Cisco Systems Cisco 2811 and SIP, what do I need?
Subject Author Date
Cisco 2811 and SIP, what do I need? Peter Danes 04-27-09
Posted by Doug McIntyre on May 27, 2009, 12:50 pm
>I have both 2600 and 2600XM
The expanded DRAM on the 2600XM lets you run some of the later 12.4T
images before they dropped support for the 2600 routers altogether.
sip-ua authentication using username/password came in a relately
recent 12.4T image.
>It could be interesting that I set on the router the SIP user/pass
>and I can use some VOIP Phones on the lan and an analog phone directly
>connected via the router.
Sure, can be done with a voice IOS load, and stock setup.
>In the first case I'd need that the phones authenticate on the router
>directly?? (maybe) and in the latter case I need a voice port with RJ11
>plug.
Yes, the SIP phones would register with dial-peers on the router.
The voice port would also get configured with dial-peers.
Setup your dial plan, and it should all work.
Similar ThreadsPosted
mib for Cisco 2811 October 31, 2005, 11:27 am
Cisco 2811 SDM July 7, 2006, 7:31 am
Cisco 2811 and SIP, what do I need? April 27, 2009, 10:08 am
Cisco 2811 max. troughput May 9, 2006, 8:35 pm
IPSEC with a Cisco 2811? May 3, 2007, 9:29 am
Cisco 2811 VPN NATting May 24, 2007, 11:26 am
Cisco 2811 Easy VPN issue October 4, 2005, 4:21 pm
Cisco 2811 Easy VPN issue October 4, 2005, 4:22 pm
Cisco 2811 router max. troughput January 15, 2007, 10:32 am
How to generate RSA key in CISCO Router 2811 July 20, 2007, 4:51 am
Cisco 2811 with HWIC-4ESW October 2, 2007, 4:45 pm
USB Sticks bigger than 256 MB for Cisco 2811 ? August 23, 2008, 1:40 pm
cisco 2811 lan port config issues January 26, 2006, 4:36 am
Interconnecting two pbx over CEoIP on Cisco 2610 and 2811 December 15, 2006, 10:29 am
Intercionnecting two pbx over CEoIP on Cisco 2600 and 2811 December 15, 2006, 11:49 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
