Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Houston SBC on October 2, 2007, 4:45 pm
installed. Does anyone have the foggiest idea of how to get fa0/0 to share a vlan with fa0/0/0-3 (the ports on the HWIC-4ESW). Any config files, urls, etc would be greatly appreciated. Appendix D of the Cisco Field Manual: Catalyst Sw. Config covers "Extending VLANs within Layer 3 switches" and seems to be close but it shows a 802.1Q trunk line from the layer3 device to the layer 2 device--How's it handled when it is in the same box? TIA Doug Dougs@(8888nospam!!!!)Net-fix.com | |||||||||||||||||||
Posted by response3 on October 3, 2007, 8:24 pm
Please log in for more thread options Can't do it, since the built-in port is layer 3 only, and is not capable of running in layer 2 mode. It can only route traffic for vlan's but not act as an access port to a vlan. | |||||||||||||||||||
Posted by Mike Dorn on October 4, 2007, 12:31 am
Please log in for more thread options Houston SBC wrote:
> I have a Cisco 2811 running IOS adventerprisek9-mz.12.4-15.T and a HWIC-4ESW
Actually, I did this just yesterday with a 2811 and the 9-port switch module. I
> installed. > > Does anyone have the foggiest idea of how to get fa0/0 to share a vlan with > fa0/0/0-3 (the ports on the HWIC-4ESW). > > Any config files, urls, etc would be greatly appreciated. > > Appendix D of the Cisco Field Manual: Catalyst Sw. Config covers "Extending > VLANs within Layer 3 switches" and seems to be close but it shows a 802.1Q > trunk line from the layer3 device to the layer 2 device--How's it handled > when it is in the same box? > > TIA > > Doug > Dougs@(8888nospam!!!!)Net-fix.com > > > eventually tore it back down again because it ate up cpu and it wasn't all that essential for me to have the other interface. What you have to do is turn on bridging. Then you create a bridge virtual interface for the router to use instead of the vlan interface that connects to the switch module. Join both the vlan interface from the switch and the physical interface from the ouside of the router into the bridge group, and they're together. bridge irb int fa0/0 no ip address bridge-group 1 int bvi 1 ip address x.x.x.x y.y.y.y int vlan 3 bridge-group 1 int fa0/0/2 switchport access vlan 3 bridge 1 protocol ieee bridge 1 route ip What I did was similar, except that I was making my fa0/0 into a trunk to reach external switches, so each dot1q subinterface under it was linked to a separate bridge group. The 9-port module was then configured with one vlan for data and the other for voice to support ip phones. When I had it working, however, it chewed up 10-30% cpu with almost no traffic load. Shut down fa0/0, got rid of the bvi's and made the 9th port on the module into a trunk instead, and cpu ran about 1-2%, so that's where I'm leaving it. My guess would be that the bvi's are implemented in software, so don't optimize as well. Of course, your situation may require you to use the other ports, so go ahead & try it. I haven't messed with bridging on routers all that much, so it's also possible that I missed something--the cpu hit may be avoided by application of slightly cleverer code... | |||||||||||||||||||
Posted by Houston SBC on October 4, 2007, 6:37 am
Please log in for more thread options First, thanks for the info. Cisco docs are somewhat lacking in certain
areas. It is always nice to see someone else going where no one else has gone before. Doug > Houston SBC wrote:
>> HWIC-4ESW installed. >> >> Does anyone have the foggiest idea of how to get fa0/0 to share a vlan >> with fa0/0/0-3 (the ports on the HWIC-4ESW). >> >> Any config files, urls, etc would be greatly appreciated. >> >> Appendix D of the Cisco Field Manual: Catalyst Sw. Config covers >> "Extending VLANs within Layer 3 switches" and seems to be close but it >> shows a 802.1Q trunk line from the layer3 device to the layer 2 >> device--How's it handled when it is in the same box? >> >> TIA >> >> Doug >> Dougs@(8888nospam!!!!)Net-fix.com >> >> >> > Actually, I did this just yesterday with a 2811 and the 9-port switch
> module. I eventually tore it back down again because it ate up cpu and it > wasn't all that essential for me to have the other interface. > > What you have to do is turn on bridging. Then you create a bridge virtual > interface for the router to use instead of the vlan interface that > connects to the switch module. Join both the vlan interface from the > switch and the physical interface from the ouside of the router into the > bridge group, and they're together. > > bridge irb > int fa0/0 > no ip address > bridge-group 1 > int bvi 1 > ip address x.x.x.x y.y.y.y > int vlan 3 > bridge-group 1 > int fa0/0/2 > switchport access vlan 3 > bridge 1 protocol ieee > bridge 1 route ip > > What I did was similar, except that I was making my fa0/0 into a trunk to > reach external switches, so each dot1q subinterface under it was linked to > a separate bridge group. The 9-port module was then configured with one > vlan for data and the other for voice to support ip phones. When I had it > working, however, it chewed up 10-30% cpu with almost no traffic load. > Shut down fa0/0, got rid of the bvi's and made the 9th port on the module > into a trunk instead, and cpu ran about 1-2%, so that's where I'm leaving > it. My guess would be that the bvi's are implemented in software, so > don't optimize as well. Of course, your situation may require you to use > the other ports, so go ahead & try it. > > I haven't messed with bridging on routers all that much, so it's also > possible that I missed something--the cpu hit may be avoided by > application of slightly cleverer code... > | |||||||||||||||||||
| Similar Threads | Posted |
| mib for Cisco 2811 | October 31, 2005, 11:27 am |
| Cisco 2811 SDM | July 7, 2006, 7:31 am |
| Cisco 2811 and SIP, what do I need? | April 27, 2009, 10:08 am |
| Cisco 2811 max. troughput | May 9, 2006, 8:35 pm |
| IPSEC with a Cisco 2811? | May 3, 2007, 9:29 am |
| Cisco 2811 VPN NATting | May 24, 2007, 11:26 am |
| Cisco 2811 Easy VPN issue | October 4, 2005, 4:21 pm |
| Cisco 2811 Easy VPN issue | October 4, 2005, 4:22 pm |
| Cisco 2811 router max. troughput | January 15, 2007, 10:32 am |
| How to generate RSA key in CISCO Router 2811 | July 20, 2007, 4:51 am |
| Cisco 2811 with HWIC-4ESW | October 2, 2007, 4:45 pm |
| USB Sticks bigger than 256 MB for Cisco 2811 ? | August 23, 2008, 1:40 pm |
| cisco 2811 lan port config issues | January 26, 2006, 4:36 am |
| Interconnecting two pbx over CEoIP on Cisco 2610 and 2811 | December 15, 2006, 10:29 am |
| Intercionnecting two pbx over CEoIP on Cisco 2600 and 2811 | December 15, 2006, 11:49 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> installed.
> TIA
> Doug
