Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Jaytee on October 10, 2006, 8:39 pm
Please log in for more thread options and then the log. Long and the short of it is I have 2 computers and a laptop. Laptop has a Cisco a/b/g wireless card while the two desktops have Linksys Wireless-G PCI cards. The Cisco card can go forever no problems, the desktops both have some issue where they get deauthenticated and ...well see below. It causes havoc when a user attempts to watch streaming media across the wireless links. Generally what I have to do is restart the wireless connection and it works for a time before the same problem pops back up. Config: ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname jtap ! no logging console enable secret 5 <removed>
ip subnet-zero ! ! no aaa new-model ! dot11 ssid jtwlan max-associations 2 authentication open authentication key-management wpa wpa-psk ascii 7 <removed>
! ! username jaytee password 7 <removed>
bridge irb ! ! interface Dot11Radio0 no ip address no ip route-cache ! encryption mode ciphers tkip ! ssid jtwlan ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 channel 2462 station-role root bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding bridge-group 1 spanning-disabled ! interface FastEthernet0 no ip address no ip route-cache duplex auto speed auto bridge-group 1 no bridge-group 1 source-learning bridge-group 1 spanning-disabled hold-queue 80 in ! interface BVI1 ip address 192.168.1.3 255.255.255.0 no ip route-cache ! ip http server no ip http secure-server ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag ! ! control-plane ! bridge 1 route ip ! ! ! line con 0 line vty 0 4 password 7<removed>
login
! end Event Log: Time Severity Description Mar 4 08:05:36.601 Information Interface Dot11Radio0, Station 0014.bf7b.1e86 Associated KEY_MGMT[WPA PSK] Mar 4 08:05:17.937 Debugging Station 0014.bf7b.1e86 Authentication failed Mar 4 08:05:07.711 Debugging Station 0014.bf7b.1e86 Authentication failed Mar 4 08:05:05.461 Information Interface Dot11Radio0, Deauthenticating Station 0014.bf7b.1e86 Reason: Previous authentication no longer valid Mar 4 08:05:05.461 Warning Packet to client 0014.bf7b.1e86 reached max retries, removing the client Mar 4 08:02:06.692 Information Interface Dot11Radio0, Station 0014.bf7b.1e86 Associated KEY_MGMT[WPA PSK] Mar 4 08:01:01.674 Debugging Station 0014.bf7b.1e86 Authentication failed Mar 4 08:01:00.454 Information Interface Dot11Radio0, Deauthenticating Station 0014.bf7b.1e86 Mar 4 08:00:46.605 Information Interface Dot11Radio0, Station 0014.bf7b.1e86 Associated KEY_MGMT[WPA PSK] Mar 4 08:00:45.422 Information Interface Dot11Radio0, Deauthenticating Station 0014.bf7b.1e86 | ||||||||||||||||
Posted by Aaron Leonard on October 11, 2006, 1:36 pm
Please log in for more thread options the latest Linksys firmware, then if this doesn't fix the problem, contact Linksys tech support. Either that or replace the Linksys cards with PI21AGs. Aaron --- ~ I've got a problem with my Cisco 1121G AP. I'll post the Config first ~ and then the log. Long and the short of it is I have 2 computers and a ~ laptop. Laptop has a Cisco a/b/g wireless card while the two desktops ~ have Linksys Wireless-G PCI cards. The Cisco card can go forever no ~ problems, the desktops both have some issue where they get ~ deauthenticated and ...well see below. It causes havoc when a user ~ attempts to watch streaming media across the wireless links. Generally ~ what I have to do is restart the wireless connection and it works for a ~ time before the same problem pops back up. ~ ~ Config: ~ ~ ! ~ version 12.3 ~ no service pad ~ service timestamps debug datetime msec ~ service timestamps log datetime msec ~ service password-encryption ~ ! ~ hostname jtap ~ ! ~ no logging console ~ enable secret 5 <removed>
~ ip subnet-zero ~ ! ~ ! ~ no aaa new-model ~ ! ~ dot11 ssid jtwlan ~ max-associations 2 ~ authentication open ~ authentication key-management wpa ~ wpa-psk ascii 7 <removed>
~ ! ~ ! ~ username jaytee password 7 <removed>
~ bridge irb ~ ! ~ ! ~ interface Dot11Radio0 ~ no ip address ~ no ip route-cache ~ ! ~ encryption mode ciphers tkip ~ ! ~ ssid jtwlan ~ ! ~ speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 ~ 36.0 48.0 54.0 ~ channel 2462 ~ station-role root ~ bridge-group 1 ~ bridge-group 1 subscriber-loop-control ~ bridge-group 1 block-unknown-source ~ no bridge-group 1 source-learning ~ no bridge-group 1 unicast-flooding ~ bridge-group 1 spanning-disabled ~ ! ~ interface FastEthernet0 ~ no ip address ~ no ip route-cache ~ duplex auto ~ speed auto ~ bridge-group 1 ~ no bridge-group 1 source-learning ~ bridge-group 1 spanning-disabled ~ hold-queue 80 in ~ ! ~ interface BVI1 ~ ip address 192.168.1.3 255.255.255.0 ~ no ip route-cache ~ ! ~ ip http server ~ no ip http secure-server ~ ip http help-path ~ http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag ~ ! ~ ! ~ control-plane ~ ! ~ bridge 1 route ip ~ ! ~ ! ~ ! ~ line con 0 ~ line vty 0 4 ~ password 7<removed>
~ login
~ ! ~ end ~ ~ Event Log: ~ ~ Time Severity Description ~ Mar 4 08:05:36.601 Information Interface Dot11Radio0, Station ~ 0014.bf7b.1e86 Associated KEY_MGMT[WPA PSK] ~ Mar 4 08:05:17.937 Debugging Station 0014.bf7b.1e86 Authentication ~ failed ~ Mar 4 08:05:07.711 Debugging Station 0014.bf7b.1e86 Authentication ~ failed ~ Mar 4 08:05:05.461 Information Interface Dot11Radio0, Deauthenticating ~ Station 0014.bf7b.1e86 Reason: Previous authentication no longer valid ~ Mar 4 08:05:05.461 Warning Packet to client 0014.bf7b.1e86 reached max ~ retries, removing the client ~ Mar 4 08:02:06.692 Information Interface Dot11Radio0, Station ~ 0014.bf7b.1e86 Associated KEY_MGMT[WPA PSK] ~ Mar 4 08:01:01.674 Debugging Station 0014.bf7b.1e86 Authentication ~ failed ~ Mar 4 08:01:00.454 Information Interface Dot11Radio0, Deauthenticating ~ Station 0014.bf7b.1e86 ~ Mar 4 08:00:46.605 Information Interface Dot11Radio0, Station ~ 0014.bf7b.1e86 Associated KEY_MGMT[WPA PSK] ~ Mar 4 08:00:45.422 Information Interface Dot11Radio0, Deauthenticating ~ Station 0014.bf7b.1e86 | ||||||||||||||||
Cisco 1121G AP and Linksys wireless clients
Yahoo!
Windows Live
del.icio.us
digg
Netscape
