Cisco Systems Cisco 851/%SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed
Subject Author Date
Cisco 851/%SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed VAXman- 12-26-08
Posted by on December 26, 2008, 10:28 am
First time posting here.
I have a new Cisco 851 router. Like clockwork, every 4 days I find the
following in the SYSLOG on my main server:
Dec 25 15:44:48 Cisco 000064: *Dec 25 09:54:01.476 PCTime: %SYS-2-MALLOCFAIL:
from 0x8011A088, alignment 32
Dec 25 15:44:48 Cisco 69: Pool: Processor Free: 79776 Cause: Memory
fragmentation
Dec 25 15:44:48 Cisco 70: Alternate Pool: None Free: 0 Cause: No Alternate pool
Dec 25 15:44:48 Cisco 71:
Dec 25 15:44:48 Cisco 72: -Process= "ARP Input", ipl= 0, pid= 8
Dec 25 15:44:48 Cisco 73: -Traceback= 0x8054EE44 0x800F750C 0x800FD13C
0x8011A08C 0x803A69B4 0x807036A4 0x808F7C30 0x808F8250
0x808F8EDC 0x803B2F54 0x800DDF38 0x800E11F8
Dec 25 15:44:49 Cisco 74: 000065: *Dec 25 09:54:01.476 PCTime: %FIB-3-NOMEM:
Malloc Failure, disabling CEF
Dec 25 15:44:49 Cisco 75: -Traceback= 0x8054EE44 0x803A69FC 0x807036A4
0x808F7C30 0x808F8250 0x808F8EDC 0x803B2F54 0x800DDF38
0x800E11F8
As you can see, I received a Christmas present yesterday.
I've searched the Cisco support forums and I've googled this error, and I
have not found any real solution. When this happens, the router is inac-
cessible and has to be reloaded from the serial console or power-cycled.
Can anyone here offer a clue or solution? I am no IOS power user either,
so please reply with cogent instructions.
Thanks.
VAXman- A Bored Certified VMS Kernel Mode Hacker VAXman(at)TMESIS(dot)ORG
"Well my son, life is like a beanstalk, isn't it?"
Posted by bod43 on December 26, 2008, 6:51 pm
On 26 Dec, 15:28, VAXman- @SendSpamHere.ORG wrote:
> Hi,
> I have a new Cisco 851 router. =A0Like clockwork, every 4 days I find the
> Dec 25 15:44:48 Cisco 000064: *Dec 25 09:54:01.476 PCTime: %SYS-2-MALLOCF=
> =A0from 0x8011A088, alignment 32
> Dec 25 15:44:48 Cisco 69: Pool: Processor =A0Free: 79776 =A0Cause: Memory=
fragmentation
> Dec 25 15:44:48 Cisco 70: Alternate Pool: None =A0Free: 0 =A0Cause: No Al=
ternate pool
> Dec 25 15:44:48 Cisco 72: -Process=3D "ARP Input", ipl=3D 0, pid=3D 8
> Dec 25 15:44:48 Cisco 73: -Traceback=3D 0x8054EE44 0x800F750C 0x800FD13C =
> =A00x808F8EDC 0x803B2F54 0x800DDF38 0x800E11F8
> Dec 25 15:44:49 Cisco 74: 000065: *Dec 25 09:54:01.476 PCTime: %FIB-3-NOM=
EM: Malloc Failure, disabling CEF
> Dec 25 15:44:49 Cisco 75: -Traceback=3D 0x8054EE44 0x803A69FC 0x807036A4 =
> =A00x800E11F8
> have not found any real solution. =A0When this happens, the router is ina=
c-
> Can anyone here offer a clue or solution? =A0I am no IOS power user eithe=
r,
> Thanks.
Obviously - the router has exhausted its memory.
If you check with sh mem
router#sh mem
Head Total(b) Used(b) Free(b) Lowest(b)
Largest(b)
Processor 83099124 70676188 27469044 43207144
40316708 38171256
I/O 7400000 12582912 3925532 8657380
8530336 8537212
and worry about the Processor, free, lowest, largest
and also compare how that changes in time against
sh proc mem entries per process
you may be able to work out which process is capturing all of the
memory.
Since you have already been notified that an ARP
process is the one failing the allocation I would check that
you are not doing proxy arp on your internet facing
interface, or for that matter on th inside interface.
int fa 4 ! If I recall correctly
no ip proxy-arp
If none of this makes any sense post
sh proc mem
over several intervals before the router crashes.
Posted by on December 26, 2008, 7:35 pm
>> Hi,
> fragmentation
>ternate pool
>> =A00x800E11F8
>c-
>r,
>> Thanks.
>router#sh mem
>Largest(b)
>40316708 38171256
>8530336 8537212
>memory.
>no ip proxy-arp
I have this on Interface FastEthernet4 as well as Vlan1.
>sh proc mem
I'll try.
I found one discussion about this and added some arp timeout values that
should free up the cached translations, I hope. I set FastEthernet4 to
300 seconds and Vlan1 to 900 seconds. I'll be watching the memory over
the next couple of days.
Any other suggestions, I'm all ears at this point having pretty much ex-
hausted other paths.
Posted by on December 26, 2008, 8:43 pm
writes:
>>> Hi,
>> fragmentation
>>ternate pool
>>> =A00x800E11F8
>>c-
>>r,
>>> Thanks.
>>router#sh mem
>>Largest(b)
>>40316708 38171256
>>8530336 8537212
>>memory.
>>no ip proxy-arp
>>sh proc mem
>I'll try.
I found it. I removed:
# ip route 0.0.0.0 0.0.0.0 FastEthernet4
and replaced it with:
# ip route 0.0.0.0 0.0.0.0 24.xx.yy.zz (IP address up upstream router,)
I removed the timeouts that I had installed too.
# show process memory 8
has shown a rock steady memory use now at 7176 bytes.
Similar ThreadsPosted
Cisco 851/%SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed December 26, 2008, 10:28 am
Ratio of Bytes Delayed to Bytes Sent December 21, 2005, 3:08 pm
Convert bytes to MB on cisco router March 29, 2006, 3:59 pm
MTU less than 1500 bytes on Cisco layer 3 switch October 25, 2005, 7:18 am
Address Allocation Q May 27, 2006, 9:57 am
MICA modems allocation on AS5300 February 26, 2006, 5:04 am
ACS / C1220 APs / VPN 3000 Conc: IP addr allocation for VPN but notfor 802.1X possible? July 19, 2005, 4:09 pm
3620 memory requirements exceed available memory March 31, 2008, 10:58 am
Error : memory requirements exceed available memory April 3, 2008, 9:00 pm
Multiple router eigrp 65536 - can't delete or edeit July 19, 2007, 4:48 pm
PIX VPN tunnel 0 bytes TX! July 28, 2006, 4:40 am
Cisco Assertion Failed Error April 17, 2007, 10:33 am
cisco 340AP: Failed "Too Many Stations in BSS" May 24, 2008, 3:37 pm
Input & Output bytes question April 23, 2007, 8:24 pm
Priority Queue - Bytes, Kilobits Etc October 8, 2007, 12:16 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
