Posted by Chris on June 12, 2006, 7:30 pm
I have always had my 3640 doing NAT. Now I want to let the ISP's
routers that I am connected to do it.
My internal network is 192.168.144.96/27 is my 3640 VLAN1
My external networks are:
192.168.1.0/29 ISP1 192.168.1.1 is a router doing nat or it can be
configured with Public IPs.
192.168.0.0/29 ISP2 192.168.0.1 is a modem doing nat or it can be
What I need to know is how do I get the VLAN traffic to the ISP's
routers without doing NAT on th 3640?
I have read a little on bridging and it seems like that may be what I
need, but I am not sure.
The reason I am doing this is because it is my understanding that NAT
is completely process switrched and with the current bandwidth that I
have available the 3640 can't process switch that many packets.
If I am in error and NAT does not have to be processed switched, I
would be interested in hearing any input on how to no process switch
NAT.
Thanks in advance for any help or advice.
| Similar Threads | Posted |
| Cisco 3640 Config NM-16sw Internal Lan Ethernet to Cable Router doing NAT | June 12, 2006, 7:30 pm |
| Which Dual ethernet Cisco router for Cable modem <--> LAN ? | February 9, 2005, 9:37 pm |
| Cisco 3640 NM-4E Westell ADSL Modem & Ambit Cable Modem/Router Half 1/2 Speed | June 4, 2006, 3:38 pm |
| Cisco 3640 DS3 Config | December 18, 2007, 11:54 am |
| Basic Config help needed 1841 Router 2 ethernet | February 15, 2007, 5:04 am |
| 3640 Optimized Edge Routing and Ethernet Bridge BVI | June 18, 2006, 7:13 am |
| Cisco 1700 Config not able to processing internal webmail script | October 21, 2007, 8:31 pm |
| Made a mistake Cisco router 3640 | September 21, 2005, 8:39 pm |
| Made a mistake Cisco router 3640 | September 21, 2005, 8:40 pm |
| Pix 506e w/5 static outside IPs - How to create a rule to allow ALL tcp/udp traffic from one outside IP to an internal IP (for an internal router/NAT with it's own subnet) | April 6, 2008, 3:39 pm |
| Which cable(s)? Madge AccessSwitch 20 and Cisco router | November 13, 2008, 9:08 pm |
| Upgrading the Cisco IOS on Cisco router 3640. | July 27, 2007, 8:43 pm |
| Use router ethernet interface as a layer 2 ethernet port | November 24, 2006, 7:53 pm |
| Cisco 2801 router Advanced IP services and HWIC Cable-D-2 | December 11, 2006, 10:24 am |
| Speed/Throughput Issues ADSL/Cable Modem to Cisco Router | June 6, 2006, 10:08 am |
