Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by tomarseneault on May 29, 2008, 10:12 pm
I have a 2811 with the advanced security feature pack. I'm configuring it to replace our old pix and 2621 but I can't set the default route to an "outside" interface (FastEthernet0/1), I can set it to an inside interface easy enough. The line in the config file is the same for both setups: ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 But when I enter in the 2nd line I get "Gateway of last resort is not set". I have tried using the IP of the next hop router as well, same results. I also compared it to our existing 2621 and it looks the same. Here are the interface setups: interface FastEthernet0/0 description Inside$ES_LAN$$ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$ $FW_INSIDE$ ip address 10.10.3.1 255.255.255.0 ip access-group 100 in ip nat inside ip virtual-reassembly duplex full speed 100 ! interface FastEthernet0/1 description Outside$ES_WAN$$ETH-WAN$$FW_OUTSIDE$ ip address 65.123.2.2 255.255.255.128 ip access-group 101 in ip verify unicast reverse-path ip inspect SDM_LOW out ip nat outside ip virtual-reassembly duplex full speed 100 crypto map SDM_CMAP_1 ! Could there be something in the ACLs that are causing problems? Is there any other information you all need to help with this? | |||||||
| Similar Threads | Posted |
| Need to route SMTP traffic through static interface (not default route) | March 27, 2007, 5:19 pm |
| Can't set default route to outside interface | May 29, 2008, 10:12 pm |
| learning destination MAC if default route uses interface and not next-hop IP | September 20, 2005, 11:19 am |
| What is the default precedence: local-route, static-route, OSPF-route? | August 4, 2008, 3:00 am |
| question for static route -- default route | April 1, 2009, 12:03 am |
| question for static route -- default route | April 1, 2009, 12:04 am |
| RIP + Default Route | October 20, 2005, 9:58 pm |
| Default Route | November 4, 2005, 8:05 pm |
| Default Route(s) | August 14, 2006, 11:58 am |
| Specified a default route by ACL. | October 10, 2006, 1:06 pm |
| Default Route BGP Query | December 4, 2006, 8:24 pm |
| Default Route Question | September 4, 2007, 3:32 pm |
| Pix VPN-Tunnel Default Route? | November 22, 2007, 8:15 am |
| VLAN Default Route | October 2, 2008, 12:31 pm |
| NAT and backup default route | December 29, 2008, 11:45 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
