Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by John Chajecki on December 4, 2005, 4:12 pm
Please log in for more thread options I've ytied everything I can think of, but I can't get the ADSL interface to establish a connection with my provider (PIPEX) on my Cisco 837 router. If I use DHCP, then I do not get an IP address assignement. The provider says that I should be using DHCP and confirm that an IP address has in fact be leased. The Cisco dosent seemm to see it though. If I use Negotiated, then I do appear get an IP address, but no connectivity. When I run the interface test if fails on something called 'Exit interface'. The options in the suggested fix do not appear to match any options available on the router. Here is my config: Current configuration : 5811 bytes ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname LydiSoft-ADSL ! boot-start-marker boot-end-marker ! memory-size iomem 5 no logging buffered enable secret 5 $mysecret enable password sh1l0h ! no aaa new-model ! resource policy ! ip subnet-zero no ip routing ! ! no ip dhcp use vrf connected ! ! ip dhcp update dns both no ip cef ip domain name mill-corner.ath.cx ip name-server 62.241.162.200 ip name-server 62.241.163.200 no ip ips deny-action ips-interface ip ddns update method sdm_ddns1 HTTP add http://username:password@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
remove
! no ftp-server write-enable ! crypto pki trustpoint TP-self-signed-2353383044 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-2353383044 revocation-check none rsakeypair TP-self-signed-2353383044 ! ! crypto pki certificate chain TP-self-signed-2353383044 certificate self-signed 01 ...... quit partition flash 2 10 2 ! username admin secret 5 $password username jchajecki privilege 15 secret 5 $password username chajj001 privilege 15 secret 5 $password ! ! no crypto isakmp ccm ! ! ! interface Ethernet0 description Internal LAN$ETH-LAN$ ip address 10.210.210.58 255.255.255.224 ip access-group 100 in ip nat inside ip virtual-reassembly no ip route-cache hold-queue 100 out ! interface Ethernet2 no ip address no ip route-cache shutdown hold-queue 100 out ! interface ATM0 no ip address no ip route-cache no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0.1 point-to-point no ip route-cache pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 ! ! interface FastEthernet1 duplex auto speed auto ! interface FastEthernet2 shutdown duplex auto speed auto ! interface FastEthernet3 shutdown duplex auto speed auto ! interface FastEthernet4 speed auto full-duplex ! interface Dialer0 ip address dhcp client-id Ethernet0 ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication chap pap callin ppp chap hostname arbk23@xtreme2.pipex.net ppp chap password 0 oongikoo ppp pap sent-username arbk23@xtreme2.pipex.net password 0 oongikoo ! ip classless ! ip http server ip http access-class 1 ip http secure-server ! ip nat inside source list 2 interface Dialer0 overload ! access-list 1 remark Auto generated by SDM Management Access feature access-list 1 remark SDM_ACL Category=1 access-list 1 permit 10.210.210.64 0.0.0.31 access-list 1 permit 10.210.210.32 0.0.0.31 access-list 2 remark INSIDE_IF=Ethernet0 access-list 2 remark SDM_ACL Category=2 access-list 2 permit 10.210.210.32 0.0.0.31 access-list 100 remark Auto generated by SDM Management Access feature access-list 100 remark SDM_ACL Category=1 access-list 100 permit tcp 10.210.210.64 0.0.0.31 host 10.210.210.58 eq 22 access-list 100 permit tcp 10.210.210.32 0.0.0.31 host 10.210.210.58 eq 22 access-list 100 permit tcp 10.210.210.64 0.0.0.31 host 10.210.210.58 eq 443 access-list 100 permit tcp 10.210.210.32 0.0.0.31 host 10.210.210.58 eq 443 access-list 100 permit tcp 10.210.210.64 0.0.0.31 host 10.210.210.58 eq cmd access-list 100 permit tcp 10.210.210.32 0.0.0.31 host 10.210.210.58 eq cmd access-list 100 deny tcp any host 10.210.210.58 eq telnet access-list 100 deny tcp any host 10.210.210.58 eq 22 access-list 100 deny tcp any host 10.210.210.58 eq www access-list 100 deny tcp any host 10.210.210.58 eq 443 access-list 100 deny tcp any host 10.210.210.58 eq cmd access-list 100 deny udp any host 10.210.210.58 eq snmp access-list 100 permit ip any any access-list 101 remark Auto generated by SDM Management Access feature access-list 101 remark SDM_ACL Category=1 access-list 101 permit ip 10.210.210.64 0.0.0.31 any access-list 101 permit ip 10.210.210.32 0.0.0.31 any dialer-list 1 protocol ip permit ! ! control-plane ! banner login ^CUnauthorised users strictly prohibited! If you are not authorised to log on then please disconnect now.^C ! line con 0 no modem enable line aux 0 line vty 0 4 access-class 101 in password password login transport input ssh ! scheduler max-task-time 5000 end I am using the SDM (CRWS dosen't work), but I used CLI to bring the Fatsthernet interfaces up before connecting with SDM. My supplier requires VC/MUX, ITU G.dmt and PPPoA. IP address delivered by DHCP. VPI/VCI 0,38. Have been playing with this for a few days now trying all sorts of settings but can't get anything to work. Any help or pointers would be greatlt appreciated. Thanks in advance. | |||||||||||||
Posted by Matty M on December 4, 2005, 6:03 pm
Please log in for more thread options > Hi,
> > I've ytied everything I can think of, but I can't get the ADSL interface > to establish a connection with my provider (PIPEX) on my Cisco 837 router. > If I use DHCP, then I do not get an IP address assignement. The provider > says that I should be using DHCP and confirm that an IP address has in > fact be leased. The Cisco dosent seemm to see it though. > > If I use Negotiated, then I do appear get an IP address, but no > connectivity. When I run the interface test if fails on something called > 'Exit interface'. The options in the suggested fix do not appear to match > any options available on the router. > > Here is my config: > > > Current configuration : 5811 bytes > ! > version 12.3 > no service pad > service timestamps debug datetime msec > service timestamps log datetime msec > no service password-encryption > ! > hostname LydiSoft-ADSL > ! > boot-start-marker > boot-end-marker > ! > memory-size iomem 5 > no logging buffered > enable secret 5 $mysecret > enable password sh1l0h > ! > no aaa new-model > ! > resource policy > ! > ip subnet-zero > no ip routing > ! <<SNIPPED>>
Hi, Try adding on your Dialer interface - ip address negotiated encapsulation ppp ppp ipcp dns request ppp ipcp wins request Cheers Matt | |||||||||||||
Posted by John Chajecki on December 5, 2005, 9:48 am
Please log in for more thread options Matt,
Thanks for your suggestion. I have tried this and now get: Checking interface status... UP Checking for DNS settings... Successful Checking interface IP address... Successful Checking exit interface... Failed No configured DNS server(s) are routable through the selected interface. Select 'Enter IP address or hostname' option or add a 'host specific/network specific/default' route through this interface and retest connection. | |||||||||||||
Posted by John Chajecki on December 5, 2005, 10:30 am
Thanks for your suggestion. I have applied this and now get the following: Checking interface status... UP Checking for DNS settings... Successful Checking interface IP address... Successful Checking exit interface... Failed No configured DNS server(s) are routable through the selected interface. Select 'Enter IP address or hostname' option or add a 'host specific/network specific/default' route through this interface and retest connection. I can't find an 'Enter IP address or hostname' option anywhere and I'm not sure how to add a 'host specific/network specific/default' route through this interface. Adding a route of 0.0.0.0 0.0.0.0 to Dialer1 or ATM0.1 does not seem to solve the problem. | |||||||||||||
Posted by Martin Kayes on December 5, 2005, 11:11 am
Please log in for more thread options Hi John,
You should try adding these lines to your config to reduce the MTU size, Pipex's DSLAM is probably dropping your packets as with the PPP encapsulation added they will be oversized. interface Ethernet0 ip tcp adjust-mss 1452 ! interface Dialer0 ip mtu 1492 ip tcp adjust-mss 1452 Also, I am not sure why you have a subinterface on the ATM 0, the config could be simplified to look like this: interface ATM0 no ip address no ip mroute-cache no atm ilmi-keepalive dsl operating-mode auto pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 Let me know what you get. Regards, Martin | |||||||||||||
Cannot establish connection with ADSL provider
Yahoo!
Windows Live
del.icio.us
digg
Netscape
