Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on December 6, 2005, 6:27 am
12.3(2)XC2 and an issue relating to CBAC / 'ip inspect' command has come to light. When the 'ip inspect' command is applied outbound only on the Dialer0 interface, we are able to access/browse the Internet from the internal network successfully but cannot receive incoming mail. Outgoing e-mail is fine. However, when the 'ip inspect' command (outbound) is removed from the Dialer0 interface altogether, we are able to receive incoming mail but cannot get to the Internet at all. We've worked around this by applying the 'ip inspect' commands to the Dialer0 interface both in AND outbound so as not to disrupt service but think that surely this must only be a temporary measure due to the increased security risk. This router is configured in practically exactly the same way as another 837 also running IOS version 12.3(2)XC2. With the 'ip inspect' command applied outbound only on the Dialer0 interface of this second router, we see none of the same issues and everything works fine. I think that this may be a symptom of a misconfiguration rather than a problem in itself but I don't know what. Could it be NAT or route maps? I will post config if anyone wants to have a look. Thank you in advance for you help & suggestions. | |||||||||||||
Posted by on December 6, 2005, 11:28 am
Please log in for more thread options permits incoming mail and keep the Inspect. access-l 100 permit tcp any host my.mail.server eq 25 int d0 access-g 100 in substitute the EXTERNAL address of the mail server for "my.mail.server". | |||||||||||||
Posted by slim on December 6, 2005, 7:40 pm
Please log in for more thread options anybody43@hotmail.com wrote:around manually defining ACL's? In fact, I believe in 12.3T, a feature called "firewall ACL bypass" was introduced. If I understand it correctly, that feature is to eliminate redundant ACL processing - an inbound pass, inspect, and outbound pass, with the idea being that if inspect "sees" the traffic, the other two ACL processes are assumed to be performed. I ask this because I'm starting to work with the firewall feature set myself, and too have noticed odd behavior. In my case, with inspect on, RTP flows between IP phones work. Shut it down, and I get one-way audio. All of this with no ACL's. However, I have to explicitly define ACL's for skinny even though it's configured to be inspected. Very odd, and I don't understand the inconsistency. Any insights would be appreciated! | |||||||||||||
| Similar Threads | Posted |
| CBAC / IP Inspect Confusion | December 6, 2005, 6:27 am |
| IOS upgrade confusion | January 29, 2007, 11:00 am |
| VTP Transparent mode confusion | September 21, 2005, 12:11 pm |
| HSRP neighbors confusion | January 11, 2007, 7:31 pm |
| Confusion regarding logical vs. physical drawings | July 18, 2005, 8:20 am |
| PIX 515 Inbound/Outbound access list confusion | March 7, 2006, 9:20 pm |
| IP Inspect | May 18, 2006, 7:13 pm |
| ISR CBAC prolem | January 22, 2006, 6:52 am |
| Proxy and CBAC. | August 28, 2006, 6:03 am |
| Cisco 837 - CBAC Bug. | November 22, 2005, 4:58 am |
| CBAC 7200 | October 4, 2006, 5:41 am |
| HTTP Inspect | November 11, 2005, 3:05 pm |
| HTTP INSPECT | November 11, 2005, 3:11 pm |
| IP Inspect vs. established | March 12, 2009, 9:59 pm |
| IP INSPECT question | January 21, 2010, 6:28 am |
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language! Click Here to learn more |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> int d0
> access-g 100 in
