Cisco Systems Cisco 3640 and WIC-1ADSL
Subject Author Date
Cisco 3640 and WIC-1ADSL carey.heck 05-19-06
Posted by on May 19, 2006, 1:35 pm
Hi there. I have a 3640 running enterprise plus 12.4(8) that won't see
a WIC-1ADSL card.
The WIC card is inserted into a NM 2E 2W Network Module, along with a
WIC-1T1DSU. I have swapped WIC slots, and tried booting just with the
ADSL WIC, no luck.
The card is a known good, since it lights up to OK in a 2611.
Am I missing something here?
Any and all help is appreciated.
Thanks
Check
Posted by on May 19, 2006, 2:45 pm
Wow found my answer. The Network Module does not support the
WIC-1ADSL. Wierd.
Note: For the Cisco 3600, ADSL is not supported on WIC NM-1E1R2W,
NM-1E2W, or NM-2E2W
Oh well, off to ebay I go.
Posted by R. Koops on May 19, 2006, 5:48 pm
> NM-1E2W, or NM-2E2W
You can use a NM-2FE2W module. It works for me:
router#show diag
Slot 0:
NM-2FE2W Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-04797-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 05
PCB Serial Number : JAD0626CFJD
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : NM-2FE2W=
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01
0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30
0x20: 36 32 36 43 46 4A 44 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
DSL SAR (ADSL)
Hardware Revision : 2.2
Part Number : 73-4771-07
Board Revision : A0
Fab Version : 05
PCB Serial Number : JAB05370J1A
RMA History : 00
Product (FRU) Number : PA-1C-P=
0x00: 04 FF 40 00 2E 41 02 02 82 49 12 A3 07 42 41 30
0x10: 80 00 00 00 00 02 05 C1 8B 4A 41 42 30 35 33 37
0x20: 30 4A 31 41 03 00 81 00 00 00 00 04 00 FF FF FF
Posted by Wayne on May 20, 2006, 12:10 am
> WIC-1ADSL. Wierd.
> NM-1E2W, or NM-2E2W
Not surprising at all. The NM-xE cards are old, proabably EOL, while ADSL
WICs are pretty new.
Posted by rick on May 22, 2006, 1:52 pm
These are the NM's that support the WIC-1ADSL:
NM-2W
NM-1FE2W
NM-1FE2W-V2
NM-2FE2W
NM-2FE2W-V2
NM-1FE1R2W
NM-1FE1R2W-V2
I have:
1 x NM-1FE2W USED @ $450
4 x NM-1FE1R2W USED $425/each [equivalent use as NM-
1FE2W]
20 x NM-2FE2W USED @ $700/each
ALL GUARANTEED to be REAL, CISCO ORIGINAL. NO
counterfeits! Let me know if you need anything
* We buy and sell networking equipment. Please contact
me if you have any offers or are interested in
purchasing. *
Thanks,
Rick Truong
TruTech Systems
Office: 951.696.3688
Mobile: 951.440.8711
AIM: ricktrutek
E-Mail: rick at trutechsystems dot net
Posted with NewsLeecher v2.0 Final
* Binary Usenet Leeching Made Easy
* http://www.newsleecher.com/?usenet
Similar ThreadsPosted
Cisco 3640 with NM-4T1-IMA October 9, 2006, 10:44 pm
Discussion about segregating bandwidth with Cisco 7513, Cisco 3750 and Cisco 3640 June 17, 2006, 8:34 am
Cisco 3640 MFR Setup HELP!!! September 6, 2005, 5:00 pm
Cisco 3640 and WIC-1ADSL May 19, 2006, 1:35 pm
Upgrading Cisco 3640 June 12, 2006, 7:43 pm
How do I add a user to Cisco 3640 October 20, 2006, 2:02 pm
Bridge on two cisco 3640 June 20, 2007, 1:45 am
Cisco 3640 DS3 Config December 18, 2007, 11:54 am
Upgrading flash -> 32 mb. Cisco 3640 July 22, 2005, 6:56 pm
CISCO 3640 not showing all DRAM September 9, 2005, 4:07 pm
Cisco 3640 T1 Interface Drops July 10, 2006, 4:55 pm
Cisco 3620 or 3640 for CCNA. June 18, 2007, 3:24 am
Cisco 3640 support Vpls ? June 20, 2007, 2:55 am
SLB on Cisco 3640, any good experience? July 1, 2007, 1:05 am
Made a mistake Cisco router 3640 September 21, 2005, 8:39 pm
