Cisco Systems Change routing port to switch port
Subject Author Date
Change routing port to switch port xianli 03-05-08
Posted by on March 5, 2008, 4:53 am
Hi all:
Today when I try to change the Gi1/0/1(routing port) on the fibre
module of 3750 into switchport by issuing the "switchport" command,
then assign it to a vlan, then I connect it to a fibre module on a
nortel layer2 switch. I found out there is no conectivity between the
3750 and the nortel switch. The status of the Gi1/0/1 is "not
connected". Is it because I cant do it on a fibre module?
Thank you
Posted by blue-birdy on March 5, 2008, 8:37 am
On Mar 5, 12:53=A0pm, xia...@xianli.net wrote:
Hai,
wat Model of 3750 switch r u using?Gi1/0/1 is it fiber connection or
Ethernet?
B'cos i hav to deal with 3750 -24 10/100/1000 ethernet + 4 SFP.I have
couple of question reg that.Can u help me out?
Thanxs in advance.
Posted by on March 5, 2008, 8:31 pm
The switches I am working with is a 3750 48 10/100/1000 ethernet port
with 4 SFP module slots. If you have any porblems, just post it see if
I can help.
Posted by Maarten Carels on March 6, 2008, 3:32 am
Then you certainly mean gi1/0/49.
The 48 copper ports are numbered 1 thru 48, and the SFP ones are the
next 4. Same on 24 port versions.
The numbers actually are present (very tiny) in the link LEDs of the
ports.
Hope this helps,
--maarten
Posted by on March 6, 2008, 7:03 am
On Mar 6, 11:32=A0am, maarten.car...@uva.nl (Maarten Carels) wrote:
helllo......
no ...u r wrong....if it is 48 ports 10/100/1000 ethernet ......with 4
sfp ports
the first SFP port will be Gi/0/1 apart from that 48 ports.i think it
is needed to check both ends of the switches for correct match....
like same kind of transceiver are used or not???
Similar ThreadsPosted
Change routing port to switch port March 5, 2008, 4:53 am
Port mirroring in HP 2626-pwr 24 port switch October 25, 2005, 5:01 am
change FTP port April 27, 2007, 10:22 am
Change SSH Port September 11, 2007, 2:18 pm
change pdm listening port December 2, 2006, 6:16 am
Open port & change internal IP on PIX 501 March 8, 2006, 2:19 pm
Change Telnet Port Access to Router & Switches August 10, 2005, 8:39 pm
Switch port December 14, 2005, 12:09 am
switch port going up and down on specific NIC October 12, 2006, 9:47 am
TCP/UDP port or protocol-based routing February 6, 2006, 3:38 pm
Problem with Cisco Switch Port Please Help August 23, 2005, 12:43 pm
Filter Switch Port Traffic? February 11, 2009, 10:00 pm
Turning off a switch port using SNMP February 26, 2009, 11:26 am
how to monitor traffic going through a switch port November 18, 2009, 3:36 pm
HELP VPN, Routing issues, no acess to 25 port of exchange May 27, 2006, 4:26 am
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
