0D7D5579 5B224102 85ACD7A5 70CEA26D
AB724318
41A5EA62 A84A510C 30642D39 754B6518 21BE7C30 2C0F7AA7 46DED180
CF7C223A
2AA5A5E9 CF559865 2B3489A2 F17FEE60 85804CAC 1912608B 43A021FF
57BEEBF2
EC02E9AD 72798C6C 79A5FC11 5E135B7E 97B79593 64367A71 0668FDD5
BDC47487
93D3FC8C CFAB486A C21D01A8
quit
username XXX privilege 15 secret 5 XXX !hash and username has been
commented out
commented out
bridge irb
interface Null0
no ip unreachables
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm auto-configuration
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.6 point-to-point
description $FW_OUTSIDE$
ip address 87.50.196.58 255.255.255.252
ip access-group 111 in
ip verify unicast reverse-path
ip mask-reply
ip inspect SDM_LOW out
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly
pvc 0/101
protocol ip 87.50.196.57 broadcast
oam-pvc manage
encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
bridge-group 1
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 50.10.10.1 255.255.255.0
ip access-group 104 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0.6 permanent
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface ATM0.6 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 50.10.10.0 0.0.0.255
access-list 2 permit 212.146.94.66
access-list 2 remark HTTP Access-class list
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 195.12.52.146
access-list 2 permit 67.98.69.136
access-list 2 permit 50.10.10.0 0.0.0.255
access-list 2 deny any
access-list 100 remark auto-generated by Cisco SDM Express firewall
configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 permit ip any any
access-list 101 remark auto-generated by Cisco SDM Express firewall
configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 50.10.10.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any
access-list 102 remark VTY Access-class list
access-list 102 remark SDM_ACL Category=1
access-list 102 permit ip host 195.12.52.146 any
access-list 102 permit ip host 212.146.94.66 any
access-list 102 permit ip host 67.98.69.136 any
access-list 102 permit ip 50.10.10.0 0.0.0.255 any
access-list 102 deny ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp host 194.239.134.83 eq domain host
87.50.196.58
access-list 103 permit udp host 193.162.153.164 eq domain host
87.50.196.58
access-list 103 deny ip 50.10.10.0 0.0.0.255 any
access-list 103 permit icmp any host 87.50.196.58 echo-reply
access-list 103 permit icmp any host 87.50.196.58 time-exceeded
access-list 103 permit icmp any host 87.50.196.58 unreachable
access-list 103 deny ip 10.0.0.0 0.255.255.255 any
access-list 103 deny ip 172.16.0.0 0.15.255.255 any
access-list 103 deny ip 192.168.0.0 0.0.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip host 0.0.0.0 any
access-list 103 deny ip any any log
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 permit tcp 50.10.10.0 0.0.0.255 host 50.10.10.1 eq
telnet
access-list 104 permit tcp 50.10.10.0 0.0.0.255 host 50.10.10.1 eq 22
access-list 104 permit tcp 50.10.10.0 0.0.0.255 host 50.10.10.1 eq www
access-list 104 permit tcp 50.10.10.0 0.0.0.255 host 50.10.10.1 eq 443
access-list 104 permit tcp 50.10.10.0 0.0.0.255 host 50.10.10.1 eq cmd
access-list 104 deny tcp any host 50.10.10.1 eq telnet
access-list 104 deny tcp any host 50.10.10.1 eq 22
access-list 104 deny tcp any host 50.10.10.1 eq www
access-list 104 deny tcp any host 50.10.10.1 eq 443
access-list 104 deny tcp any host 50.10.10.1 eq cmd
access-list 104 deny udp any host 50.10.10.1 eq snmp
access-list 104 deny ip 87.50.196.56 0.0.0.3 any log
access-list 104 deny ip host 255.255.255.255 any log
access-list 104 deny ip 127.0.0.0 0.255.255.255 any log
access-list 104 permit ip any any
access-list 105 remark auto generated by SDM firewall configuration
access-list 105 remark SDM_ACL Category=1
access-list 105 permit udp host 194.239.134.83 eq domain host
87.50.196.58
access-list 105 permit udp host 193.162.153.164 eq domain host
87.50.196.58
access-list 105 deny ip 50.10.10.0 0.0.0.255 any
access-list 105 permit icmp any host 87.50.196.58 echo-reply
access-list 105 permit icmp any host 87.50.196.58 time-exceeded
access-list 105 permit icmp any host 87.50.196.58 unreachable
access-list 105 deny ip 10.0.0.0 0.255.255.255 any
access-list 105 deny ip 172.16.0.0 0.15.255.255 any
access-list 105 deny ip 192.168.0.0 0.0.255.255 any
access-list 105 deny ip 127.0.0.0 0.255.255.255 any
access-list 105 deny ip host 255.255.255.255 any
access-list 105 deny ip host 0.0.0.0 any
access-list 105 deny ip any any log
access-list 106 remark auto generated by SDM firewall configuration
access-list 106 remark SDM_ACL Category=1
access-list 106 permit udp host 194.239.134.83 eq domain host
87.50.196.58
access-list 106 permit udp host 193.162.153.164 eq domain host
87.50.196.58
access-list 106 deny ip 50.10.10.0 0.0.0.255 any
access-list 106 permit icmp any host 87.50.196.58 echo-reply
access-list 106 permit icmp any host 87.50.196.58 time-exceeded
access-list 106 permit icmp any host 87.50.196.58 unreachable
access-list 106 deny ip 10.0.0.0 0.255.255.255 any
access-list 106 deny ip 172.16.0.0 0.15.255.255 any
access-list 106 deny ip 192.168.0.0 0.0.255.255 any
access-list 106 deny ip 127.0.0.0 0.255.255.255 any
access-list 106 deny ip host 255.255.255.255 any
access-list 106 deny ip host 0.0.0.0 any
access-list 106 deny ip any any log
access-list 107 remark auto generated by SDM firewall configuration
access-list 107 remark SDM_ACL Category=1
access-list 107 permit udp host 193.162.153.164 eq domain host
87.50.196.58
access-list 107 permit udp host 194.239.134.83 eq domain host
87.50.196.58
access-list 107 deny ip 50.10.10.0 0.0.0.255 any
access-list 107 permit icmp any host 87.50.196.58 echo-reply
access-list 107 permit icmp any host 87.50.196.58 time-exceeded
access-list 107 permit icmp any host 87.50.196.58 unreachable
access-list 107 deny ip 10.0.0.0 0.255.255.255 any
access-list 107 deny ip 172.16.0.0 0.15.255.255 any
access-list 107 deny ip 192.168.0.0 0.0.255.255 any
access-list 107 deny ip 127.0.0.0 0.255.255.255 any
access-list 107 deny ip host 255.255.255.255 any
access-list 107 deny ip host 0.0.0.0 any
access-list 107 deny ip any any log
access-list 108 remark auto generated by SDM firewall configuration
access-list 108 remark SDM_ACL Category=1
access-list 108 permit udp host 193.162.153.164 eq domain host
87.50.196.58
access-list 108 permit udp host 194.239.134.83 eq domain host
87.50.196.58
access-list 108 deny ip 50.10.10.0 0.0.0.255 any
access-list 108 permit icmp any host 87.50.196.58 echo-reply
access-list 108 permit icmp any host 87.50.196.58 time-exceeded
access-list 108 permit icmp any host 87.50.196.58 unreachable
access-list 108 deny ip 10.0.0.0 0.255.255.255 any
access-list 108 deny ip 172.16.0.0 0.15.255.255 any
access-list 108 deny ip 192.168.0.0 0.0.255.255 any
access-list 108 deny ip 127.0.0.0 0.255.255.255 any
access-list 108 deny ip host 255.255.255.255 any
access-list 108 deny ip host 0.0.0.0 any
access-list 108 deny ip any any log
access-list 109 remark auto generated by SDM firewall configuration
access-list 109 remark SDM_ACL Category=1
access-list 109 permit udp host 194.239.134.83 eq domain host
87.50.196.58
access-list 109 permit udp host 193.162.153.164 eq domain host
87.50.196.58
access-list 109 deny ip 50.10.10.0 0.0.0.255 any
access-list 109 permit icmp any host 87.50.196.58 echo-reply
access-list 109 permit icmp any host 87.50.196.58 time-exceeded
access-list 109 permit icmp any host 87.50.196.58 unreachable
access-list 109 permit tcp any host 87.50.196.58 eq 443
access-list 109 permit tcp any host 87.50.196.58 eq 22
access-list 109 permit tcp any host 87.50.196.58 eq cmd
access-list 109 deny ip 10.0.0.0 0.255.255.255 any
access-list 109 deny ip 172.16.0.0 0.15.255.255 any
access-list 109 deny ip 192.168.0.0 0.0.255.255 any
access-list 109 deny ip 127.0.0.0 0.255.255.255 any
access-list 109 deny ip host 255.255.255.255 any
access-list 109 deny ip host 0.0.0.0 any
access-list 109 deny ip any any log
access-list 110 remark auto generated by SDM firewall configuration
access-list 110 remark SDM_ACL Category=1
access-list 110 permit udp host 194.239.134.83 eq domain host
87.50.196.58
access-list 110 permit udp host 193.162.153.164 eq domain host
87.50.196.58
access-list 110 deny ip 50.10.10.0 0.0.0.255 any
access-list 110 permit icmp any host 87.50.196.58 echo-reply
access-list 110 permit icmp any host 87.50.196.58 time-exceeded
access-list 110 permit icmp any host 87.50.196.58 unreachable
access-list 110 permit tcp any host 87.50.196.58 eq 443
access-list 110 permit tcp any host 87.50.196.58 eq 22
access-list 110 permit tcp any host 87.50.196.58 eq cmd
access-list 110 deny ip 10.0.0.0 0.255.255.255 any
access-list 110 deny ip 172.16.0.0 0.15.255.255 any
access-list 110 deny ip 192.168.0.0 0.0.255.255 any
access-list 110 deny ip 127.0.0.0 0.255.255.255 any
access-list 110 deny ip host 255.255.255.255 any
access-list 110 deny ip host 0.0.0.0 any
access-list 110 deny ip any any log
access-list 111 remark auto generated by SDM firewall configuration
access-list 111 remark SDM_ACL Category=1
access-list 111 permit tcp host 195.12.52.146 host 87.50.196.58 eq 22
access-list 111 permit tcp host 212.146.94.66 host 87.50.196.58 eq 22
access-list 111 permit tcp host 67.98.69.136 host 87.50.196.58 eq 22
access-list 111 permit tcp host 195.12.52.146 host 87.50.196.58 eq 443
access-list 111 permit tcp host 212.146.94.66 host 87.50.196.58 eq 443
access-list 111 permit tcp host 67.98.69.136 host 87.50.196.58 eq 443
access-list 111 permit tcp host 195.12.52.146 host 87.50.196.58 eq cmd
access-list 111 permit tcp host 67.98.69.136 host 87.50.196.58 eq cmd
access-list 111 deny tcp any host 87.50.196.58 eq telnet
access-list 111 deny tcp any host 87.50.196.58 eq www
access-list 111 deny tcp any host 87.50.196.58 eq cmd
access-list 111 deny udp any host 87.50.196.58 eq snmp
access-list 111 permit udp any host 87.50.196.61 range bootps bootpc
log
access-list 111 permit udp host 194.239.134.83 eq domain host
87.50.196.58
access-list 111 permit udp host 193.162.153.164 eq domain host
87.50.196.58
access-list 111 permit icmp any host 87.50.196.58 echo-reply
access-list 111 permit icmp any host 87.50.196.58 time-exceeded
access-list 111 permit icmp any host 87.50.196.58 unreachable
access-list 111 deny ip 50.10.10.0 0.0.0.255 any
access-list 111 deny ip 10.0.0.0 0.255.255.255 any
access-list 111 deny ip 172.16.0.0 0.15.255.255 any
access-list 111 deny ip 192.168.0.0 0.0.255.255 any
access-list 111 deny ip 127.0.0.0 0.255.255.255 any
access-list 111 deny ip host 255.255.255.255 any
access-list 111 deny ip host 0.0.0.0 any
access-list 111 deny ip any any log
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
access-class 102 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
--- Running config - END
Any help will greatly be appreciated
Regards
Ken
Posted by on June 30, 2006, 6:03 am
Ken wrote:
> Hi
> What I do is this.
> Speedstream modem.
I have had issues with ADSL line stability (lets call it)
with 857/877. The fix was a software upgrade.
I did though think that 12.4(4)T was OK.
What hapened with me was that the line would
go down every few hours and the ONLY recovery
was to power cycle the router. A reload did not fix it.
I am presently on 12.4(6)T which seems OK.
> interface ATM0
I have also had to manually set the
dsl operating-mode
On BT in the UK Ansi-dmt worked.
None of this though is necesasry with newer software.
Posted by chris on June 30, 2006, 11:57 am
> Hi
When it goes down do a "sh dsl int atm0" and post the results. You may be
clocking up DSL errors.
Chris.
> Hi
Chris.
Posted by Phil Dotchon on July 7, 2006, 4:00 pm
Ken,
I would guess you need to install the latest ADSL modem firmware in the
Cisco, I had issues with mine that were cured instantly.
You need a file called 'adsl_alc_20190_2_6_4.bin' which will be used in
place of the firmware embedded inside the IOS file, this was released on
7-6-2006: You will need a support agreement to get the file, or be within, I
think, 90 days of purchase!
The following issues are fixed in the latest firmware 2.6.4
1) CSCsd50555: No Sync on certain loops for ADSL2+ on 876 against Alcatel
7300 DSLAM
2) CSCsd50985: Lower Downstream performance against Alcatel 7300 DSLAM on
ADSL2+
3) CSCsd29021: Higher Downstream attenuation against Alcatel 7300 DSLAM on
ADSL2+
4) CSCsc02270 Attenuation values lower than expected
5) CSCsc14860 1801 Does not Sync up against Alcatel UD in ANSI-Mode
6) CSCsc94724 Unstable connection on 876 against DSLAM in Germany/DT
7) CSCsd05659 Attenuation higher than expected on 1801
8) CSCsd17532 1801 does not train up against Lucent DSLAM with 72 port
linecard
9) CSCsd17649 877 does not train up against SIEMENS HIX DSLAM for ADSL2+
10) CSCsd17712 877 does not train up against Marconi AHX-600 for ADSL2+
11)CSCsd29021 Higher DS attenuation against Alcatel with Broadcom Chipset
12) CSCsd50555 No Sync on certain loops for ADSL2+ on 876 against Alcatel
13) CSCsd50985 Lower DS Performance compared to Speedtouch against Alcatel
on ADSL2+
Cheers,
Phil Dotchon
CCIE 6632
> Hi
> What I do is this.
> Speedstream modem.
> changed state to up
> <ilmi_send_trap>
> trap
> was:
> trap (ATM0)
> trap (ATM0)
> trap (ATM0)
> trap (ATM0)
> trap (ATM0)
> trap (ATM0)
> Country: Denmark
> ISP: TDC
> ADSL: 4096/768
> !version 12.4
> no service pad
> hostname TMData
> boot-start-marker
> boot-end-marker
> no aaa new-model
> resource policy
> ip subnet-zero
> no ip source-route
> ip cef
> import all
> no ip bootp server
> ip ssh time-out 60
> application im msn
> audit-trail off
> application http
> audit-trail off
> 04050030
> 43657274
> 30303133
> 03132649
> 34303234
> 81890281
> 9EE8D130
> 41CBE254
> 96D08B9D
> 76833962
> 301B0603
> 03551D23
> 0603551D
> 092A8648
> AB724318
> CF7C223A
> 57BEEBF2
> BDC47487
> quit
> commented out
> commented out
> bridge irb
> interface Null0
> no ip unreachables
> interface ATM0
> no ip address
> no ip redirects
> no ip unreachables
> no ip proxy-arp
> ip route-cache flow
> ip mask-reply
> ip flow ingress
> ip flow egress
> ip nat outside
> pvc 0/101
> oam-pvc manage
> no ip address
> 36.0 48.0 54.0
> station-role root
> bridge-group 1
> interface Vlan1
> no ip address
> bridge-group 1
> interface BVI1
> no ip redirects
> no ip unreachables
> no ip proxy-arp
> ip nat inside
> ip classless
> ip http server
> configuration
> configuration
> 87.50.196.58
> 87.50.196.58
> telnet
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> 87.50.196.58
> log
> 87.50.196.58
> 87.50.196.58
> no cdp run
> control-plane
> bridge 1 route ip
> line con 0
> login local
> no modem enable
> line aux 0
> login local
> line vty 0 4
> access-class 102 in
> privilege level 15
> login local
> end
> Regards
> Ken
Similar ThreadsPosted
Cisco 877W, fixed IP, ISP connection drops June 30, 2006, 2:37 am
506E Drops Connection August 6, 2007, 4:32 pm
Connection issues, drops off after 2 minutes May 1, 2006, 9:04 pm
Switch randomly drops connection to port March 20, 2007, 12:09 pm
PIX v 7.2(1) embryonic session limit connection drops June 28, 2007, 4:14 am
FIXed IP and DHCP IP September 28, 2005, 6:00 am
Cisco ASA L2 Decode Drops May 24, 2008, 2:25 am
1711 - remove fixed WIC card? September 20, 2005, 6:55 pm
seting a fixed IP address for VPN clients November 21, 2006, 8:30 pm
Cisco 3640 T1 Interface Drops July 10, 2006, 4:55 pm
Sporadic line drops every 20 seconds or so using Cisco 585 LRE September 24, 2005, 9:16 pm
NAT type of Cisco 877W November 26, 2005, 8:14 pm
Using IPv6 on a Cisco 877W October 21, 2006, 10:52 am
Bridging with a Cisco 877W December 21, 2006, 1:11 pm
Cisco 877W of 857W ? May 23, 2008, 10:28 am
