Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Ingot on April 19, 2007, 1:30 pm
Please log in for more thread options First off, while I have significant experience in LAN's, I'm a complete newbie at WAN's, T1's, etc. Feel free to make fun of me. I'm in possession of a Cisco 2514 I bought quite awhile ago for practice/trial purposes. My work is currently in possession of two active T1 lines they are not using. (Don't ask, it's a long story involving bean-counters). It occurred to me there are several things I can do with those lines locally while waiting on official equipment, so I brought in my old 2514, and started researching things. Here's my problem. The 2514 has two Serial DB60 interfaces. It came with two cables labeled "CBL, Serial, V.35 DTE". They are 60 pin female on one side, and the other side is a large clunky connector with places for up to 34 pins. (M/34?) Question is... The T1 line from our demarkpoint to our server closet terminates in a RJ45 connector. While I think I could manage to configure a serial interface with a bit of help and advice, what I can't find anywhere on the net, is whether or not these serial interfaces can be used for this T1 line, and if so, what kind of cable I need to purchase to connect it. Any help, even the proper search words for google, would be appreciated. Thank you Ingot. | ||||||||||||||||
Posted by J.Cottingim on April 19, 2007, 2:14 pm
Please log in for more thread options to "talk" to on the other end) You'll need to plug the T1's into a DSU/CSU. The T1 would plug into the CSU, the CSU would then plug into the router via a serial cable. (to the DB-60 interfaces) The 2514 router you have is a fixed-configuration router - (no hardware options) If, for instance, you had a Cisco 2600, you could use a WIC-1DSU-T1 (has build-in CSU) and plug the T1 directly into the router. JC | ||||||||||||||||
Posted by Ingot on April 19, 2007, 2:49 pm
JC: So since the 2514 doesn't have a built in CSU, I'd need to buy one eh? I guess that makes sense, since the other routers I've worked with have been 2600's at least. That explains why I didn't recognize the interface. I bought it mainly for its two ethernet ports, way back when I needed to practice IP routing. Not much chance of me using it for a temporary router on a T1 line then, I can't afford $700 for a CSU. Thanks very much for the reply. Chris | ||||||||||||||||
Posted by Scooby on April 19, 2007, 3:18 pm
Please log in for more thread options >
>> hardware options) >> If, for instance, you had a Cisco 2600, you could use a WIC-1DSU-T1 >> (has build-in CSU) and plug the T1 directly into the router. >
> JC: > > So since the 2514 doesn't have a built in CSU, I'd need to buy one eh? > > I guess that makes sense, since the other routers I've worked with have > been > 2600's at least. That explains why I didn't recognize the interface. > > I bought it mainly for its two ethernet ports, way back when I needed to > practice IP routing. > > Not much chance of me using it for a temporary router on a T1 line then, I > can't afford $700 for a CSU. > > Thanks very much for the reply. > > Chris > > Ebay for Adtran TSU LT - these things are a dime a dozen and just what you are looking for. Nice low end unit. | ||||||||||||||||
Posted by Ingot on April 20, 2007, 8:18 am
> are looking for. Nice low end unit. That's very helpful of you. Thanks, I'll do that. Ingot | ||||||||||||||||
| Similar Threads | Posted |
| Cisco 2514 and serial cables | April 19, 2007, 1:30 pm |
| Serial Cables and setup ? | March 15, 2006, 3:45 pm |
| Newbie question re back-to-back serial cables | October 17, 2007, 1:33 pm |
| Cisco 2514 IOS Help | October 16, 2006, 7:33 pm |
| Cisco 2514 Upgrade Boot ROM ? | September 8, 2005, 11:53 am |
| upgrading Cisco 2514 from console | September 25, 2005, 2:31 am |
| Cisco CAB-530MT DTE RS-530 cables | October 19, 2005, 5:02 pm |
| 2514 NAT configuration on ADSL | March 11, 2006, 3:36 pm |
| How to unblock TCP port 42 across a 2514 | April 21, 2006, 10:58 am |
| 2503/2514 boot rom | January 5, 2007, 10:17 am |
| FS 2514 - Dual Ethernet Router | February 10, 2005, 6:55 am |
| UTP Cables | March 13, 2006, 8:52 am |
| Console Cables | January 7, 2008, 2:23 pm |
| WIC-1DSU-56K crossover cables | November 23, 2006, 11:16 pm |
| routing with crossover cables | February 9, 2007, 8:42 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> hardware options)
