Cisco Systems Cisco 2514 IOS Help
Subject Author Date
Cisco 2514 IOS Help jsmith12 10-16-06
`--> Re: Cisco 2514 IOS Help www.BradReese.C...10-16-06
Posted by on October 16, 2006, 7:33 pm
I need an updated IOS for my 2514 routers, however, I don't have an
Enterprise account w/Cisco. Can someone point me in the right
direction? Or possibly just send me a current Enterprise IOS?
Thanks.
dummyt68 at yahoo dot com
Posted by Walter Roberson on October 16, 2006, 8:03 pm
Cisco no longer sells IOS for 25xx routers; CCO (support contract) is
the only way you can get it from them.
IOS is not transferable under most conditions (e.g., unless you buy out
a company's complete assets). Germany and Denmark are exceptions;
I haven't manage to figure out if any of the rest of the EU is.
Sending you IOS is not something that can legitimately be done
(except maybe in the above two countries.) You'd need written
permission from Cisco to get around that, and they are not at all
likely to grant that permission.
Cisco has a "relicensing" program to allow buyers of used equipment
to acquire rights to run the software -- but they won't relicense
devices that old.
In other words, you are pretty much stuck with what you have; if it
isn't sufficient then you would need to buy a newer piece of equipment
from someone authorized by Cisco to offer software licenses.
Posted by www.BradReese.Com on October 16, 2006, 10:22 pm
Cisco is taking an active role in curtailing the unauthorized use of
grey market / used equipment without correct relicense agreements in
place and rewarding customers for purchasing legitimate software
relicenses for their units.
Cisco Software Relicensing For Used Cisco Units:
http://www.bradreese.com/cisco-embedded-software-licenses.htm
Sincerely,
Brad Reese
BradReese.Com - Cisco Jobs
http://www.bradreese.com/hot-jobs.htm
1293 Hendersonville Road, Suite 17
Asheville, North Carolina USA 28803
USA & Canada: 877-549-2680
International: 828-277-7272
Fax: 775-254-3558
AIM: R2MGrant
BradReese.Com - Cisco Salary and Compensation Rates
http://www.bradreese.com/compensation-database.htm
Similar ThreadsPosted
Cisco 2514 IOS Help October 16, 2006, 7:33 pm
Cisco 2514 Upgrade Boot ROM ? September 8, 2005, 11:53 am
upgrading Cisco 2514 from console September 25, 2005, 2:31 am
Cisco 2514 and serial cables April 19, 2007, 1:30 pm
2514 NAT configuration on ADSL March 11, 2006, 3:36 pm
How to unblock TCP port 42 across a 2514 April 21, 2006, 10:58 am
2503/2514 boot rom January 5, 2007, 10:17 am
FS 2514 - Dual Ethernet Router February 10, 2005, 6:55 am
Business VoIP Solutions Using Cisco Gateways, Cisco Call Agent, And Cisco IP Phones October 2, 2007, 8:02 pm
Discussion about segregating bandwidth with Cisco 7513, Cisco 3750 and Cisco 3640 June 17, 2006, 8:34 am
good cisco and juniper IPS site for intrusion prevention and cisco switch info January 5, 2007, 4:59 pm
Re: Q: Cisco AP 1131 -- "Unsupported device type" error in Cisco Network Assistant November 27, 2007, 1:19 pm
Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable August 15, 2008, 6:40 am
Re: Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable August 15, 2008, 7:32 am
Cisco 2970 strange traffic problem - stumped cisco support February 10, 2005, 12:19 pm
