Cisco Systems Cisco 877 - Policy Map
Subject Author Date
Cisco 877 - Policy Map Darren Green 12-11-06
Posted by Darren Green on December 11, 2006, 1:59 pm
I have an 877 router on which there is a simple policy-map:
class-map match-any Premium
match access-group 100
policy-map Outbound
class Premium
priority 50
set ip dscp ef
my access-list 100 permits the local LAN subnet to an importnant server IP
address.
I have applied the policy-map to my ATM0 interface as follows:
interface ATM0
bandwidth 288
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
service-policy output Outbound
If I ping from the router (source vlan1) to the relevant IP address I
receive hits on Packets Marked (at the bottom of the policy). If I ping from
a LAN host to the same IP the Packets Marked do not increment. Does anyone
know why this is / alternatively, can anyone provide a sample config. Should
I be using a Virtual-Template on the ATM ?
Class-map: Premium (match-any)
15011 packets, 4691581 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 100
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 136
Bandwidth 50 (kbps) Burst 1250 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
QoS Set
dscp ef
Packets marked 1217
Regards
Darren
Posted by www.BradReese.Com on December 11, 2006, 3:29 pm
Hi Darren,
You may wish to investigate the Cisco 877 Config Wizard:
http://www.ifm.net.nz/cookbooks/800-isr-wizard.html
Sincerely,
Brad Reese
http://www.BradReese.Com
Posted by Matthias Scheler on December 11, 2006, 5:53 pm
The policy-map must be attached to the interface which handles the
outgoing IP traffic, probably "Dialer0".
        Kind regards
Matthias Scheler http://zhadum.org.uk/
Similar ThreadsPosted
Cisco 877 - Policy Map December 11, 2006, 1:59 pm
Service Policy issue on Cisco 828 October 25, 2005, 2:48 am
Cisco VPN v3.5.3 - Cannot match policy entry December 1, 2005, 10:01 pm
Cisco ASA NAT certain IP range conflict the default policy July 12, 2006, 7:43 pm
How to deploy Cisco VPN Client 4.6 through AD Group Policy? July 7, 2005, 2:22 am
Deploying Cisco VPN Client with Group Policy November 13, 2006, 12:55 pm
Deploying cisco vpn client software via group policy September 29, 2007, 6:29 pm
Policy Based Routing on Cisco L3 Switch 3550 with IOS 12.1(22) April 30, 2008, 11:48 am
Cisco Security Manager, how does the policy manager handle precedence? September 18, 2007, 12:34 pm
PIX Policy-NAT October 17, 2005, 10:50 am
Policy NAT October 15, 2007, 9:06 am
GRE & Policy Routing July 28, 2005, 8:46 am
Service Policy October 13, 2005, 7:41 am
ASA Policy NAT Question September 14, 2006, 9:12 am
ASA Policy NAT not working at all... September 14, 2006, 11:58 am
