Cisco Systems Best Hardware To Connect Two Private Networks
Subject Author Date
Best Hardware To Connect Two Private Networks christopher.crn 04-19-08
Posted by on April 19, 2008, 11:55 am
I need to connect two office suites that are located in the same
building, less than 100 meters apart. Both suites have address schemes
of 192.168.0.x. Both suites have a managed switch (Netgear FSM726).
These switches do not appear to have VLAN capabilities. There are
about 35 devices on each side. It seems to me that changing one side
to 192.168.1.x and placing a router between the two sites is the way
to go, but I have never done anything like this before.
Is there some better, easier, more secure way of connecting these two
sites than using a router? I know that a layer 3 switch could be used,
but read this would not support a WAN port, which may be needed in the
future. If a router or layer 3 switch is the way to go any thoughts on
make/model?
If I need to supply more information, please ask away!
Thanks for any help,
Chris
Posted by stephen on April 19, 2008, 5:32 pm
the important bit here is missing - what are you trying to achieve?
do you need to keep the 2 networks separate at all?
if not, just Cat 5 or fibre between the 2 switches and you have a link.
the main complication after that is making sure any servers etc do not have
address clashes, and only running 1 copy of DHCP.
or - if they need to maintain separate networks (ie you need to be able to
split the sites again later maybe),
then that is different.
> make/model?
layer 3 switch.
entry level Cisco would be a Cat 3560, or a few other choices.
> Chris
Regards
stephen_hope@xyzworld.com - replace xyz with ntl
Posted by on April 20, 2008, 8:44 am
> > about 35 devices on each side. =A0It seems to me that changing one side
I would like to have connectity between the networks and be able to
use computer names to locate computers from either side. On the other
hand I want packets to stay on thier own side of the fence unless they
need to cross to the other side (ie No Broadcast).
> the main complication after that is making sure any servers etc do not hav=
e
> or - if they need to maintain separate networks (ie you need to be able to=
> > make/model?
> layer 3 switch.
Thanks, I will take a look at this model..
> > Chris
> Regards
> stephen_h...@xyzworld.com - replace xyz with ntl
Similar ThreadsPosted
Best Hardware To Connect Two Private Networks April 19, 2008, 11:55 am
Subnetting, private networks & default routes April 22, 2006, 12:49 pm
How can I connect 1 Switch to 2 different networks ? April 23, 2007, 3:41 am
Need to connect 2 private Lans for sharing files while maintining security July 13, 2007, 7:59 am
WE BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, In January 12, 2008, 10:50 am
WE BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, In January 24, 2008, 12:27 am
WE BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, In February 3, 2008, 3:59 pm
WE BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, In February 9, 2008, 8:02 am
WE BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, In February 10, 2008, 7:11 pm
I BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, Int May 6, 2008, 2:22 am
I BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, Int July 19, 2008, 4:24 pm
I BUY used, new and refurbed Sun, Cisco, Lucent, Nortel, Alcatel, 3com, IBM, HP, Compaq, Dell, Madge, Cabletron, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, Int August 10, 2008, 12:08 pm
I am looking to buy Cisco, Lucent, Nortel, Alcatel, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, Intel, Motorola, Nokia VPN/Firewall, Netscreen, Microsoft Adobe, February 24, 2008, 8:23 am
I am looking to buy Cisco, Lucent, Nortel, Alcatel, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, Intel, Motorola, Nokia VPN/Firewall, Netscreen, Microsoft Adobe, March 9, 2008, 6:09 am
I am looking to buy Cisco, Lucent, Nortel, Alcatel, Juniper Networks, Bintec, Siemens, Foundry, Networks, Extreme Networks, Fore/Marconi, Tellabs Lucent/Avaya/Ascend, Xylogics, Brocade, Intel, Motorola, Nokia VPN/Firewall, Netscreen, Microsoft Adobe, March 16, 2008, 6:43 pm
