Cisco Systems Cisco 876 & CPU Load
Subject Author Date
Cisco 876 & CPU Load Marco Buchholz 09-04-08
Posted by Marco Buchholz on September 4, 2008, 6:13 am
Hello at all,
i´ve a problem with the cisco 876 integrated services router.
The router´s ios-version is 12.4(11)T4 and it has a ADSL2+ (16 Mbit
downstream  / 1 Mbit upstream) connection.
If i start a download via http (or any other protocol), the cpu load
still remains at 100% until the download ends ...
Are there any solutions for this problem or has anybody the same
problems with this router. I´ve tried other ios-images, but the problem
is still the same.
Greetz, Marco
Posted by News Reader on September 4, 2008, 11:03 am
Marco Buchholz wrote:
Perhaps this relates to your choice of switching paths (particularly if
you were using process switching).
Have you enabled CEF globally, and Fast Switching on the interfaces?
e.g.:
ip cef
interface FastEthernet0
  ip route-cache flow
If the problem relates to your choice of switching paths, you might
search for documents with the following titles on the Cisco web site:
- How to Choose the Best Router Switching Path for Your Network
- Performance Tuning Basics
Best Regards,
News Reader
Posted by Uli Link on September 9, 2008, 3:20 am
Marco Buchholz schrieb:
Try IOS 12.4(6)T11 or 12.4(9)T7 instead.
There was a 30 percent CPU usage increase for the 870 routers with
12.4(11)T according to
<http://www.cisco.com/en/US/docs/ios/12_4t/release/notes/124TFEAT.html#wp1533957>
Disable the IPS feature.
Try to disable the http inspection rule and use the generic tcp
inspection instead if looking for less CPU usage.
Also 12.4(15)T6 is worth a trial (I don't use the newer T7, as I found
serious tracebacks in the T7 rebuild)
ULi
Similar ThreadsPosted
Load Balancing / Load Sharing over parallel paths November 21, 2005, 9:14 am
Cisco 876 & CPU Load September 4, 2008, 6:13 am
Cisco for load balancing w/o BGP October 11, 2006, 12:14 pm
server load balancing using a cisco July 14, 2005, 9:34 am
High CPU load on Cisco 877 and 878 while downloading November 12, 2006, 11:17 am
Load Balance with Cisco ISR 1801 December 5, 2007, 5:45 pm
Unable to load Cisco 350AP Firmware June 21, 2006, 7:05 pm
configure cisco load balancing with daul isp May 20, 2007, 6:46 am
[Cisco ISR 1800] Load Balance over two xDSL November 20, 2007, 6:11 pm
Cisco CSS load balance weighted round-robin perl script February 13, 2007, 9:30 pm
Failover and Load balancing with 1 Cable connection and one T1 connection on Cisco 2801 router November 13, 2006, 2:23 pm
Load Balancing Multiple Cisco Routers with Multiple ADSL circuits May 1, 2007, 5:39 am
Load Balancing February 15, 2005, 6:13 pm
load-balancing t1s August 30, 2005, 2:54 pm
BGP Load Sharing November 30, 2005, 10:27 am
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
