Cisco Systems Cisco 2811 SDM
Subject Author Date
Cisco 2811 SDM jswharton 07-07-06
Posted by on July 7, 2006, 7:31 am
Ok the cisco 2811 has SDM installed all the relevant files are in
flash. when i connect via browser with login i get redirect to :
http://10.10.10.1/archive/archive:home/html/home_aux.shtml
"PAGE CANNOT BE FOUND"
what does this mean. All relevant files are in flash. There does not
appear to be any files in archive. The login has all the correct
priviledges or so I am led to believe.
Any suggestions help guidance would be greatly appreciated.
James
Posted by on July 7, 2006, 2:40 pm
I recently fixed a strange SDM issue where it
would not load due to the idle timeout being too low.
I don't know where it came from even but it was set to 5s.
You need:-
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
username your-username privilege 15 password your-password
Have you checked that your PC meets the requirements,
Java version, pop ups allowed etc?
If that does not fix it I would just re-install SDM. You may
well need a Cisco Login to download it.
Similar ThreadsPosted
mib for Cisco 2811 October 31, 2005, 11:27 am
Cisco 2811 SDM July 7, 2006, 7:31 am
Cisco 2811 and SIP, what do I need? April 27, 2009, 10:08 am
Cisco 2811 max. troughput May 9, 2006, 8:35 pm
IPSEC with a Cisco 2811? May 3, 2007, 9:29 am
Cisco 2811 VPN NATting May 24, 2007, 11:26 am
Cisco 2811 Easy VPN issue October 4, 2005, 4:21 pm
Cisco 2811 Easy VPN issue October 4, 2005, 4:22 pm
Cisco 2811 router max. troughput January 15, 2007, 10:32 am
How to generate RSA key in CISCO Router 2811 July 20, 2007, 4:51 am
Cisco 2811 with HWIC-4ESW October 2, 2007, 4:45 pm
USB Sticks bigger than 256 MB for Cisco 2811 ? August 23, 2008, 1:40 pm
cisco 2811 lan port config issues January 26, 2006, 4:36 am
Interconnecting two pbx over CEoIP on Cisco 2610 and 2811 December 15, 2006, 10:29 am
Intercionnecting two pbx over CEoIP on Cisco 2600 and 2811 December 15, 2006, 11:49 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
