Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Matthias Scheler on December 21, 2006, 1:11 pm
Please log in for more thread options is there another way to bridge between "Dot11Radio0" and "Vlan1" on a Cisco 877W than using "bridge irb" and "bridge 1 route ip"? The problem with the above setup is that it doesn't work with IPv6 at all. How can I e.g. configure plain layer 2 bridging? Kind regards -- Matthias Scheler http://zhadum.org.uk/ | ||||||||||||||||
Posted by Aaron Leonard on December 21, 2006, 1:42 pm
Please log in for more thread options As I understand it, there is no way to do IPv6 over wireless in an ISR; this will be supported when/if CSCej50923 is resolved (which will provide IPv6 support for IRB.) Regards, Aaron --- | ||||||||||||||||
Posted by on December 21, 2006, 3:53 pm
Please log in for more thread options OK, I give in, I'll top post, just this once:-)
I have no idea if this may help or not in this case however I think that I have configured and used an IP address (IPv4) directly on the Dot11Radio interface. No bridging at all. Worked fine. Aaron Leonard wrote: > Matthias,
> > As I understand it, there is no way to do IPv6 over wireless in an > ISR; this will be supported when/if CSCej50923 is resolved (which > will provide IPv6 support for IRB.) > > Regards, > > Aaron > > --- > > > Hello,
> > > > is there another way to bridge between "Dot11Radio0" and "Vlan1" on > > a Cisco 877W than using "bridge irb" and "bridge 1 route ip"? > > The problem with the above setup is that it doesn't work with IPv6 > > at all. > > > > How can I e.g. configure plain layer 2 bridging? > > > > Kind regards > > | ||||||||||||||||
| Similar Threads | Posted |
| Bridging with a Cisco 877W | December 21, 2006, 1:11 pm |
| Bridging Ethernet and WLAN with a Cisco 877W | October 29, 2006, 4:05 pm |
| Cisco 878 bridging? | November 3, 2006, 11:23 am |
| Cisco 1720 - Bridging | July 20, 2005, 8:13 pm |
| Bridging a Cisco SOHO 96 | November 9, 2005, 10:23 am |
| NAT type of Cisco 877W | November 26, 2005, 8:14 pm |
| Using IPv6 on a Cisco 877W | October 21, 2006, 10:52 am |
| Cisco 877W of 857W ? | May 23, 2008, 10:28 am |
| Cisco 877W and Demon | November 22, 2008, 9:39 am |
| cisco 2600 as bridging firewll ? | January 27, 2006, 3:32 pm |
| Problem config Cisco 877w | October 26, 2005, 5:02 am |
| Cisco 877W Router ( Newbie ) | November 3, 2005, 7:28 pm |
| Upgrading flash in a Cisco 877W | October 27, 2006, 5:31 am |
| Cisco 877W as Wireless client | July 1, 2007, 12:49 pm |
| Cisco 877W, fixed IP, ISP connection drops | June 30, 2006, 2:37 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> at all.
> Kind regards
