Cisco Systems Cat3750 - flash problem
Subject Author Date
Cat3750 - flash problem dennis 09-03-08
Posted by dennis on September 3, 2008, 11:13 am
Hi group,
I would like to upgrade a catalyst 3750E (WS-C3750E-TD-S) with another
IOS version.
But this update doesn't work . I try it with the command "archieve
download-sw" and I got the message can't read flash ..also when I try
to read the flash with dir flash: there is the same output.
For my understand there is a problem with the flash !? Maybe
corrupt ?
Did anyone have a similar problem ?
dennis
Posted by Peter on September 3, 2008, 3:44 pm
Hi Denis,
Is this a single 3750 or a stack of 3750's?
I had issues trying to convert a pair of single 3750's into a stack
and set them both to use the same version of IOS. The "archive"
command simply would not work for me, it wanted to DOWNGRADE 1 stack
member IOS to reach the others level, so I ended up just adding the
new IOS to EACH flash and setting the BOOT command in the config for
EACH switch, but I had to break the stack to do this manually.
Eventually I got the stack sorted but I had a fun time sorting them
out.
If you copy to FLASH: in a stack, then it copies to ALL stack members
flash. You can also copy to FLASH1, FLASH2, etc to reach specific
stack members if required. If I remember correctly the BOOT command
can be set to apply to all stack members or just 1...
If you are not using a Stack then all this is moot........;-).
If yu have a stack, then try "dir flash", then "dir flash1", "dir
flash2", etc, and list the output of each.
Good luck.................pk.
Peter from Auckland.
Similar ThreadsPosted
Cat3750 - flash problem September 3, 2008, 11:13 am
Cat3750 temperature September 4, 2006, 9:35 am
Cat3750 ACL debugging June 11, 2007, 5:16 am
MAC ACL and Cat3750 - broadcasts allowed or what? September 26, 2008, 8:44 am
dir, del flash: October 15, 2007, 7:51 pm
20 MB flash on 1600R ? July 10, 2006, 7:24 pm
Updating IOS, how much Flash do I have? April 2, 2007, 5:46 pm
AP of the 881 does not see usb flash memory November 17, 2009, 4:09 pm
Updating flash on 3620 - again August 11, 2005, 8:25 am
cisco 828 flash file August 11, 2005, 10:05 pm
Renaming files in the flash. August 17, 2005, 5:08 pm
3600 RAM and Flash Uopgrade November 23, 2005, 11:37 pm
Booting from flash with a 7206 January 10, 2006, 8:07 pm
Two Flash chips in 2500 May 14, 2006, 2:21 am
2600 flash erased August 1, 2006, 4:20 am
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
