Cisco Systems Cisco 877 cabling
Subject Author Date
Cisco 877 cabling Andre Wisniewski 06-03-08
---> Re: Cisco 877 cabling Markus Marquard...06-03-08
  ---> Re: Cisco 877 cabling Andre Wisniewsk...06-03-08
Posted by Andre Wisniewski on June 3, 2008, 2:25 am
Hi all
I've some questions regarding cabling my Cisco 877 to my DSL line. Router gets
not in
sync whereas my fritz.box is in sync within seconds.
Is it possible to connect my Cisco to my splitter or has it to be connected
directly
to my line?
If it's possible what is the pin layout? In this case i have to use another
cable
than the delivered magenta one. The magenta one has two RJ11 plugs whereas my
splitter has a RJ45 jack.
Thanks in advance
Andre
Posted by Markus Marquardt on June 3, 2008, 5:15 am
Are you aware of the fact, that the Cisco 877 has a ADSL over POTS
modem? That means on nearly all lines in Germany it won't work.
For details see:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976.html
Especially:
876: ADSL over ISDN (ADSL2/ADSL2+ Annex B)
877: ADSL over analog telephone lines (ADSL2/ADSL2+ Annex A and Annex M)
Even if you have only an analog line, the Annex B is used in Germany.
> connected directly to my line?
You have to connect the Cisco router to the splitter.
Only the inner two pins are used. If you use the RJ11 cable, it should
work as the other pins are unused anyway.
With kind regards
Markus
Posted by Andre Wisniewski on June 3, 2008, 8:32 am
> For details see:
> Especially:
So, i have to use 876 instead of 877 even though i have an analog line?
Thought so.
I was right with that, too.
> With kind regards
> Markus
Posted by Markus Marquardt on June 3, 2008, 10:18 am
Yes, i think so. You could check which standard is used by the Fritzbox
which works (maybe there's a label or something on it) - i guess it is
Annex B (ADSL over ISDN). If so, the Cisco device must be the same type
- in your case the 876.
With kind regards
Markus
Posted by Markus Marquardt on June 3, 2008, 10:26 am
Just an addition, please see
http://de.wikipedia.org/wiki/Annex_A
Especially the text related to "Verbreitung":
Germany is the only country where only Annex B is used - regardless if
you have an ISDN or analog line.
With kind regards
Markus
Similar ThreadsPosted
Cisco PIX 501 and cabling September 3, 2007, 6:14 am
Cisco 877 cabling June 3, 2008, 2:25 am
Console Cabling Problems October 14, 2005, 10:49 am
Gigastack Cabling on 3550 November 2, 2005, 9:31 am
async 16a / cabling for patchbay February 13, 2006, 7:45 am
IPS 4240 cabling question November 16, 2005, 9:14 am
E1 Cabling for VWIC2-2MFT-T1/E1 April 22, 2008, 9:42 am
Business VoIP Solutions Using Cisco Gateways, Cisco Call Agent, And Cisco IP Phones October 2, 2007, 8:02 pm
Discussion about segregating bandwidth with Cisco 7513, Cisco 3750 and Cisco 3640 June 17, 2006, 8:34 am
good cisco and juniper IPS site for intrusion prevention and cisco switch info January 5, 2007, 4:59 pm
Re: Q: Cisco AP 1131 -- "Unsupported device type" error in Cisco Network Assistant November 27, 2007, 1:19 pm
Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable August 15, 2008, 6:40 am
Re: Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable August 15, 2008, 7:32 am
Cisco 2970 strange traffic problem - stumped cisco support February 10, 2005, 12:19 pm
Cisco Custom Historical Report for Cisco Customer Response Applications January 17, 2006, 12:34 pm
