Cisco Systems Cisco 2611 with old Ios installed - need to upgrade?
Subject Author Date
Cisco 2611 with old Ios installed - need to upgrade? trashcan 06-21-09
Posted by on June 21, 2009, 9:04 am
Hey,
I just got a rather old Cisco 2611 router with 2 10Base-T and one serial wic
installed.
After quite a time its the first cisco router I had to configure... so I'm
kind of outdated with those cisco's as the cisco itself I think...
All I want this 2611 to do is:
make a pppoe connection to a ADSL provider
make a dyndns update to be accessible even with a dynamic ip
do pat/nat on the internal network
forward two external ports to an internal server
make it accessible by ar BRI-ISDN (which isn't built in yet) from the
outside.
I don't know if the IOS which is installed does really support all this, so,
I really appreciate your help if it can do this with this version
cisco2611>sh ver
Cisco Internetwork Operating System Software
IOS (tm) C2600 Software (C2600-I-M), Version 11.3(4)T1, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Wed 01-Jul-98 11:48 by phanguye
Image text-base: 0x80008084, data-base: 0x80552544
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
cisco2611 uptime is 20 hours, 3 minutes
System restarted by reload
System image file is "flash:c2600-i-mz.113-4.T1", booted via flash
cisco 2611 (MPC860) processor (revision 0x202) with 18432K/6144K bytes of
memory.
Processor board ID JAB030908CE (2392022389)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
Thank you very much for your help,
Cheers,
Uli-G
Posted by Uli Link on June 21, 2009, 3:15 pm
trashcan@wopr.de schrieb:
> cisco2611>sh ver
> (fc1)
> memory.
> Bridging software.
No luck,
for dyndns you'll need at least IOS 12.4 Mainline or 12.3(14)T.
For PPPoE you'll need the PLUS feature set.
ULi
Posted by bod43 on June 22, 2009, 6:49 am
On 21 June, 23:22, trash...@wopr.de wrote:
> Uli Link wrote:
> > No luck,
> ...and more flash and dram I guess...
> Is at least pppoe available in any IOS Version where I don't have to upgr=
ade
> any hardware? I mean, its a rather old machine...
> Cheers,
No. It appears.
You will need an ADSL WIC and it looks like
you need extra RAM and FLASH.
This is in addition to the ISDN WIC.
The min quoted for ADSL support is
16M Flash
64M RDRAM
Your best idea might be to look on ebay for a suitable router.
2611 will probably have trouble keeping up with
an 8M dsl too.
http://cgi.ebay.com/CISCO-2650-ROUTER-FAST-ETHERNET-64D-32F-WIC-1BU-ISDN_W0=
QQitemZ140307917890QQcmdZViewItemQQptZCOMP_EN_Routers?hash=3Ditem20ab00ec42=
&_trksid=3Dp3286.c0.m14&_trkparms=3D65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7=
C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Everything here except ADSL WIC.
I have no knowledge of this seller and I am not
recommending this purchase.
Posted by Ulrich Gierschner on June 22, 2009, 11:59 am
bod43 schrieb:
> No. It appears.
Bummer...
Do I? I just guessed I could also use an ADSL Bridge on one of the
ethernet ports.
> 16M Flash
> 64M RDRAM
Maybe I'll try to get those on ebay somewhere...
Eer.. no.. I wanted to use *this* router for something useful and
because I got a third 1 mbit DSL account where I simply look for a pppoe
capable router to feed it into the main pfsense box.
So I thought ye'goode olde 2611 would do the trick just fine since I
don't expect really high performance...
> an 8M dsl too.
I thought 10 MBit wouldn't be a problem with this kind of cisco?
Does anyone know the original spare part numbers for cisco flash and dram?
thanks!
cheers,
Uli
Posted by Doug McIntyre on June 22, 2009, 3:44 pm
>ethernet ports.
That would work. I've done that sort of test.
>> 16M Flash
>> 64M RDRAM
eBay is sometime pricey. Someplace like MemoryX.net has things for
somewhat decent costs. Look there too, or other memory vendors like
Crucial, as well as eBay.
>> an 8M dsl too.
Not on a 2611. This router was designed to drive a T1 or two.
Cisco low-end routers are *really* slow throughput. You are buying
cisco for the name and the feature set and the reliability.
NOT for the throughput of them. :(
A stock 2611 I usually measure out at about 5-6Mbps throughput..
Check the MemoryX.net site. They'll list part #s, pictures, config
options, diagrams, etc. Its a simple format anyway, like MEM-2600-64M or so.
Similar ThreadsPosted
Cisco 2611 with old Ios installed - need to upgrade? June 21, 2009, 9:04 am
Upgrade 2611 IOS December 12, 2005, 3:32 pm
HELP WITH CISCO 2611 ARP December 20, 2006, 6:43 pm
Cisco 2611 NAT Configuration April 11, 2007, 4:03 pm
How to tell if PDM is already installed on a PIX? December 5, 2005, 12:06 pm
Cisco 2611, NAT, and Default Routes June 18, 2007, 11:00 pm
cisco 2611-dc power cable June 16, 2008, 11:29 am
Cisco 2611 router interface issues February 8, 2008, 5:42 pm
Connecting a Linksys port to a Cisco 2611 May 27, 2008, 11:11 am
Total installed RAM via SNMP? July 13, 2005, 7:00 am
problem with some sites after installed PIX-please help June 21, 2005, 3:12 pm
Cisco 2611 with Road Runner Business Class July 19, 2006, 5:23 pm
serial number of installed gbic/sfp January 31, 2006, 8:06 am
Replacement components on a Cisco 2611 mainboard (router go boom) June 16, 2006, 8:52 am
How to find out what kind of GBIC is installed in the CAT switch. March 1, 2006, 5:45 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
