Cisco Systems Cisco 2800 series router - PSTN gateway?
Subject Author Date
Cisco 2800 series router - PSTN gateway? response3 06-01-07
Posted by response3 on June 1, 2007, 5:39 pm
Hi all. I have a 2811 router that I'd like to get a little more usage
from. While the Cisco marketing is a little vague, I believe this
router can act as a PSTN to VOIP (on my LAN) gateway. Has anyone done
this, and if so, what is involved? Thanks all.
Brian
Posted by Doug McIntyre on June 2, 2007, 1:45 am
Yes, with the right cards and feature sets you can do lots of things.
The easier route probably is to start out with one of the VICs, like a
VIC-2FXO-M2 and a PVDM2 DSP card to stick into the box.
You'll have to run a Voice feature set too to pick it up.
The harder part then is to utilize it. A plain gateway is just that, a
gateway for something else to gateway to the POTS line.
The something else could be CCME on the box to turn it into a little
PBX if you also get some cisco IP phones (although the latest CCME
supports stock SIP phones now as well).
Or, maybe an asterisk system, or something that can take a dialplan
and route calls through the gateway.
Similar ThreadsPosted
Cisco 2800 series router - PSTN gateway? June 1, 2007, 5:39 pm
error on 2800 series router April 30, 2006, 10:02 am
Switch Redundancy for PIX or Router 2800 series in standby configuration February 28, 2008, 9:27 pm
Cisco 2800 and VOiP gateway integration September 12, 2006, 9:04 am
Cisco Hubs: 2800 and 400 series May 14, 2006, 5:37 pm
ADSL WIC 2800 Series November 17, 2006, 6:59 pm
3825 or 2800 series ? Any advice..? May 8, 2006, 10:40 am
Cisco Router 2800 problem May 21, 2006, 5:20 pm
VOIP GSM GATEWAY - HG-4000 SERIES August 26, 2005, 11:50 pm
A non-Cisco router, BDCOM 1700 Router Series June 28, 2008, 4:27 am
Cisco AS5400 as VoiP Gateway and Router November 14, 2005, 7:32 pm
Best way to Bond 2 PTP T1's on 2600/2800 router September 8, 2006, 8:23 pm
Cisco 2600 Series Router T1 Speeds December 3, 2005, 2:26 pm
Cisco 7200 Series Router Question April 23, 2006, 10:18 am
