Cisco Systems Bonded T1 with 1720 or 2620
Subject Author Date
Bonded T1 with 1720 or 2620 bavien 08-25-08
Posted by on August 25, 2008, 4:44 pm
Need recommendation on which router to use:
Currently running a T1 line with Cisco 1720 router (32MB DRAM and 8MB
Flash) running IOS 12.2. Company planning on increasing the bandwidth
by bonding 2 T1s. Will the current 1720 router be resourcefully enough
to handle and perform decently with a second WIC card?
Need recommendation on whether to stay with this 1720 router or go
with a Cisco 2620.
Any idea on the requirement in terms of IOS/DRAM memory/FLASH for
both 1720 and 2620 in order to run 2 WIC cards for bonding 2 T1s?
Thanks.
BV
Posted by Doug McIntyre on August 25, 2008, 5:01 pm
bavien@gmail.com writes:
>with a Cisco 2620.
Trash both and get a used 1841?
First off, you don't need DRAM/Flash for running two T1s. The only
thing you need DRAM/Flash for is running the IOS image you want to
run. A 2nd T1 doesn't use up more memory (over a tiny slight change
in buffer space, barely registerable). Multinklink and/or IP cef have
been part of IOS for a long long time. MLFR not so long.
The 2620 isn't a huge step up over the 1720. My rule of thumb was
always one T1 in a 1720, 2-3 T1s for the 2610/2620 (assuming no
NAT/CBAC). The 2600 really can't push much more than that.
If you are looking to get another used box, I'd look at a used 1841 instead,
although it uses different WIC cards than the 1720 did. (the
WIC-1DSU-T1 isn't supported on the 1841).
Then you'll have to match the method used by the other side for
running the dual T1. (ie. MLPPP or IP cef load balanced).
Posted by on August 25, 2008, 5:11 pm
> bav...@gmail.com writes:
> >with a Cisco 2620.
> >Any idea on the requirement in terms of =A0IOS/DRAM memory/FLASH for
> run. =A0A 2nd T1 doesn't use up more memory (over a tiny slight change
> If you are looking to get another used box, I'd look at a used 1841 inste=
ad,
Thanks for the quick response Doug.
Happen to know the WIC name for router 1841 (if I go with 1841)?
Any particular reason NOT going with 1720?
Thanks again.
BV
Posted by Doug McIntyre on August 25, 2008, 5:24 pm
>> >with a Cisco 2620.
>ad,
WIC-1DSU-T1-V2
(ie. only the V2 models work in the ISR and any future models).
It doesn't generally have the capacity to push many packets. I've
seen them run out of steam after 2-2.5Mbps or so of sustained traffic
(ie. you don't get your full 2 T1s worth).
The 2610/2620 run out of steam around 4-5Mbps.
Posted by on August 25, 2008, 5:32 pm
> >> >by bonding 2 T1s. Will the current 1720 router be resourcefully enoug=
h
> >> >with a Cisco 2620.
> >> >Any idea on the requirement in terms of =3DA0IOS/DRAM memory/FLASH fo=
r
> >> run. =3DA0A 2nd T1 doesn't use up more memory (over a tiny slight chan=
ge
> >> If you are looking to get another used box, I'd look at a used 1841 in=
ste=3D
> >ad,
> WIC-1DSU-T1-V2
> It doesn't generally have the capacity to push many packets. =A0I've
> The 2610/2620 run out of steam around 4-5Mbps.- Hide quoted text -
> - Show quoted text -
Very helpful. Thanks again...
BV
Similar ThreadsPosted
Bonded T1 with 1720 or 2620 August 25, 2008, 4:44 pm
Re: Bonded T1 with 1720 or 2620 August 26, 2008, 8:11 am
Bonded T1s from different carriers? January 3, 2006, 1:48 pm
Bonded DSL with 2611XM September 11, 2006, 4:26 pm
Bonded T1 - 2xT1 - Upload Help May 4, 2007, 3:26 pm
Sample config of Bonded T1 August 2, 2007, 9:42 am
Cisco 1841 - Bonded DSL Configuration August 21, 2006, 11:45 pm
1720 help February 12, 2006, 4:39 am
1720 December 30, 2006, 7:59 am
1720 and SDM July 21, 2008, 3:23 pm
1720 and comcast February 19, 2006, 8:57 pm
1720 IOS Version help June 28, 2006, 1:14 pm
pix 501 w/1720 router. October 1, 2006, 10:07 am
1720 Router October 24, 2006, 10:10 am
From 1720 to 1841 November 9, 2006, 3:56 pm
