Cisco Systems Cisco 851 firewall woes
Subject Author Date
Cisco 851 firewall woes vorpus 05-05-08
Posted by on May 5, 2008, 8:28 pm
I'm having a massive problem with my Cisco 851. I'm brand new to Cisco
and the IOS and will actually be attending some technical training in
the coming days. In the meantime, though, I am unable to use the built-
in firewall.
Using the SDM, here is the error I get when using the basic firewall
wizard:
Submitting 99 commands, please wait...
class-map type inspect match-any sdm-cls-insp-traffic
Error detected at this command. Click OK
When I connect to the router via the console, this is what it tells
me:
vorpalrouter#conf t
Enter configuration commands, one per line. End with CNTL/Z.
vorpalrouter(config)#class-map ?
% Unrecognized command
Any idea why this is happening? Is there any other way I can lock down
ports?
Posted by Peter on May 6, 2008, 3:42 am
Greetings,
> me:
> vorpalrouter#conf t
Without more info its hard to say exactly, but the error message
suggests to me that the version of IOS you are using does not include
that command (and that command is not firewall specific).
Using the CLI, post the output of the "sh ver" command. This will tell
us the H/W and S/W details of what is in your Router.
> Is there any other way I can lock down ports?
If you really do have the Firewall IOS (which I doubt, we need to see
the the above output to be able to tell), then by default everything
already IS shut down.
Cheers.......................pk.
Peter from Auckland.
Posted by on May 6, 2008, 1:20 pm
> Greetings,
> > me:
> > vorpalrouter#conf t
> > Enter configuration commands, one per line. =A0End with CNTL/Z.
Hmmm. Not shut down in my experience.
But then I usually blow away the SDM default
anyway.
You need the following.
Deny EVERYTHING inbound
Use inspect to allow "returning traffic" back in.
Of course you can then add exceptions to the
inbound block as required if you were publishing serviices
to the internet.
ip inspect name sunshine tcp
ip inspect name sunshine udp
ip inspect name sunshine icmp
!! Add the following if you require/want:-
ip inspect name sunshine ftp
ip inspect name sunshine http
ip inspect name sunshine tftp
ip inspect name sunshine netshow
ip inspect name sunshine realaudio
ip inspect name sunshine sip
ip inspect name sunshine skinny
ip inspect name sunshine rtsp
ip inspect name sunshine streamworks
interface ATM0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0.1 point-to-point
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
ip address <removed>
ip access-group inbound in
ip inspect sunshine out
ip access-list extended inbound
deny ip any any
Posted by Uli Link on May 6, 2008, 4:06 pm
The 850 series routers only comes with advsecurity IOS (which includes
the Firewall featureset)
Uli
Posted by Charles N Wyble on June 3, 2008, 3:20 am
What feature packs? What version?
class-map ? works for me.
Cisco 1841 running
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.3(8)T4,
RELEASE SOFTWARE (fc2)
<host>(config)#class-map ?
WORD class-map name
match-all Logical-AND all matching statements under this classmap
match-any Logical-OR all matching statements under this classmap
I'm not an expert on the different cisco lines so maybe the 851 doesn't
support what you want?
You should check the release notes and feature matrix for your router.
Charles
> in firewall.
> wizard:
> me:
> vorpalrouter#conf t
> ports?
Similar ThreadsPosted
Cisco 851 firewall woes May 5, 2008, 8:28 pm
Cisco 7912 IP Phone PoE woes August 9, 2006, 10:32 am
Cisco PIX woes with MS Cert Service on Windows 2000 August 25, 2006, 7:09 am
Dynamic DNS woes January 7, 2006, 1:11 pm
Multicast woes January 30, 2006, 4:18 pm
AAA authentication woes April 27, 2006, 6:22 am
E-Mail Woes to Mailsweeper on PIX DMZ October 13, 2006, 2:53 pm
Is Cisco PIX Application level firewall or Packet level firewall? October 14, 2005, 2:15 pm
2801 power supply woes... December 6, 2006, 6:56 am
AP1310, adding a new one to an existing setup woes May 30, 2006, 5:51 am
Increasing data transfer on a firewall to firewall vpn connection June 14, 2005, 5:33 pm
Cisco PIX 501 Firewall September 3, 2006, 1:23 pm
Cisco PIX 501 Firewall. December 18, 2006, 3:39 pm
Cisco PIX 520 Firewall. August 7, 2007, 7:43 pm
Cisco IOS Firewall Software August 30, 2005, 3:25 pm
